Home » Archived » BIRT » Show a preview of the report through runtime API(Show a report layout)
icon5.gif  Show a preview of the report through runtime API [message #750129] Tue, 25 October 2011 12:45 Go to next message
I want to show a preview of a report in a JEditorPane, usually i run the report and display it in a JEditorPane running an IRenderTask run method.
As preview i mean show only the report layout without any data ...
Is there a way to execute only a preview of the report without loading the data from the datasource ( without executing the query on the database), so the report should run faster ?
Re: Show a preview of the report through runtime API [message #750401 is a reply to message #750129] Tue, 25 October 2011 15:27 Go to previous messageGo to next message
You can get a thumbnail of the report but I do not think this is what
you want. Take a look at the general properties and click on the ...
button next to the Thumbnail property. This will generate one for you.
Jason
Re: Show a preview of the report through runtime API [message #750473 is a reply to message #750129] Tue, 25 October 2011 16:11 Go to previous messageGo to next message
Ok, Thanks.
What are the size of the thumbnail image ?
Can i retrieve this thumbnail from engine API ?
Re: Show a preview of the report through runtime API [message #750519 is a reply to message #750473] Tue, 25 October 2011 16:36 Go to previous message
I believe it is 180x229 pixels. Look at an example one attached.
If you generate it as part of the design process you can get it at run
time like:
design = engine.openReportDesign("Reports/TopNPercent.rptdesign");
ReportDesignHandle rdh = (ReportDesignHandle)design.getDesignHandle();
byte[] ba = rdh.getThumbnail();
ByteArrayInputStream inputStream = new ByteArrayInputStream( ba );
Image image = new Image( null, inputStream );
try {
final BufferedImage bufferedImage = ImageIO.read(new
ByteArrayInputStream(ba));
ImageIO.write(bufferedImage, "png", new
File("c:/test/image2.png"));
} catch (IOException e) {
e.printStackTrace();
Jason
On 10/25/2011 4:11 PM, Alessio Pollero wrote:
> Ok, Thanks.
  • Attachment: image.png
    (Size: 6.50KB, Downloaded 156 times)
Previous Topic:XML Data Source
Next Topic:Asynchrony Testing
Current Time: Sat Jul 26 09:37:28 EDT 2025
Powered by FUDForum. Page generated in 0.07004 seconds
