Home » Archived » BIRT » Generate given HTML once per report page in a custom report item
Generate given HTML once per report page in a custom report item [message #747890] Mon, 24 October 2011 06:44 Go to next message
My report items need certain JavaScript to be present on the page. Without modifying the viewer's JSP files the only way to do it seems to be to create <script> tags in onRowSets(IBaseResultSet[]). However, it would be inefficient to generate the same script for every instance of the item. Is there a better way to ensure it's only generated once per page than using context.get/setPageVariable?
Re: Generate given HTML once per report page in a custom report item [message #748336 is a reply to message #747890] Mon, 24 October 2011 12:37 Go to previous message
Alexey,
If you add a text element to the top of a report and use a src tag for
it like:
<script type="text/javascript"
src="http://localhost:8090/WebViewer/myjsfile.js"></script>
The script tag should automatically get moved to the HEAD tag of the
viewer and be available on all pages of a report. It only does this for
script tags that use the src tag.
Jason
Previous Topic:horizontal printing in BIRT
Next Topic:Happy to develop birt successfully, but no idea to deploy
Current Time: Fri Jul 25 09:51:09 EDT 2025
Powered by FUDForum. Page generated in 0.06406 seconds
