Home » Archived » BIRT » XML Data Source(XML Data Source)
XML Data Source [message #748239] Mon, 24 October 2011 11:24 Go to next message
I have been using the 2.5 web viewer that I built from source. I am trying to upgrade to 3.7 but I am running into some issues.
I had to modify the eclipse data tools project to get the webviewer working in our production environment. Specifically, org.eclipse.datatools.enablement.oda.xml
My question is, does BIRT 3.7 web viewer still use this for xml datasources? I have modified the jars and even through in some logging but it appears this is not used.
All of our reports pull from a xml datasource via http://www.mydatasource.com
My real problem is I have to be able to modify the request right before I call the url to get the xml datasource.
Any help would be greatly appriciated.
-Eric
Re: XML Data Source [message #748428 is a reply to message #748239] Mon, 24 October 2011 13:24 Go to previous messageGo to next message
Yes BIRT still uses that package for xml access. What jar are you
modifying?
As another option you could use the custom class feature of the web
service data source. Take a look at the attached document that has a
section on custom class.
http://www.birt-exchange.org/org/devshare/designing-birt-reports/461-birt-web-service-oda-article/
Jason
On 10/24/2011 11:24 AM, wozniakem wrote:
> Hello,
> -Eric
Re: XML Data Source [message #749780 is a reply to message #748428] Tue, 25 October 2011 08:39 Go to previous messageGo to next message
I cant use the custom class as that is for web services. This is just from an xml source via http.
I am modifying org.eclipse.datatools.enablement.oda.xml.source_1.2.1.v201104121500.jar.
specifically XMLSourceFromPath and org.eclipse.datatools.enablement.oda.xml.impl.Connection
However, when I modify the jar it wont run. I removed all my code and just put some system.out.println(); even the printlns will not run.
Re: XML Data Source [message #750064 is a reply to message #749780] Tue, 25 October 2011 11:58 Go to previous messageGo to next message
This probably because the jar is signed. Open the jar and
in the META-INF folder delete everything but the MANIFEST.MF file.
openthe MANIFEST.MF file and delete all the entries similar to the
following:
s
SHA1-Digest: VJUfJZPOB7zbjxRv4YMky1/Yuvs=
BTW the web service uses the xml datasource to do the xpath mapping of
columns so a custom class should work in your case.
Jason
> I am modifying
Re: XML Data Source [message #750294 is a reply to message #750064] Tue, 25 October 2011 14:22 Go to previous message
Thank you, removing the hashes fixed it.
Again, thank you for your time.
Previous Topic:Viewer query parameters in Reload.rptlibrary
Next Topic:Show a preview of the report through runtime API
Current Time: Sat Jul 26 03:54:16 EDT 2025
Powered by FUDForum. Page generated in 0.04305 seconds
