Home » Archived » Eclipse Process Manager (Stardust) » Document Service Integration - Attached Document Panel(DMS - Attached document panel)
Document Service Integration - Attached Document Panel [message #749249] Tue, 25 October 2011 01:30 Go to next message
I modified a process in version > 5.3 model to process attachments. Once a document has been attached to a process the first document in the document list is always displayed in a panel as I navigate from activity to activity. Is there a way not to automatically display the document panel on activity navigation?
Re: Document Service Integration - Attached Document Panel [message #749251 is a reply to message #749249] Tue, 25 October 2011 01:32 Go to previous messageGo to next message
You can change this behavior in the user preferences.You get to the menu via the button on the top right labeled "Configuration".
Then select from the tree: Views - "Activity Panel" here you can uncheck "Display Process Attachment".
Note: User must have the Administrator role to see the "Configuration" button in the upper right corner.
[Updated on: Tue, 25 October 2011 01:33] by Moderator
Re: Document Service Integration - Attached Document Panel [message #749253 is a reply to message #749251] Tue, 25 October 2011 01:33 Go to previous message
Thanks. That fixed it.
Previous Topic:Extremely high number of SQL statements executed for activity instance query
Next Topic:Historical event data from a Process Instance is empty
Current Time: Thu Jul 31 03:29:16 EDT 2025
Powered by FUDForum. Page generated in 0.11084 seconds
