Table: Deleted Row (discarding, resuming) [message #677255] |
Tue, 07 June 2011 18:57  |
I have a ITableRow r.
When I delete this row in a Table t:
It disappears from the array returned by t.getRows().
And as long as I have AutoDiscardOnDelete ==> false, it appears in the array returned by t.getDeletedRows(). And r.getStatus() == STATUS_DELETED
So far so good.
How can I "resume" the deleted row ?
I have try:
It changes the status of the row returned by t.getDeletedRows() but the row is not visible and to in the array t.getRow().
If I add a new row r1 (with the same primary key):
r1 = addRowsByMatrix(new Object[]{new Object[]{
categoryId, //== t.getCategoryIdColumn().getValue(r)
t.getNameColumn().getValue(r)
}}); I have r1 in the array returned by t.getRows() with r1 status == STATUS_INSERTED
I have r in the array returned by t.getDeleteRows() with r == STATUS_DELETED
I also have tried to discard the deleted row: this doesn't seems to be possible: nothing append. t.deleteRow(r)
t.discardRow(r) => r is still in t.getDeletedRow().
This is not the the behavior I have expected.
Re: Table: Deleted Row (discarding, resuming) [message #685621 is a reply to message #685314] |
Fri, 17 June 2011 17:43   |
Thanks for your answer...
I manage to solve my problem server-side: for the "primary key" Column (index defined by valueColumn), I check if there is a STATUS_INSERTED and STATUS_DELETED row. If yes I update the status to change it to STATUS_UPDATED (=> Nothing changed in the database for STATUS_UPDATED rows). On the client side I ensure that I do not have multiple STATUS_INSERTED rows for the same primary key Value. Multiple deletes are not a problem with my database query.
private void cleanupTable(AbstractTableFieldData table, int valueColumn) {
HashMap<Object, Integer> deletedMap = new HashMap<Object, Integer>();
HashMap<Object, Integer> insertedMap = new HashMap<Object, Integer>();
for (int i = 0; i < table.getRowCount(); i++) {
switch (table.getRowState(i)) {
case ITableHolder.STATUS_INSERTED:
if (deletedMap.containsKey(table.getValueAt(i, valueColumn))) {
Integer index = deletedMap.get(table.getValueAt(i, valueColumn));
table.setRowState(index.intValue(), ITableHolder.STATUS_UPDATED);
table.setRowState(i, ITableHolder.STATUS_UPDATED);
else {
insertedMap.put(table.getValueAt(i, valueColumn), Integer.valueOf(i));
break;
case ITableHolder.STATUS_DELETED:
if (insertedMap.containsKey(table.getValueAt(i, valueColumn))) {
Integer index = insertedMap.get(table.getValueAt(i, valueColumn));
else {
deletedMap.put(table.getValueAt(i, valueColumn), Integer.valueOf(i));
break;
case ITableHolder.STATUS_NON_CHANGED:
case ITableHolder.STATUS_UPDATED:
default:
//Do nothing
break;
This should work... until there is a discaredDeletedRow(ITableRow) in the AbstractTable in the client.
Re: Table: Deleted Row (discarding, resuming) [message #750299 is a reply to message #685621] |
Tue, 25 October 2011 14:26   |
Jeremie Bresson wrote on Fri, 17 June 2011 23:43This should work... until there is a discaredDeletedRow(ITableRow) in the AbstractTable in the client.
I opened a bug: Bug 361985
Jeremie Bresson wrote on Fri, 17 June 2011 23:43the "primary key" Column (index defined by valueColumn)
Writing such utility functions that rely on an index as int is dangerous, because they are called with:
cleanupTable(formData.getActorsTable(), 0);
If a column is inserted before the first column (ActorIdColumn), the code is still valid, but the code do not work as expected. It would be better to call it with:
cleanupTable(formData.getActorsTable(), ActorsTable.ACTOR_ID_COLUMN_ID);
In order to change the SDK to insert the column indexes as constant, I opened and proposed a patch: Bug 356426
Re: Table: Deleted Row (discarding, resuming) [message #774873 is a reply to message #773044] |
Wed, 04 January 2012 15:30  |
Jeremie Bresson wrote on Sat, 31 December 2011 10:43How can I test this modification (and write a test) to ensure that the methods work as expected ?
I added some tests for my patch (in order to ensure it works as expected)... The patch itself also needed an update...
Everything is in Bugzilla...
FUDForum. Page generated in 0.26278 seconds
