Home » Eclipse Projects » Remote Application Platform (RAP) » Setting url parameter
Setting url parameter [message #74840] Wed, 20 February 2008 02:12 Go to next message
Originally posted by: fannyziegler.gmx.de
to read a parameter out of the url of my rap servlet I use the following:
HttpServletRequest request = RWT.getRequest();
System.out.println(request.getParameter("id"));
Is it also possible to change the parameter values in the url? How can I
achieve this? I need to write a parameter value in the url so that another
application can read it.
Fanny
Re: Setting url parameter [message #74873 is a reply to message #74840] Wed, 20 February 2008 03:20 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
this is common servlet technology. The request object provided by the
server is readonly regarding the request parameters. To share key-value
pairs with 'other' applications regarding the same request you may use
HttpServletRequest#setAttribute(String,Object). For RAP internal
exchange you may use the convenience RWT#getSessionStore()
implementation.
I'm sorry but I don't get the second question. What is it exactly that
you are trying to do, what do you mean by 'other application'?
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Fanny [mailto:fannyziegler@gmx.de]
Bereitgestellt: Mittwoch, 20. Februar 2008 08:13
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Setting url parameter
Betreff: Setting url parameter
following:
another application can read it.
Fanny
Re: Setting url parameter [message #74903 is a reply to message #74873] Wed, 20 February 2008 03:38 Go to previous messageGo to next message
thanks for your answer.
I need to add to the url that is displayed in the browser a new parameter.
So my url is: http://127.0.0.1:2028/rap?startup=default
When a button is pressed I want to change the url so that it displays:
http://127.0.0.1:2028/rap?startup=default&id=1 for example.
Re: Setting url parameter [message #74939 is a reply to message #74903] Wed, 20 February 2008 03:56 Go to previous messageGo to next message
this isn't possible since RAP uses AJAX for request processing. This
means the URL in the browser which represents the initial session
request doesn't change anymore. There is only one document for the
complete user session, no browser history etc. RAP (as with any
AJAX-app) does not replace the current document with a new document each
time a request is proceeded, the response of RAP-Requests are used to
modify the current loaded document subsequently.
Ciao
Frank
Bereitgestellt: Mittwoch, 20. Februar 2008 09:38
Betreff: Re: Setting url parameter
parameter.
Re: Setting url parameter [message #74948 is a reply to message #74939] Wed, 20 February 2008 04:11 Go to previous messageGo to next message
ok, I understand that I canŽt change the url within one user session. But
I could start a new session with a changed url, couldn`t I? Would this be
possible or wouldnŽt this change the browser url?
Greetings,
Fanny
Re: Setting url parameter [message #75298 is a reply to message #74948] Sat, 23 February 2008 16:49 Go to previous message
that's true, using a link with a changed URL would change the entry in
the URL-Field in the browser.
Ciao
Frank
Bereitgestellt: Mittwoch, 20. Februar 2008 10:11
But I could start a new session with a changed url, couldn`t I? Would
this be possible or wouldnŽt this change the browser url?
Greetings,
Fanny
Previous Topic:Custom widgets and Themes
Next Topic:Synchronized scrollbars
Current Time: Sun Aug 31 07:19:30 EDT 2025
Powered by FUDForum. Page generated in 0.04098 seconds
