Hive dataset : column sum [message #749432] |
Tue, 25 October 2011 04:08  |
I want to use BIRT for some reporting against data stored in Hive.
I defined a simple dataset with the following query :
SELECT day, site, responsecode, sum(occurences) FROM access_logs GROUP BY day, site, responsecode .
The query runs fine in the Hive client.
However, in BIRT I have an exception : BIRT tries to get the value of the column "sum(occurences)" as a BigDecimal, unfortunately the method getBigDecimal is not implement in the Hive JDBC driver.
I tried to change the value of the output column from Decimal to Integer but BIRT still wants to get the value as a BigDecimal.
Is there any other Hive / BIRT users who have the same problem ? How do you solve it ?
Laurent
Re: Hive dataset : column sum [message #750074 is a reply to message #749432] |
Tue, 25 October 2011 12:04  |
Laurent,
This sounds like a bug. Can you open a bugzilla entry for this?
If you select the occurences and not the sum does it work?
Jason
On 10/25/2011 4:08 AM, Laurent Vaills wrote:
> you solve it ?
> Laurent
FUDForum. Page generated in 0.31093 seconds
