Home » Archived » Test and Performance Tools Platform (TPTP) » Integrated Agent Controller not enabled?
Integrated Agent Controller not enabled? [message #74567] |
Sat, 17 June 2006 12:41  |
Originally posted by: eclipse.nitwit.de
Hi!
I'm a TPTP (4.1, callisto) noob and spend an hour trying to get the Profiler
to work with a simple local application.
1) IAC seems to be disabled. In Preferences the enable checkbox (and
everything else on the page) is not clickable.
2) In the Profile As dialog I don't have a Profile tab but a Monitor tab.
3) Preferences > Profiling and Loggin > Hosts: Local Direct Connection and
localhost:10002 show up. When I test the connection the latter one I get the
same error message I get when I try actually profile: IWAT0284E: The agent
controller is not available on host localhost.
When I try to connect to Local Direct Connection a message popups up that a
remote agent controller (RAC) is already running. Well, this and 1) would
explain the problem somehow but how do I fix it? I didn't start any remote
agent controller...
Thanks a lot!
Timo
Re: Integrated Agent Controller not enabled? [message #74624 is a reply to message #74606] |
Sun, 18 June 2006 14:58   |
Timo Nentwig wrote:
> Randy D. Smith wrote:
>>Perhaps everything revolves around the "(4.1, callisto)" part. Callisto
>>is a simulataneous release of several products due out the end of this
>>month. As such it incorporates Eclipse 3.2 and TPTP *4.2*. 4.1 is to be
>>used with Eclipse 3.1, with Callisto having nothing to do with those
>>older (actual releases). Callisto is still in development... though if
>>you get "Callisto" (an Eclipse 3.2RC7 platform and everything else you
>>want from its update site, *including* TPTP [4.2]) it certainly should
>>be working for you now... and if it's not we want to know about is ASAP!
> Well, I downloaded eclipse SDK 3.2rc7 and installed TPTP 4.2 via Callisto's
> update site but everything remeins unaffected. I'm esp. wondering why the
> IAC page in Preferences is disabled...
In trying to help a similar problem in an earlier thread (the "[Newbie]
Help starting the Java profiler" thread) I downloaded Eclipse 3.2RC7
Platform Runtime and Platform SDKs and started fresh from each
separately. I then went to Help => Software Updates => Find and
Install... (after setting my proxy settings in my environment) => Search
for new features to install => Callisto Discovery Site, selected just
the TPTP feature, then hit the "Select Required" after I got a red X box
saying I didn't have some dependencies... that resolved the
dependencies, and I did the OK on the license acceptance, all the
downloading, then the Install All when it got to the Certificate issue.
After installing, I allowed it to restart the workbench.
I belabor this to make sure we're on the same page.
I had a brief thought that it (the fact that after this it all works for
me, but not for y'all) might have to do with me working with existing,
established projects... so I went back to the default "empty"
workspace... but all was still well. IAC was enabled, Profiling and
Logging perspective was available.
So... what's different between your environment and mine? One
possibility is JVM... I'm using Sun's 1.5.0_06... what's your JVM??
Another possible area of difference, given we're dealing with the IAC,
is your firewalling/port situation... You've got nothing blocking port
10002 do you? Is any firewalling on at the local system? We are dealing
with Windows XP here, right?
As I recall the explanation of what happens between the IAC and the RAC
in determining who gets to run, besides port 10002 there is a named
pipe... but I'll have to go look at the e-mail from Samson to remind me
(1) what the named pipe is being used, and (2) what the open source
package was he recommended to me for seeing what my Windows system was
doing with resources such as named pipes.
I'll get back to you on that shortly.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: Integrated Agent Controller not enabled? [message #74730 is a reply to message #74678] |
Mon, 19 June 2006 15:42   |
> same version
> No firewall.
> Nope, linux (gentoo).
Ooops, that's what I get for assuming.
I'm trying it on Linux now... I'll see what I can see. Meanwhile,
reading back through the thread, I'm changing my approach a little... I
take it from the "I downloaded eclipse SDK 3.2rc7" part that you
downloaded neither the Platform nor the Platform SDK but the actual top
link for Linux on the 3.2RC7 download page... that being the "Eclipse
SDK" (Platform SDK with the JDT and PDE and source and doc and etc.
etc.). Should not affect the Update Manager's handling of the
TPTP&dependencies, but we'll see.
Okay, as I did this I ran into a few questions... depending on the
resolution of those we may end up with the fact that we don't test
against gentoo. I'm not sure what our "officially supported Linux" list
is, but I know it has RedHat on it, and that the openSUSE 10 I use isn't
on it (last I looked). But it works for me on SUSE... But we can't cover
every Linux.
As for the questions: When you get the list from the Callisto Discovery
site, do you expand TPTP and select just some of them? Or did you click
the top-level TPTP one? I selected the top level one, so that when I did
a "Select Required" I think it said I needed 22 of 34. If I'd expanded
and taken just the four main projects, I think my dependency list would
have been smaller... but again, I'm just wanting to test just what you did.
You mentioned originally that "I didn't start any remote agent
controller..." ... Has the RAC been downloaded onto this system? Has one
ever been run?? If yes to either of these, we need to go look at the
/tmp/IBMRAC directory to see if any named pipes were left lingering that
make the IAC *think* the RAC is there. Maybe go check if that directory
exists and if anything is lingering there even if you didn't download a RAC.
Well, I tried it on my openSUSE box cleanly from the "Eclipse SDK"
download for 3.2RC7 (all 100+ MB of it), and my preferences window had
the IAC enabled when I looked at it. I can't do the "Test Local Direct
Connection" you do as I *do* have an agent controller already running...
I've left LinuxAgent running Perfmon on my Linux system for ~10 days up
til now, and I'd really like to keep it running to see how long it stays
up, so I won't be "RAC-less" for a while yet I expect.
RDS
Re: Integrated Agent Controller not enabled? [message #74833 is a reply to message #74730] |
Wed, 21 June 2006 13:57   |
Yes. This time. Last time I started with the pure platform (and had no start
up script or splash screen).
> every Linux.
Well, at least the kernel is the same across all distros :) I can't think
in which way a distro should be affecting eclipse or java at all.
> did.
Yes, I did the same.
Well, I didn't even know that I can download a RAC separately :) So, I think
the answer here is probably no.
> RAC.
No such directory in /tmp
I *can't* do the "Test Local Direct Connection" thing either because an RAC
is supposedly already running.
Maybe this will help:
/usr/local/java/eclipse-3.2rc7/plugins $ ls -1
com.ibm.etools.emf.event_3.0.0.v20060518_RC1.jar
com.ibm.icu.source_3.4.4.1
com.ibm.icu_3.4.4.1.jar
com.jcraft.jsch_0.1.28.jar
com.lowagie.itext_1.3.0.N20060531-1258
org.apache.ant_1.6.5
org.apache.axis_1.3.0.v200605232140
org.apache.cactus_1.7.2.v200605092015
org.apache.commons.codec_1.3.0.N20060531-1258
org.apache.commons_logging_1.0.4.v200605300431
org.apache.jakarta_log4j_1.2.8.v200605300321
org.apache.lucene_1.4.103.v20060601
org.apache.wsil4j_1.0.0.v200603092046
org.apache.xerces_2.8.0.v200605280700
org.eclipse.ant.core_3.1.100.v20060531.jar
org.eclipse.ant.ui_3.2.0.v20060531.jar
org.eclipse.birt.chart.cshelp_2.1.0.N20060531-1258
org.eclipse.birt.chart.device.extension_2.1.0.N20060531-1258 .jar
org.eclipse.birt.chart.device.pdf_2.1.0.N20060531-1258.jar
org.eclipse.birt.chart.device.svg_2.1.0.N20060531-1258.jar
org.eclipse.birt.chart.device.swt_2.1.0.N20060531-1258.jar
org.eclipse.birt.chart.engine.extension_2.1.0.N20060531-1258 .jar
org.eclipse.birt.chart.engine_2.1.0.N20060531-1258.jar
org.eclipse.birt.chart.examples_2.1.0.N20060531-1258.jar
org.eclipse.birt.chart.reportitem.ui_2.1.0.N20060531-1258.ja r
org.eclipse.birt.chart.reportitem_2.1.0.N20060531-1258.jar
org.eclipse.birt.chart.runtime_2.1.0.N20060531-1258
org.eclipse.birt.chart.ui.extension_2.1.0.N20060531-1258.jar
org.eclipse.birt.chart.ui_2.1.0.N20060531-1258.jar
org.eclipse.birt.chart_2.1.0.N20060531-1258
org.eclipse.birt.core.ui_2.1.0.N20060531-1258.jar
org.eclipse.birt.core_2.1.0.N20060531-1258.jar
org.eclipse.birt.cshelp_2.1.0.N20060531-1258
org.eclipse.birt.data.oda.adapter.dtp_2.0.0.N20060531-1258.j ar
org.eclipse.birt.data.oda_2.0.2.N20060531-1258
org.eclipse.birt.data_2.1.0.N20060531-1258.jar
org.eclipse.birt.example_2.1.0.N20060531-1258
org.eclipse.birt.report.data.adapter_2.1.0.N20060531-1258.ja r
org.eclipse.birt.report.data.oda.jdbc.ui_2.1.0.N20060531-125 8.jar
org.eclipse.birt.report.data.oda.jdbc_2.1.0.N20060531-1258
org.eclipse.birt.report.data.oda.sampledb.ui_2.1.0.N20060531 -1258.jar
org.eclipse.birt.report.data.oda.sampledb_2.1.0.N20060531-12 58
org.eclipse.birt.report.data.oda.xml.ui_2.1.0.N20060531-1258 .jar
org.eclipse.birt.report.data.oda.xml_2.1.0.N20060531-1258.ja r
org.eclipse.birt.report.debug.ui_2.1.0.N20060531-1258.jar
org.eclipse.birt.report.designer.core_2.1.0.N20060531-1258.j ar
org.eclipse.birt.report.designer.example.samplereport_2.1.0. N20060531-1258.jar
org.eclipse.birt.report.designer.ui.editors.schematic_2.1.0. N20060531-1258.jar
org.eclipse.birt.report.designer.ui.editors_2.1.0.N20060531- 1258.jar
org.eclipse.birt.report.designer.ui.ide_2.1.0.N20060531-1258 .jar
org.eclipse.birt.report.designer.ui.lib.explorer_2.1.0.N2006 0531-1258.jar
org.eclipse.birt.report.designer.ui.lib_2.1.0.N20060531-1258 .jar
org.eclipse.birt.report.designer.ui.preview_2.1.0.N20060531- 1258.jar
org.eclipse.birt.report.designer.ui_2.1.0.N20060531-1258
org.eclipse.birt.report.designer_2.1.0.N20060531-1258
org.eclipse.birt.report.engine.emitter.html_2.1.0.N20060531- 1258.jar
org.eclipse.birt.report.engine.emitter.pdf_2.1.0.N20060531-1 258.jar
org.eclipse.birt.report.engine.fonts_2.1.0.N20060531-1258
org.eclipse.birt.report.engine_2.1.0.N20060531-1258.jar
org.eclipse.birt.report.model.adapter.oda_2.1.0.N20060531-12 58.jar
org.eclipse.birt.report.model_2.1.0.N20060531-1258.jar
org.eclipse.birt.report.runtime_2.1.0.N20060531-1258
org.eclipse.birt.report.viewer_2.1.0.N20060531-1258
org.eclipse.birt_2.1.0.N20060531-1258
org.eclipse.compare_3.2.0.v20060525.jar
org.eclipse.core.boot_3.1.100.v20060601a.jar
org.eclipse.core.commands_3.2.0.I20060511-0800a.jar
org.eclipse.core.contenttype_3.2.0.v20060601a.jar
org.eclipse.core.expressions_3.2.0.v20060602-0010.jar
org.eclipse.core.filebuffers_3.2.0.v20060602-0010.jar
org.eclipse.core.filesystem.linux.x86_64_1.0.0.v20060601a.ja r
org.eclipse.core.filesystem_1.0.0.v20060601a.jar
org.eclipse.core.jobs_3.2.0.v20060601a.jar
org.eclipse.core.resources.compatibility_3.2.0.v20060601a.ja r
org.eclipse.core.resources_3.2.0.v20060601a.jar
org.eclipse.core.runtime.compatibility.auth_3.2.0.v20060601. jar
org.eclipse.core.runtime.compatibility.registry_3.2.0.v20060 602
org.eclipse.core.runtime.compatibility_3.1.100.v20060601a.ja r
org.eclipse.core.runtime_3.2.0.v20060601b.jar
org.eclipse.core.variables_3.1.100.v20060517.jar
org.eclipse.datatools.connectivity.db.derby_0.9.0.200605121. jar
org.eclipse.datatools.connectivity.db.generic.ui_0.9.0.20060 5101
org.eclipse.datatools.connectivity.db.generic_0.9.0.20060523 1
org.eclipse.datatools.connectivity.dbdefinition.derby_0.9.0. 200605101
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC_ 0.9.0.200605101
org.eclipse.datatools.connectivity.derby.ui_0.9.0.200605101. jar
org.eclipse.datatools.connectivity.derby_0.9.0.200605101.jar
org.eclipse.datatools.connectivity.finfo_0.9.0.200605291.jar
org.eclipse.datatools.connectivity.oda.consumer_3.0.1.200605 231.jar
org.eclipse.datatools.connectivity.oda.design.ui_3.0.1.20060 5231.jar
org.eclipse.datatools.connectivity.oda.design_3.0.0.20060523 1.jar
org.eclipse.datatools.connectivity.oda.designer.finfo_0.9.0. 200605291.jar
org.eclipse.datatools.connectivity.oda.finfo_0.9.0.200605291 .jar
org.eclipse.datatools.connectivity.oda.flatfile.ui_3.0.0.200 605101.jar
org.eclipse.datatools.connectivity.oda.flatfile_3.0.0.200605 241.jar
org.eclipse.datatools.connectivity.oda.profile_3.0.0.2006051 01.jar
org.eclipse.datatools.connectivity.oda_3.0.1.200605251.jar
org.eclipse.datatools.connectivity.sqm.core.ui_0.9.0.2006051 01
org.eclipse.datatools.connectivity.sqm.core_0.9.0.200605121. jar
org.eclipse.datatools.connectivity.sqm.server.ui_0.9.0.20060 5101
org.eclipse.datatools.connectivity.ui.dse_0.9.0.200605121
org.eclipse.datatools.connectivity.ui_0.9.0.200605101
org.eclipse.datatools.connectivity_0.9.0.200605121
org.eclipse.datatools.modelbase.dbdefinition_0.9.0.200605101
org.eclipse.datatools.modelbase.derby_0.9.0.200605101.jar
org.eclipse.datatools.modelbase.edit_0.9.0.200605101
org.eclipse.datatools.modelbase.finfo_0.9.0.200605291.jar
org.eclipse.datatools.modelbase.sql.query_0.9.0.200605101
org.eclipse.datatools.modelbase.sql.xml.query_0.9.0.20060510 1
org.eclipse.datatools.modelbase.sql_0.9.0.200605101
org.eclipse.debug.core_3.2.0.v20060601.jar
org.eclipse.debug.ui_3.2.0.v20060601.jar
org.eclipse.draw2d_3.2.0.v20060529.jar
org.eclipse.emf.ant_2.2.0.v200605300949.jar
org.eclipse.emf.codegen.ecore.ui_2.2.0.v200605300949.jar
org.eclipse.emf.codegen.ecore_2.2.0.v200605300949.jar
org.eclipse.emf.codegen.ui_2.1.0.v200605300949.jar
org.eclipse.emf.codegen_2.2.0.v200605300949.jar
org.eclipse.emf.common.ui_2.2.0.v200605300949.jar
org.eclipse.emf.common_2.2.0.v200605300949.jar
org.eclipse.emf.commonj.sdo_2.1.0.v200605300949.jar
org.eclipse.emf.converter_2.2.0.v200605300949.jar
org.eclipse.emf.ecore.change.edit_2.1.0.v200605300949.jar
org.eclipse.emf.ecore.change_2.2.0.v200605300949.jar
org.eclipse.emf.ecore.edit_2.2.0.v200605300949.jar
org.eclipse.emf.ecore.editor_2.2.0.v200605300949.jar
org.eclipse.emf.ecore.sdo.edit_2.1.0.v200605300949.jar
org.eclipse.emf.ecore.sdo.editor_2.1.0.v200605300949.jar
org.eclipse.emf.ecore.sdo_2.2.0.v200605300949.jar
org.eclipse.emf.ecore.xmi_2.2.0.v200605300949.jar
org.eclipse.emf.ecore_2.2.0.v200605300949.jar
org.eclipse.emf.edit.ui_2.2.0.v200605300949.jar
org.eclipse.emf.edit_2.2.0.v200605300949.jar
org.eclipse.emf.exporter_2.2.0.v200605300949.jar
org.eclipse.emf.importer.ecore_2.2.0.v200605300949.jar
org.eclipse.emf.importer.java_2.2.0.v200605300949.jar
org.eclipse.emf.importer.rose_2.2.0.v200605300949.jar
org.eclipse.emf.importer_2.2.0.v200605300949.jar
org.eclipse.emf.mapping.ecore2ecore.editor_2.2.0.v2006053009 49.jar
org.eclipse.emf.mapping.ecore2ecore_2.2.0.v200605300949.jar
org.eclipse.emf.mapping.ecore2xml.ui_2.2.0.v200605300949.jar
org.eclipse.emf.mapping.ecore2xml_2.2.0.v200605300949.jar
org.eclipse.emf.mapping.ui_2.2.0.v200605300949.jar
org.eclipse.emf.mapping.xsd2ecore.editor_2.1.0.v200605300949 .jar
org.eclipse.emf.mapping.xsd2ecore_2.1.0.v200605300949.jar
org.eclipse.emf.mapping_2.2.0.v200605300949.jar
org.eclipse.emf_2.2.0.v200605300949.jar
org.eclipse.equinox.common_3.2.0.v20060601a.jar
org.eclipse.equinox.preferences_3.2.0.v20060601.jar
org.eclipse.equinox.registry_3.2.0.v20060601.jar
org.eclipse.equinox.servlet.api_1.0.0.v20060510.jar
org.eclipse.gef_3.2.0.v20060529.jar
org.eclipse.help.appserver_3.1.100.v20060510b.jar
org.eclipse.help.base_3.2.0.v20060601.jar
org.eclipse.help.ui_3.2.0.v20060510b.jar
org.eclipse.help.webapp_3.2.0.v20060510b
org.eclipse.help_3.2.0.v20060518.jar
org.eclipse.hyades.analysis.engine_4.2.0.v200605251528
org.eclipse.hyades.execution.correlation_4.1.100.v2006052515 28.jar
org.eclipse.hyades.execution.trace_4.1.100.v200605251528.jar
org.eclipse.hyades.execution_4.2.0.v200605251528
org.eclipse.hyades.logging.adapter.ui_4.2.0.v200605251528.ja r
org.eclipse.hyades.logging.adapter_4.2.0.v200605251528
org.eclipse.hyades.logging.core.sample_4.1.100.v200605251528
org.eclipse.hyades.logging.core_4.2.0.v200605251528
org.eclipse.hyades.logging.parsers_4.2.0.v200605251528
org.eclipse.hyades.perfmon_4.2.0.v200605251528
org.eclipse.hyades.probekit.doc.user_4.1.100.v200605251528.j ar
org.eclipse.hyades.probekit.ui_4.1.100.v200605251528.jar
org.eclipse.hyades.probekit_4.2.0.v200605251528
org.eclipse.hyades.resources.database_4.1.100.v200605251528
org.eclipse.hyades.sdb_4.1.100.v200605251528
org.eclipse.hyades.statistical.ui_4.2.0.v200605251528
org.eclipse.hyades.test.core_4.2.0.v200605251528
org.eclipse.hyades.test.doc.user_4.1.100.v200605251528.jar
org.eclipse.hyades.test.tools.core_4.2.0.v200605251528
org.eclipse.hyades.test.tools.ui_4.2.0.v200605251528.jar
org.eclipse.hyades.test.ui.extensions_4.2.0.v200605251528.ja r
org.eclipse.hyades.test.ui_4.2.0.v200605251528.jar
org.eclipse.hyades.trace.sample_4.1.100.v200605251528.jar
org.eclipse.hyades.trace.ui_4.2.0.v200605251528.jar
org.eclipse.hyades.trace.views_4.1.100.v200605251528.jar
org.eclipse.hyades.ui_4.1.100.v200605251528.jar
org.eclipse.jdt.apt.core_3.2.0.v20060601-2020.jar
org.eclipse.jdt.apt.ui_3.2.0.v20060601-2020.jar
org.eclipse.jdt.core.manipulation_1.0.0.v20060602-0010.jar
org.eclipse.jdt.core_3.2.0.v_670.jar
org.eclipse.jdt.debug.ui_3.2.0.v20060517.jar
org.eclipse.jdt.debug_3.2.0.v20060601
org.eclipse.jdt.doc.isv_3.2.0.v20060602-1130.jar
org.eclipse.jdt.doc.user_3.2.0.v20060602-1130.jar
org.eclipse.jdt.junit.runtime_3.2.0.v20060602-0010
org.eclipse.jdt.junit4.runtime_1.0.0.v20060602-0010.jar
org.eclipse.jdt.junit_3.2.0.v20060602-0010
org.eclipse.jdt.launching_3.2.0.v20060525.jar
org.eclipse.jdt.source_3.2.0.v20060602-0010-F7snq0fulF-UQcP
org.eclipse.jdt.ui_3.2.0.v20060602-0010.jar
org.eclipse.jdt_3.2.0.v20060602-0010.jar
org.eclipse.jem.beaninfo_1.2.0.v20060530_RC2.jar
org.eclipse.jem.proxy_1.2.0.v20060530_RC2.jar
org.eclipse.jem.ui_1.2.0.v20060518_RC1.jar
org.eclipse.jem.util_1.2.0.v20060530_RC2.jar
org.eclipse.jem.workbench_1.2.0.v20060530_RC2.jar
org.eclipse.jem_1.2.0.v20060530_RC2.jar
org.eclipse.jface.databinding_1.0.0.I20060511-2000.jar
org.eclipse.jface.text_3.2.0.v20060602-0010.jar
org.eclipse.jface_3.2.0.I20060602-0010.jar
org.eclipse.jst.common.annotations.controller_1.0.0.v2006051 81622.jar
org.eclipse.jst.common.annotations.core_1.0.0.v200605270041. jar
org.eclipse.jst.common.annotations.ui_1.0.0.v200605181622.ja r
org.eclipse.jst.common.frameworks_1.0.0.v200605241644.jar
org.eclipse.jst.common.project.facet.core_1.0.0.v20060518162 2.jar
org.eclipse.jst.ejb.doc.user_1.0.201.v200605291441.jar
org.eclipse.jst.ejb.ui_1.0.0.v200605261351.jar
org.eclipse.jst.j2ee.core_1.0.0.v200605250119.jar
org.eclipse.jst.j2ee.doc.user_1.0.201.v200605152316.jar
org.eclipse.jst.j2ee.ejb.annotation.model_1.0.0.v20060528204 3.jar
org.eclipse.jst.j2ee.ejb.annotations.emitter_1.0.0.v20060525 0119.jar
org.eclipse.jst.j2ee.ejb.annotations.ui_1.0.0.v200605291137. jar
org.eclipse.jst.j2ee.ejb.annotations.xdoclet_1.0.0.v20060530 1759.jar
org.eclipse.jst.j2ee.ejb_1.0.0.v200605262006.jar
org.eclipse.jst.j2ee.infopop_1.0.201.v200605040115.jar
org.eclipse.jst.j2ee.jca.ui_1.0.0.v200605181622.jar
org.eclipse.jst.j2ee.jca_1.0.0.v200605261351.jar
org.eclipse.jst.j2ee.navigator.ui_1.0.0.v200605262006.jar
org.eclipse.jst.j2ee.ui_1.0.0.v200605262006.jar
org.eclipse.jst.j2ee.web_1.0.0.v200605261351.jar
org.eclipse.jst.j2ee.webservice.ui_1.0.0.v200605181622.jar
org.eclipse.jst.j2ee.webservice_1.0.0.v200605250119.jar
org.eclipse.jst.j2ee.xdoclet.runtime_1.0.0.v200605250119.jar
org.eclipse.jst.j2ee_1.0.0.v200605262006.jar
org.eclipse.jst.jsp.core_1.1.0.v200605280700.jar
org.eclipse.jst.jsp.ui.infopop_1.0.2.v200605040115.jar
org.eclipse.jst.jsp.ui_1.1.0.v200605301759.jar
org.eclipse.jst.server.core_1.0.102.v20060530.jar
org.eclipse.jst.server.generic.core_1.0.100.v20060530.jar
org.eclipse.jst.server.generic.jboss_1.5.0.v20060530
org.eclipse.jst.server.generic.jonas_1.5.0.v20060530
org.eclipse.jst.server.generic.oc4j_1.5.0.v20060530
org.eclipse.jst.server.generic.ui_1.0.100.v20060516d.jar
org.eclipse.jst.server.generic.weblogic_1.5.0.v20060530
org.eclipse.jst.server.installable_1.5.0.v20060511.jar
org.eclipse.jst.server.tomcat.core_1.0.102.v20060530.jar
org.eclipse.jst.server.tomcat.ui_1.0.102.v20060530.jar
org.eclipse.jst.server.ui.doc.user_1.0.1.v200605040115.jar
org.eclipse.jst.server.ui.infopop_1.0.2.v200605040115.jar
org.eclipse.jst.server.ui_1.0.102.v20060530.jar
org.eclipse.jst.server.websphere.core_1.0.100.v20060530
org.eclipse.jst.servlet.ui.infopop_1.0.201.v200605040115.jar
org.eclipse.jst.servlet.ui_1.0.0.v200605262006.jar
org.eclipse.jst.ws.axis.consumption.core_1.0.101.v2006051804 32.jar
org.eclipse.jst.ws.axis.consumption.ui_1.0.101.v200605242132 .jar
org.eclipse.jst.ws.axis.creation.ui_1.0.101.v200605250307.ja r
org.eclipse.jst.ws.axis.infopop_1.0.201.v200605152241.jar
org.eclipse.jst.ws.axis.ui.doc.user_1.0.201.v200605111705.ja r
org.eclipse.jst.ws.consumption.infopop_1.0.201.v200605152241 .jar
org.eclipse.jst.ws.consumption.ui.doc.user_1.0.201.v20060511 1705.jar
org.eclipse.jst.ws.consumption.ui_1.0.101.v200605301759.jar
org.eclipse.jst.ws.consumption_1.0.101.v200605250307
org.eclipse.jst.ws.creation.ejb.ui_1.0.0.v200605040224.jar
org.eclipse.jst.ws.creation.ui_1.0.101.v200605301759.jar
org.eclipse.jst.ws.doc.user_1.0.201.v200605111641.jar
org.eclipse.jst.ws.infopop_1.0.201.v200605162034.jar
org.eclipse.jst.ws.uddiregistry_1.0.100.v200605180400.jar
org.eclipse.jst.ws.ui_1.0.100.v200605180400.jar
org.eclipse.jst.ws_1.0.101.v200605292143.jar
org.eclipse.jst_1.0.1.v200605040115.jar
org.eclipse.ltk.core.refactoring_3.2.0.v20060602-0010.jar
org.eclipse.ltk.ui.refactoring_3.2.0.v20060602-0010.jar
org.eclipse.osgi.services_3.1.100.v20060601.jar
org.eclipse.osgi.util_3.1.100.v20060601.jar
org.eclipse.osgi_3.2.0.v20060601.jar
org.eclipse.pde.build_3.2.0.v20060601
org.eclipse.pde.core_3.2.0.v20060601b.jar
org.eclipse.pde.doc.user_3.2.0.v20060602-1300.jar
org.eclipse.pde.junit.runtime_3.2.0.v20060511-0800.jar
org.eclipse.pde.runtime_3.2.0.v20060511-0800.jar
org.eclipse.pde.source_3.2.0.v20060602-0010-6zXJJzJvOWpFYED
org.eclipse.pde.ui_3.2.0.v20060526-0010.jar
org.eclipse.pde_3.2.0.v20060511-1200.jar
org.eclipse.platform.doc.isv_3.2.0.v20060602-1302.jar
org.eclipse.platform.doc.user_3.2.0.v20060602-1302.jar
org.eclipse.platform.source.linux.gtk.x86_64_3.2.0.v20060602 -0010-_OZ2h-8eOaU1uKq
org.eclipse.platform.source_3.2.0.v20060602-0010-_OZ2h-8eOaU 1uKq
org.eclipse.platform_3.2.0.v20060601
org.eclipse.rcp.source.linux.gtk.x86_64_3.2.0.v20060602-0010 -VDNgVdItGFMTNJo
org.eclipse.rcp.source_3.2.0.v20060602-0010-VDNgVdItGFMTNJo
org.eclipse.rcp_3.2.0.v20060511-1200.jar
org.eclipse.sdk_3.2.0.v20060529
org.eclipse.search_3.2.0.v20060602-0010.jar
org.eclipse.swt.gtk.linux.x86_64_3.2.0.v3232l.jar
org.eclipse.swt_3.2.0.v3232l.jar
org.eclipse.team.core_3.2.0.I200605181830.jar
org.eclipse.team.cvs.core_3.2.0.I200606011710.jar
org.eclipse.team.cvs.ssh2_3.2.0.I200606011710.jar
org.eclipse.team.cvs.ssh_3.2.0.I200606011710.jar
org.eclipse.team.cvs.ui_3.2.0.I200605251705.jar
org.eclipse.team.ui_3.2.0.I200606011710.jar
org.eclipse.text_3.2.0.v20060602-0010.jar
org.eclipse.tomcat_4.1.130.v20060601
org.eclipse.tptp.monitoring.doc.user_4.2.0.v200605251528.jar
org.eclipse.tptp.monitoring.examples_4.2.0.v200605251528.jar
org.eclipse.tptp.monitoring.logui_4.2.0.v200605251528.jar
org.eclipse.tptp.monitoring.profile.server_4.1.100.v20060525 1528.jar
org.eclipse.tptp.monitoring.report.birt.ui_4.2.0.v2006052515 28
org.eclipse.tptp.monitoring.report.birt_4.2.0.v200605251528. jar
org.eclipse.tptp.monitoring_4.1.100.v200605251528.jar
org.eclipse.tptp.platform.agentcontroller.doc.user_4.2.0.v20 0605251528.jar
org.eclipse.tptp.platform.agentcontroller_4.1.100.v200605251 528
org.eclipse.tptp.platform.analysis.codereview.java.rules_4.2 .0.v200605251528.jar
org.eclipse.tptp.platform.analysis.codereview.java_4.2.0.v20 0605251528.jar
org.eclipse.tptp.platform.analysis.core.ui.doc_4.2.0.v200605 251528.jar
org.eclipse.tptp.platform.analysis.core.ui_4.2.0.v2006052515 28.jar
org.eclipse.tptp.platform.analysis.core_4.2.0.v200605251528. jar
org.eclipse.tptp.platform.analysis.engine_4.1.100.v200605251 528.jar
org.eclipse.tptp.platform.analysis_4.1.100.v200605251528.jar
org.eclipse.tptp.platform.collection.framework_4.1.100.v2006 05251528
org.eclipse.tptp.platform.core_4.1.100.v200605251528.jar
org.eclipse.tptp.platform.doc.user_4.1.100.v200605251528.jar
org.eclipse.tptp.platform.examples_4.2.0.v200605251528.jar
org.eclipse.tptp.platform.execution_4.2.0.v200605251528
org.eclipse.tptp.platform.log.views_4.2.0.v200605251528.jar
org.eclipse.tptp.platform.lta_4.1.100.v200605251528.jar
org.eclipse.tptp.platform.models_4.2.0.v200605251528
org.eclipse.tptp.platform.probekit.launch_4.2.0.v20060525152 8.jar
org.eclipse.tptp.platform.probekit_4.1.100.v200605251528.jar
org.eclipse.tptp.platform.profile.server.core_4.1.100.v20060 5251528.jar
org.eclipse.tptp.platform.profile.server.wst_4.1.100.v200605 251528.jar
org.eclipse.tptp.platform.profile.server_4.1.100.v2006052515 28.jar
org.eclipse.tptp.platform.report.birt.ui_4.2.0.v200605251528
org.eclipse.tptp.platform.report.birt_4.2.0.v200605251528.ja r
org.eclipse.tptp.platform.report.core_4.1.100.v200605251528
org.eclipse.tptp.platform.report.ui_4.1.100.v200605251528
org.eclipse.tptp.platform.report_4.1.100.v200605251528.jar
org.eclipse.tptp.platform.samples_4.1.100.v200605251528.jar
org.eclipse.tptp.platform.statistical.ui_4.1.100.v2006052515 28.jar
org.eclipse.tptp.platform.trace_4.1.100.v200605251528.jar
org.eclipse.tptp.test.report.birt.ui_4.2.0.v200605251528.jar
org.eclipse.tptp.test.report.birt_4.2.0.v200605251528
org.eclipse.tptp.test.samples_4.1.100.v200605251528
org.eclipse.tptp.test.tools_4.1.100.v200605251528.jar
org.eclipse.tptp.test_4.1.100.v200605251528.jar
org.eclipse.tptp.trace.report.birt.ui_4.2.0.v200605251528
org.eclipse.tptp.trace.report.birt_4.2.0.v200605251528.jar
org.eclipse.tptp.trace_4.1.100.v200605251528.jar
org.eclipse.ui.browser_3.2.0.v20060601.jar
org.eclipse.ui.cheatsheets_3.2.0.v20060516.jar
org.eclipse.ui.console_3.1.100.v20060518.jar
org.eclipse.ui.editors_3.2.0.v20060602-0010.jar
org.eclipse.ui.externaltools_3.1.100.v20060511.jar
org.eclipse.ui.forms_3.2.0.v20060530.jar
org.eclipse.ui.ide_3.2.0.I20060602-0010.jar
org.eclipse.ui.intro.universal_3.2.0.v20060601
org.eclipse.ui.intro_3.2.0.v20060601.jar
org.eclipse.ui.navigator.resources_3.2.0.I20060511-2000.jar
org.eclipse.ui.navigator_3.2.0.I20060526-0010.jar
org.eclipse.ui.presentations.r21_3.2.0.I20060511-2000.jar
org.eclipse.ui.views.properties.tabbed_3.2.0.I20060511-0800a .jar
org.eclipse.ui.views_3.2.0.I20060511-2000.jar
org.eclipse.ui.workbench.compatibility_3.2.0.I20060511-2000
org.eclipse.ui.workbench.texteditor_3.2.0.v20060602-0010.jar
org.eclipse.ui.workbench_3.2.0.I20060602-0010.jar
org.eclipse.ui_3.2.0.I20060602-0010.jar
org.eclipse.update.configurator_3.2.0.v20060511.jar
org.eclipse.update.core.linux_3.2.0.v20060511.jar
org.eclipse.update.core_3.2.0.v20060602.jar
org.eclipse.update.scheduler_3.2.0.v20060511.jar
org.eclipse.update.ui_3.2.0.v20060601.jar
org.eclipse.ve.cde_1.2.0.v20060518_RC1.jar
org.eclipse.ve.doc_1.2.0.v20060518_RC1.jar
org.eclipse.ve.java.core_1.2.0.v20060530_RC2.jar
org.eclipse.ve.jfc_1.2.0.v20060518_RC1.jar
org.eclipse.ve.propertysheet_1.2.0.v20060518_RC1.jar
org.eclipse.ve.swt_1.2.0.v20060530_RC2.jar
org.eclipse.ve_1.2.0.v20060518_RC1.jar
org.eclipse.wst.command.env.core_1.0.101.v200605082020.jar
org.eclipse.wst.command.env.infopop_1.0.2.v200605070230.jar
org.eclipse.wst.command.env.ui_1.0.101.v200605160236.jar
org.eclipse.wst.command.env_1.0.101.v200605300321
org.eclipse.wst.common.core_1.0.100.v200605302315.jar
org.eclipse.wst.common.emf_1.0.0.v200605172127.jar
org.eclipse.wst.common.emfworkbench.integration_1.0.0.v20060 5172127.jar
org.eclipse.wst.common.environment_1.0.100.v200605082020.jar
org.eclipse.wst.common.frameworks.ui_1.0.100.v200605261351.j ar
org.eclipse.wst.common.frameworks_1.0.100.v200605250119.jar
org.eclipse.wst.common.infopop_1.0.1.v200605270041.jar
org.eclipse.wst.common.modulecore_1.0.100.v200605262006.jar
org.eclipse.wst.common.project.facet.core_1.0.1.v20060524163 9.jar
org.eclipse.wst.common.project.facet.ui_1.0.1.v200605301625. jar
org.eclipse.wst.common.snippets_1.0.100.v200605101723.jar
org.eclipse.wst.common.ui.properties_1.0.100.v200605262004.j ar
org.eclipse.wst.common.ui_1.0.100.v200605300630.jar
org.eclipse.wst.common.uriresolver_1.0.101.v200605300748.jar
org.eclipse.wst.css.core_1.1.0.v200605100843.jar
org.eclipse.wst.css.ui_1.0.100.v200605152323.jar
org.eclipse.wst.datatools.connection.ui.doc.user_1.0.1.v2006 05040131.jar
org.eclipse.wst.datatools.data.ui.doc.user_1.0.1.v2006050702 30.jar
org.eclipse.wst.datatools.fe.ui.doc.user_1.0.201.v2006050702 30.jar
org.eclipse.wst.datatools.server.ui.doc.user_1.0.1.v20060507 0230.jar
org.eclipse.wst.doc.user_1.0.201.v200605181647.jar
org.eclipse.wst.dtd.core_1.1.0.v200605100843.jar
org.eclipse.wst.dtd.ui.infopop_1.0.1.v200605040131.jar
org.eclipse.wst.dtd.ui_1.0.100.v200605172229.jar
org.eclipse.wst.dtdeditor.doc.user_1.0.2.v200605040131.jar
org.eclipse.wst.html.core_1.1.0.v200605280700.jar
org.eclipse.wst.html.standard.dtds_1.0.0.jar
org.eclipse.wst.html.ui.infopop_1.0.1.v200605040131.jar
org.eclipse.wst.html.ui_1.0.100.v200605241023.jar
org.eclipse.wst.internet.cache_1.0.101.v200605301759.jar
org.eclipse.wst.internet.monitor.core_1.0.102.v20060516d.jar
org.eclipse.wst.internet.monitor.ui_1.0.102.v20060516d.jar
org.eclipse.wst.internet.proxy.infopop_1.0.0.v200605070230.j ar
org.eclipse.wst.internet.proxy_1.0.100.v200605082020.jar
org.eclipse.wst.javascript.core_1.0.0.v200605152323.jar
org.eclipse.wst.javascript.ui.infopop_1.0.1.v200605040131.ja r
org.eclipse.wst.javascript.ui_1.0.0.v200605301759.jar
org.eclipse.wst.rdb.connection.ui.infopop_1.0.0.v20060504013 1.jar
org.eclipse.wst.rdb.connection.ui_1.0.101.v200605040131.jar
org.eclipse.wst.rdb.core.ui_1.0.102.v200605301759
org.eclipse.wst.rdb.core_1.0.106.v200605192055.jar
org.eclipse.wst.rdb.data.core_1.0.103.v200605171737.jar
org.eclipse.wst.rdb.data.ui_1.0.104.v200605171737.jar
org.eclipse.wst.rdb.dbdefinition.db2.iseries_1.0.101.v200605 040131.jar
org.eclipse.wst.rdb.dbdefinition.db2.luw_1.0.102.v2006050401 31.jar
org.eclipse.wst.rdb.dbdefinition.db2.zseries_1.0.101.v200605 040131.jar
org.eclipse.wst.rdb.dbdefinition.derby_1.0.101.v200605040131 .jar
org.eclipse.wst.rdb.dbdefinition.generic.jdbc_1.0.101.v20060 5040131.jar
org.eclipse.wst.rdb.dbdefinition.informix_1.0.102.v200605082 300.jar
org.eclipse.wst.rdb.dbdefinition.mysql_1.0.0.v200605040131.j ar
org.eclipse.wst.rdb.dbdefinition.oracle_1.0.101.v20060504013 1.jar
org.eclipse.wst.rdb.dbdefinition.sqlserver_1.0.102.v20060504 0131.jar
org.eclipse.wst.rdb.dbdefinition.sybase_1.0.102.v20060508230 0.jar
org.eclipse.wst.rdb.derby.ui_1.0.101.v200605040131.jar
org.eclipse.wst.rdb.derby_1.0.101.v200605040131.jar
org.eclipse.wst.rdb.fe.ui.actions_1.0.101.v200605040131.jar
org.eclipse.wst.rdb.fe.ui.infopop_1.0.0.v200605040131.jar
org.eclipse.wst.rdb.fe.ui_1.0.101.v200605040131.jar
org.eclipse.wst.rdb.models.dbdefinition_1.0.101.v20060504013 1.jar
org.eclipse.wst.rdb.models.sql.edit_1.0.102.v200605151754.ja r
org.eclipse.wst.rdb.models.sql_1.0.102.v200605151754.jar
org.eclipse.wst.rdb.mysql_1.0.101.v200605040131.jar
org.eclipse.wst.rdb.outputview.infopop_1.0.0.v200605040131.j ar
org.eclipse.wst.rdb.outputview_1.0.104.v200605151844
org.eclipse.wst.rdb.server.extensions_1.0.102.v20605152107
org.eclipse.wst.rdb.server.ui.infopop_1.0.0.v200605040131.ja r
org.eclipse.wst.rdb.server.ui_1.0.101.v200605291425.jar
org.eclipse.wst.rdb.sqleditor.infopop_1.0.0.v200605040131.ja r
org.eclipse.wst.rdb.sqleditor_1.0.103.v200605082257
org.eclipse.wst.rdb.sqlscrapbook_1.0.101.v200605261454.jar
org.eclipse.wst.server.core_1.0.102.v20060530.jar
org.eclipse.wst.server.ui.doc.user_1.0.2.v200605040131.jar
org.eclipse.wst.server.ui.infopop_1.0.2.v200605040131.jar
org.eclipse.wst.server.ui_1.0.102.v20060530.jar
org.eclipse.wst.sqleditor.doc.user_1.0.0.v200605270041.jar
org.eclipse.wst.sse.core_1.1.0.v200605280700.jar
org.eclipse.wst.sse.doc.user_1.0.201.v200605152316.jar
org.eclipse.wst.sse.ui.infopop_1.0.101.v200605040131.jar
org.eclipse.wst.sse.ui_1.0.101.v200605301759.jar
org.eclipse.wst.validation.infopop_1.0.201.v200605070230.jar
org.eclipse.wst.validation.ui_1.0.0.v200605301759.jar
org.eclipse.wst.validation_1.0.100.v200605250119.jar
org.eclipse.wst.web.ui.infopop_1.0.201.v200605070230.jar
org.eclipse.wst.web.ui_1.0.0.v200605301625.jar
org.eclipse.wst.web_1.0.0.v200605172127.jar
org.eclipse.wst.webtools.doc.user_1.0.201.v200605181650.jar
org.eclipse.wst.ws.explorer_1.0.101.v200605242132
org.eclipse.wst.ws.infopop_1.0.201.v200605152241.jar
org.eclipse.wst.ws.parser_1.0.100.v200605102129.jar
org.eclipse.wst.ws.ui_1.0.100.v200605082020.jar
org.eclipse.wst.ws_1.0.100.v200605300321.jar
org.eclipse.wst.wsdl.ui.doc.user_1.0.201.v200605111623.jar
org.eclipse.wst.wsdl.ui_1.0.1.v200605301759.jar
org.eclipse.wst.wsdl.validation_1.0.201.v200605300748.jar
org.eclipse.wst.wsdl_1.0.0.v200605262126.jar
org.eclipse.wst.wsi.ui.doc.user_1.0.201.v200605111705.jar
org.eclipse.wst.wsi.ui_1.0.0.v200605070715.jar
org.eclipse.wst.wsi_1.0.101.v200605232221.jar
org.eclipse.wst.xml.core_1.1.0.v200605302315.jar
org.eclipse.wst.xml.ui.infopop_1.0.1.v200605040131.jar
org.eclipse.wst.xml.ui_1.0.100.v200605301759.jar
org.eclipse.wst.xmleditor.doc.user_1.0.201.v200605040131.jar
org.eclipse.wst.xsd.core_1.0.101.v200605100738.jar
org.eclipse.wst.xsd.ui_1.0.100.v200605301759.jar
org.eclipse.wst.xsdeditor.doc.user_1.0.201.v200605181657.jar
org.eclipse.wst_1.0.1.v200605040144.jar
org.eclipse.xsd.ecore.exporter_2.2.0.v200605300949.jar
org.eclipse.xsd.ecore.importer_2.2.0.v200605300949.jar
org.eclipse.xsd.edit_2.2.0.v200605300949.jar
org.eclipse.xsd.editor_2.2.0.v200605300949.jar
org.eclipse.xsd_2.2.0.v200605300949.jar
org.junit4_4.1.0
org.junit_3.8.1
org.mozilla.rhino_1.6.0.N20060531-1258
org.uddi4j_2.0.4.v200604261334
org.w3c.sac_1.3.0.N20060531-1258
org.wsdl4j_1.4.0.v200603012030
/usr/local/java/eclipse-3.2rc7/features $ ls -1
org.apache.axis.feature_1.3.0.v200605180450--08422827454362
org.apache.commons_logging.feature_1.0.4.v200605300321--0842 2827522653
org.apache.jakarta_log4j.feature_1.2.8.v200605300321--084228 27522543
org.apache.wsil4j.feature_1.0.0.v200605180610--084228252A426 8
org.apache.xerces.feature_2.8.0.v200605151647--084228274_292 2
org.eclipse.datatools.connectivity.feature_0.9.0.200605291
org.eclipse.datatools.connectivity.oda.designer.feature_0.9. 0.200605291
org.eclipse.datatools.connectivity.oda.feature_0.9.0.2006052 91
org.eclipse.datatools.modelbase.feature_0.9.0.200605291
org.eclipse.jdt_3.2.0.v20060602-0010-F7snq0fulF-UQcP
org.eclipse.jst.common_core.feature_1.5.0.v200605151622--084 228273_3844
org.eclipse.jst.enterprise_core.feature_1.5.0.v200605151622- -2PD88P8MDOABDN
org.eclipse.jst.enterprise_ui.feature_1.5.0.v200605151622-pE Bq_gJJP8zh4Ud
org.eclipse.jst.enterprise_userdoc.feature_1.5.0.v2006051516 22--4hNDDhDcJUJeMV
org.eclipse.jst.server_adapters.feature_1.5.0.v20060516d---- --87cMN7N-iN
org.eclipse.jst.server_core.feature_1.5.0.v200605151622--2PD 88P8MDG4237
org.eclipse.jst.server_ui.feature_1.5.0.v20060516d-PGIEUCXGR zB8C59
org.eclipse.jst.server_userdoc.feature_1.5.0.v200605151622-- 08422827262337
org.eclipse.jst.web_core.feature_1.5.0.v200605151622--87cMN7 N-b3OgZg
org.eclipse.jst.web_ui.feature_1.5.0.v200605151622--2PD88P8M BJ_LFN
org.eclipse.jst.web_userdoc.feature_1.5.0.v200605151622
org.eclipse.jst_1.5.0.v200605191500-kKpXfcOuQy3WaNl
org.eclipse.pde_3.2.0.v20060602-0010-6zXJJzJvOWpFYED
org.eclipse.platform_3.2.0.v20060602-0010-_OZ2h-8eOaU1uKq
org.eclipse.rcp_3.2.0.v20060602-0010-VDNgVdItGFMTNJo
org.eclipse.sdk_3.2.0.v20060404-uDfm0S6NTspEZqy
org.eclipse.tptp.birt_4.2.0.v200605251528
org.eclipse.tptp.monitoring.runtime_4.2.0.v200605251528
org.eclipse.tptp.monitoring_4.2.0.v200605251528
org.eclipse.tptp.platform.analysis.engine_4.2.0.v20060525152 8
org.eclipse.tptp.platform.analysis_4.2.0.v200605251528
org.eclipse.tptp.platform.core.doc.user_4.2.0.v200605251528
org.eclipse.tptp.platform.core_4.2.0.v200605251528
org.eclipse.tptp.platform.doc.user_4.2.0.v200605251528
org.eclipse.tptp.platform.lta_4.2.0.v200605251528
org.eclipse.tptp.platform.probekit.doc.user_4.2.0.v200605251 528
org.eclipse.tptp.platform.probekit_4.2.0.v200605251528
org.eclipse.tptp.platform.runtime_4.2.0.v200605251528
org.eclipse.tptp.platform.samples_4.2.0.v200605251528
org.eclipse.tptp.platform.trace_4.2.0.v200605251528
org.eclipse.tptp.test.doc.user_4.2.0.v200605251528
org.eclipse.tptp.test.runtime_4.2.0.v200605251528
org.eclipse.tptp.test.tools_4.2.0.v200605251528
org.eclipse.tptp.test_4.2.0.v200605251528
org.eclipse.tptp.trace.runtime_4.2.0.v200605251528
org.eclipse.tptp.wtp_4.2.0.v200605251528
org.eclipse.ve_1.2.0.v20060530_RC2
org.eclipse.wst.common_core.feature_1.5.0.v200605151622--AXr VWXWMpHisqS
org.eclipse.wst.common_ui.feature_1.5.0.v200605221440-qKHiTH IayokBI3a
org.eclipse.wst.common_userdoc.feature_1.5.0.v200605151622
org.eclipse.wst.rdb_adapters.feature_1.5.0.v200605151622--Cq 0bcpcccXft7m
org.eclipse.wst.rdb_core.feature_1.5.0.v200605151622--3YIAAY AUDZEPQR
org.eclipse.wst.rdb_ui.feature_1.5.0.v200605221715-FTMpqXYhN g_RT_y
org.eclipse.wst.rdb_userdoc.feature_1.5.0.v200605151622--4hN DDhDcFjDKTF
org.eclipse.wst.server_core.feature_1.5.0.v200605151622----- 1G955G5E9Ar
org.eclipse.wst.server_ui.feature_1.5.0.v200605221710-PGIEYc jOaNJXKR_
org.eclipse.wst.server_userdoc.feature_1.5.0.v200605151622-- 08422827262353
org.eclipse.wst.web_core.feature_1.5.0.v200605151622--3YIAAY AUFUETIN
org.eclipse.wst.web_ui.feature_1.5.0.v200605221910-ziPyPmyvh ykAgnq
org.eclipse.wst.web_userdoc.feature_1.5.0.v200605151622--1G9 55G5E7K7GDB
org.eclipse.wst.ws_core.feature_1.5.0.v200605180610--4hNDDhD cOMJRPc
org.eclipse.wst.ws_ui.feature_1.5.0.v200605221450-hZYxAjxpq2 _5UiA
org.eclipse.wst.ws_userdoc.feature_1.5.0.v200605221940--1G95 5G5E777H7C
org.eclipse.wst.xml_core.feature_1.5.0.v200605151622--3YIAAY AUHICZIQ
org.eclipse.wst.xml_ui.feature_1.5.0.v200605221438-7plFl1NB2 FuXIx6
org.eclipse.wst.xml_userdoc.feature_1.5.0.v200605151622--3YI AAYAUCVDLMP
org.eclipse.wst_1.5.0.v200605221430-U-z2nUPIcqVPbf1
org.uddi4j.feature_2.0.3.v200605232140--08422826483556
org.wsdl4j.feature_1.4.0.v200605180555--08422825234252
Re: Integrated Agent Controller not enabled? [message #74854 is a reply to message #74833] |
Wed, 21 June 2006 14:36   |
Timo,
From the directory listing you posted, it seems that some plugin
fragments are missing under the Eclipse "plugins" directory. They are:
org.eclipse.hyades.execution.aix.ppc_4.2.0.v200606131519
org.eclipse.hyades.execution.hpux.PA_RISC_4.2.0.v20060613151 9
org.eclipse.hyades.execution.linux.x86_4.2.0.v200606131519
org.eclipse.hyades.execution.solaris.sparc_4.2.0.v2006061315 19
org.eclipse.hyades.execution.win32.x86_4.2.0.v200606131519
They contain the native code required for IAC to run. Without those
fragments, the IAC will be disabled.
I have downloaded the latest TPTP Runtime driver (build
TPTP-4.2.0-200606190100) from the 4.2.0 tab of:
http://www.eclipse.org/tptp/home/downloads/downloads.php
and I can see that all the above fragments exist. Will this be a problem
in the Callisto package?
Samson Wai
>> every Linux.
>> did.
>> RAC.
> org.junit4_4.1.0
> org.junit_3.8.1
Re: Integrated Agent Controller not enabled? [message #74874 is a reply to message #74854] |
Wed, 21 June 2006 17:46  |
Samson,
You can't mean all of them are needed... I just checked my two Linux
Eclipse 3.2RC7 systems, both of which I verified that the "IAC Enabled"
Windows Preferences was valid for... one starting from the Eclipse
Platform runtime and one starting from the Eclipse SDK ... both had the
linux.x86 one but none of the others... and as I said that dialog box
wsa enabled fine contrary to Timo's situation.
So Timo doesn't need all of them, but just the one for his system
(linux.x86 I expect), right?
Any idea how he could have gotten TPTP via the Callisto update site
*without* getting at least one of these?? Both of my setups came right
from Callisto upgrades!
RDS
Samson Wai wrote:
> Timo,
> Regards,
> Samson Wai
>> start
>>> every Linux.
>>> did.
>> think
>>> RAC.
>> an RAC
>> org.junit4_4.1.0
>> org.junit_3.8.1
RDS
Current Time: Sat Jul 26 04:35:58 EDT 2025
Powered by FUDForum. Page generated in 0.11248 seconds
