Eclipse CDT stack overflow problem,need help. [message #747256] |
Sun, 23 October 2011 21:29  |
Hello everyone, I started using Eclipse CDT (with MinGW on Windows) recently.
I need some very large arrays in my project.
As a result, stack overflow occurred.
In VC6.0, I used to increase the "stack allocation" amount in project->settings->link->output->stack allocation when this happened.
So where do I change the settings in Eclipse? Thanks a lot.
ps: I know there is a way to avoid this. Just use the "new" command to create large arrays and no stack overflow would happen. But I really want to know where I can increase the default stack amount in Eclipse.
Thanks again.
Re: Eclipse CDT stack overflow problem,need help. [message #753630 is a reply to message #752371] |
Fri, 28 October 2011 03:05  |
igoat wrote on Wed, 26 October 2011 13:19Oh, I found it.
In Project Properties->C/C++Build->Settings->Tool Settings->MinGW C++ Linker, I found there's a text box called "command" with initially "g++" in it.
So I should just change it into someting like "g++ -Wl,--stack,0xFFFFFF" and all the stack overflow problem can be solved?
Yes, but it's better to leave the "command" untouched and add the options to the "Miscellaneous" field of the linker.
FUDForum. Page generated in 0.05270 seconds
