Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Name mapping
Name mapping [message #74828] Sun, 11 March 2007 07:37 Go to next message
Is it possible to give a class another name in the db(schema)?
for example:
crypticName -> cName
Mit freundlichen Grüßen
arc solutions GmbH
Sandro Weiser
sandro.weiser@arcsolutions.de
www.arcsolutions.de
Handelsregister
Amtsgericht Chemnitz HRB 19907
Geschäftsführer der ARC Solutions GmbH: Alexander Hoffmann
Re: Name mapping [message #74846 is a reply to message #74828] Sun, 11 March 2007 09:03 Go to previous messageGo to next message
Cause:
Table `CSMCharacteristicValueContainer` doesn't exsist: its
`CSMCharacteristicValueContaine`!!!
(database only supports 30 chars for table names, so we had to set
PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH, "30").
87504 [main] DEBUG org.hibernate.transaction.JDBCTransaction - begin
87504 [main] DEBUG org.hibernate.jdbc.ConnectionManager - opening JDBC
connection
87504 [main] DEBUG
org.hibernate.connection.DriverManagerConnectionProvider - total
checked-out connections: 0
87504 [main] DEBUG
org.hibernate.connection.DriverManagerConnectionProvider - using pooled
JDBC connection, pool size: 0
87504 [main] DEBUG org.hibernate.transaction.JDBCTransaction - current
autocommit status: false
87504 [main] DEBUG org.hibernate.jdbc.JDBCContext - after transaction begin
87520 [main] DEBUG
org.hibernate.event.def.DefaultInitializeCollectionEventList ener -
initializing collection [CSMInstance.csmValueContainer#3]
87520 [main] DEBUG
checking second-level cache
87520 [main] DEBUG
collection not cached
87520 [main] DEBUG org.hibernate.loader.Loader - loading collection:
87520 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to open
PreparedStatement (open PreparedStatements: 0, globally: 0)
87520 [main] DEBUG org.hibernate.SQL - select
csmvalueco0_.`CSMCharacteristicValueConta_id` as CSMChar20_4_,
csmvalueco0_.e_id as e1_4_,
csmvalueco0_.`CSMINSTANCE_CSMVALUECONTAI_IDX` as CSMINST28_4_,
csmvalueco0_.e_id as e1_1_3_, csmvalueco0_.e_version as e3_1_3_,
csmvalueco0_.`CSMElement_csmXML_e_id` as CSMElement4_1_3_,
csmvalueco0_.`valid` as valid19_1_3_,
csmvalueco0_.`CSMCharacteristicValueConta_id` as CSMChar20_1_3_,
csmvalueco0_.`CSMValue_concreteValue_e_id` as CSMValue21_1_3_,
csmxml1_.e_id as e1_15_0_, csmxml1_.e_version as e3_15_0_,
csmvalue2_.e_id as e1_7_1_, csmvalue2_.e_version as e3_7_1_,
csmvalue2_.`CSMType_dataType_e_id` as CSMType4_7_1_,
csmvalue2_.econtainer_class as econtainer12_7_1_, csmvalue2_.e_container
as e13_7_1_, csmvalue2_.e_container_featureid as e14_7_1_,
csmvalue2_.`value` as value5_7_1_, csmvalue2_.`DTYPE` as DTYPE2_7_1_,
csmtype3_.e_id as e1_6_2_, csmtype3_.e_version as e3_6_2_,
csmtype3_.econtainer_class as econtainer4_6_2_, csmtype3_.e_container as
e5_6_2_, csmtype3_.e_container_featureid as e6_6_2_, csmtype3_.`DTYPE`
as DTYPE2_6_2_ from `CSMElement` csmvalueco0_ left outer join `CSMXML`
csmxml1_ on csmvalueco0_.`CSMElement_csmXML_e_id`=csmxml1_.e_id left
outer join `CSMValueSet` csmvalue2_ on
csmvalueco0_.`CSMValue_concreteValue_e_id`=csmvalue2_.e_id left outer
join `CSMType` csmtype3_ on
csmvalue2_.`CSMType_dataType_e_id`=csmtype3_.e_id where
csmvalueco0_.`CSMCharacteristicValueConta_id`=?
87520 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - preparing statement
87535 [main] DEBUG org.hibernate.type.LongType - binding '3' to
parameter: 1
87535 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to open
ResultSet (open ResultSets: 0, globally: 0)
87535 [main] DEBUG org.hibernate.loader.Loader - result set contains
(possibly empty) collection: [CSMInstance.csmValueContainer#3]
87535 [main] DEBUG org.hibernate.engine.CollectionLoadContext -
uninitialized collection: initializing
87535 [main] DEBUG org.hibernate.loader.Loader - processing result set
87551 [main] DEBUG org.hibernate.loader.Loader - result set row: 0
87551 [main] DEBUG org.hibernate.type.LongType - returning null as
column: e1_15_0_
column: e1_7_1_
column: e1_6_2_
87551 [main] DEBUG org.hibernate.type.LongType - returning '33' as
column: e1_1_3_
87551 [main] DEBUG org.hibernate.loader.Loader - result row: null,
null, null, EntityKey[CSMCharacteristicValueContainer#33]
87551 [main] DEBUG org.hibernate.loader.Loader - Initializing object
from ResultSet: [CSMCharacteristicValueContainer#33]
87551 [main] DEBUG
org.hibernate.persister.entity.AbstractEntityPersister - Hydrating
entity: [CSMCharacteristicValueContainer#33]
87551 [main] DEBUG org.hibernate.type.IntegerType - returning '0' as
column: e3_1_3_
column: CSMElement4_1_3_
87551 [main] DEBUG org.hibernate.type.BooleanType - returning 'true' as
column: valid19_1_3_
87551 [main] DEBUG org.hibernate.type.LongType - returning '3' as
column: CSMChar20_1_3_
column: CSMValue21_1_3_
87551 [main] DEBUG org.hibernate.engine.TwoPhaseLoad - Version: 0
column: CSMChar20_4_
87551 [main] DEBUG org.hibernate.loader.Loader - found row of
87551 [main] DEBUG org.hibernate.engine.CollectionLoadContext - reading row
column: e1_4_
87551 [main] DEBUG org.hibernate.event.def.DefaultLoadEventListener -
loading entity: [CSMCharacteristicValueContainer#33]
attempting to resolve: [CSMCharacteristicValueContainer#33]
resolved object in session cache: [CSMCharacteristicValueContainer#33]
87551 [main] DEBUG org.hibernate.type.IntegerType - returning '8' as
column: CSMINST28_4_
87551 [main] DEBUG org.hibernate.loader.Loader - done processing result
set (1 rows)
87551 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to close
ResultSet (open ResultSets: 1, globally: 1)
PreparedStatement (open PreparedStatements: 1, globally: 1)
87551 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - closing statement
87551 [main] DEBUG org.hibernate.loader.Loader - total objects hydrated: 1
87551 [main] DEBUG org.hibernate.engine.TwoPhaseLoad - resolving
associations for [CSMCharacteristicValueContainer#33]
creating collection wrapper:[CSMElement.referencedElements#33]
loading entity: [CSMInstance#3]
attempting to resolve: [CSMInstance#3]
resolved object in session cache: [CSMInstance#3]
creating collection wrapper:[CSMCharacteristicValueContainer.valueSet#33]
loading entity: [CSMCharacteristicDefinition#3]
attempting to resolve: [CSMCharacteristicDefinition#3]
resolved object in session cache: [CSMCharacteristicDefinition#3]
87551 [main] DEBUG org.hibernate.transaction.JDBCTransaction - rollback
87551 [main] DEBUG org.hibernate.transaction.JDBCTransaction - rolled
back JDBC Connection
87551 [main] DEBUG org.hibernate.jdbc.JDBCContext - after transaction
completion
87551 [main] DEBUG org.hibernate.jdbc.ConnectionManager - aggressively
releasing JDBC connection
87551 [main] DEBUG org.hibernate.jdbc.ConnectionManager - releasing
JDBC connection [ (open PreparedStatements: 0, globally: 0) (open
ResultSets: 0, globally: 0)]
87551 [main] DEBUG
org.hibernate.connection.DriverManagerConnectionProvider - returning
connection to pool, pool size: 1
87551 [main] DEBUG org.hibernate.impl.SessionImpl - after transaction
completion
87551 [main] ERROR org.hibernate.LazyInitializationException - illegal
access to loading collection
org.hibernate.LazyInitializationException: illegal access to loading
collection
at
org.hibernate.collection.AbstractPersistentCollection.initia lize(AbstractPersistentCollection.java:341)
at
org.hibernate.collection.AbstractPersistentCollection.read(A bstractPersistentCollection.java:86)
at
org.hibernate.collection.AbstractPersistentCollection.readSi ze(AbstractPersistentCollection.java:109)
at org.hibernate.collection.PersistentList.size(PersistentList. java:91)
at
org.eclipse.emf.common.util.DelegatingEList.delegateSize(Del egatingEList.java:223)
at
org.eclipse.emf.teneo.mapping.elist.PersistableEList.delegat eSize(PersistableEList.java:415)
at
org.eclipse.emf.common.util.DelegatingEList.size(DelegatingE List.java:214)
at
org.eclipse.emf.common.util.DelegatingEList$EIterator.hasNex t(DelegatingEList.java:1000)
at
de.arcsolutions.remarc.platform.datacore.impl.CSMInstanceImp l.getCSMCharacteristicValueContainer(CSMInstanceImpl.java:20 9)
at
de.arcsolutions.remarc.platform.ui.tableeditor.ktable.Mappin gKTableModel.getCSMCharacteristicValueContainer(MappingKTabl eModel.java:201)
at
de.arcsolutions.remarc.platform.ui.tableeditor.ktable.Mappin gKTableModel.doGetContentAt(MappingKTableModel.java:136)
at
de.arcsolutions.remarc.platform.ui.tableeditor.ktable.Mappin gKTableSortedModel.doGetContentAt(MappingKTableSortedModel.j ava:90)
at
de.kupzog.ktable.KTableSortedModel.getContentAt(KTableSorted Model.java:171)
at
de.arcsolutions.remarc.platform.ui.tableeditor.ktable.Mappin gKTableSortedModel.getContentAt(MappingKTableSortedModel.jav a:258)
at de.kupzog.ktable.KTable.drawCell(KTable.java:1171)
at de.kupzog.ktable.KTable.drawCells(KTable.java:1088)
at de.kupzog.ktable.KTable.onPaint(KTable.java:776)
at de.kupzog.ktable.KTable$3.paintControl(KTable.java:267)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:83)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:12 85)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3299 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4025 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:19 32)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2966)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
at
de.arcsolutions.remarc.rcp.application.PlatformRunnable.run( PlatformRunnable.java:71)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Please help!
arc solutions GmbH
Sandro Weiser
www.arcsolutions.de
Handelsregister
Re: Name mapping [message #74863 is a reply to message #74828] Sun, 11 March 2007 12:08 Go to previous messageGo to next message
Yes use the Table annotation.
gr. Martin
> for example:
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Name mapping [message #74878 is a reply to message #74846] Sun, 11 March 2007 12:18 Go to previous messageGo to next message
Can you step through the code in the PersistableEList.delegateSize method? There is a load() call
there this should have loaded the hibernate collection but apparently did not do that.
gr. Martin
> Cause:
> connection
> 87504 [main] DEBUG
> 87504 [main] DEBUG
> begin
> 87520 [main] DEBUG
> 87520 [main] DEBUG
> 87520 [main] DEBUG
> statement
> parameter: 1
> column: e1_15_0_
> column: e1_7_1_
> column: e1_6_2_
> column: e1_1_3_
> 87551 [main] DEBUG
> column: e3_1_3_
> row
> column: e1_4_
> set (1 rows)
> completion
> 87551 [main] DEBUG
> completion
> collection
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Please help!
The Netherlands
Re: Name mapping [message #74892 is a reply to message #74863] Sun, 11 March 2007 12:19 Go to previous messageGo to next message
grrrr, already tried
using @Table(Name="CSMCVC") produces a table with the name CSMCVC but
the exception doesn't go away
but renaming the Class to CSMCVC makes the exception go away
so what's the difference?
Is it possible to include table names >
PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH in an unique renaming
mapping/the PersistenceOptions.JOIN_TABLE_NAMING_STRATEGY, "unique"
(PersistenceOptions.SHORTENED_SQL_NAMING_STRATEGY, "unique"??)?
Sandro
arc solutions GmbH
Sandro Weiser
www.arcsolutions.de
Handelsregister
Re: Name mapping [message #74932 is a reply to message #74892] Sun, 11 March 2007 13:07 Go to previous message
You mean that after renaming the class to CSMCVC all exceptions disappeared and your application
worked as it should be (no issues related to loading elements of CSMCharacteristicValueContainer)?
Afaics the exception you showed in this last post is not related to the table name.
The table name length issue can be related to the other error you mentioned that Elements in
CSMCharacteristicValueContainer were not found.
Related to maximum_sql_name_length/unique. You can also set your own class to do name handling. To
do this you need to set the persistenceoption: PersistenceOptions.SQL_CASE_STRATEGY to the name of a
class which implements org.eclipse.emf.teneo.util.SQLCaseStrategy. It will get the tablename after
doing the unique/maximum table name length thing.
Are all exceptions/strange behaviors in previous posts solved (if not which are still open)?
gr. Martin
> Sandro
The Netherlands
Re: Name mapping [message #603420 is a reply to message #74828] Sun, 11 March 2007 09:03 Go to previous message
Cause:
connection
87504 [main] DEBUG
87504 [main] DEBUG
87520 [main] DEBUG
87520 [main] DEBUG
87520 [main] DEBUG
parameter: 1
column: e1_15_0_
column: e1_7_1_
column: e1_6_2_
column: e1_1_3_
87551 [main] DEBUG
column: e3_1_3_
column: e1_4_
set (1 rows)
completion
87551 [main] DEBUG
completion
collection
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Please help!
arc solutions GmbH
Sandro Weiser
www.arcsolutions.de
Handelsregister
Re: Name mapping [message #603424 is a reply to message #74828] Sun, 11 March 2007 12:08 Go to previous message
gr. Martin
> for example:
The Netherlands
Re: Name mapping [message #603428 is a reply to message #74846] Sun, 11 March 2007 12:18 Go to previous message
gr. Martin
> Cause:
> connection
> 87504 [main] DEBUG
> 87504 [main] DEBUG
> begin
> 87520 [main] DEBUG
> 87520 [main] DEBUG
> 87520 [main] DEBUG
> statement
> parameter: 1
> column: e1_15_0_
> column: e1_7_1_
> column: e1_6_2_
> column: e1_1_3_
> 87551 [main] DEBUG
> column: e3_1_3_
> row
> column: e1_4_
> set (1 rows)
> completion
> 87551 [main] DEBUG
> completion
> collection
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Please help!
The Netherlands
Re: Name mapping [message #603434 is a reply to message #74863] Sun, 11 March 2007 12:19 Go to previous message
Sandro
arc solutions GmbH
Sandro Weiser
www.arcsolutions.de
Handelsregister
Re: Name mapping [message #603447 is a reply to message #74892] Sun, 11 March 2007 13:07 Go to previous message
gr. Martin
> Sandro
The Netherlands
Previous Topic:Name mapping
Next Topic:EMaps and the missing @MapKey annotation
Current Time: Sun Jul 27 11:30:07 EDT 2025
Powered by FUDForum. Page generated in 0.04578 seconds
