Getting older versions from p2 [message #744130] |
Fri, 21 October 2011 19:59  |
I'm trying to specify a lower version number for a particular feature and/or plugin, and having trouble getting bucky to accept it. I've tried specifying the version in both the plugin MANIFESTs and in the feature.xml. In both cases I get my favorite message, e.g. "No suitable provider for component org.eclipse.emf.edit:eclipse.feature/[2.7.0,2.7.0]"
I know the artifacts are in there. I can get them using P2 UI by deselecting the "Show only latest versions" checkbox. Is there some equivalent property I need to set for buckminster in order to force it to search earlier versions, or am I likely doing something else wrong? I would think that this would work OOTB..
Re: Getting older versions from p2 [message #745474 is a reply to message #745128] |
Sat, 22 October 2011 17:14  |
OK, I finally figured it out. I got the message above when I tried to specify a specific version from feature.xml. Here's what I'd tried..
1. All plugin MANIFEST.MF that reference the bundle have the version range specified, that is: org.eclipse.emf.edit;bundle-version="[2.7.0,2.7.1)"
2. My feature.xml includes the containing features without any version qualifiers, e.g. <includes id="org.eclipse.emf.edit" version="0.0.0"/>
But *that* didn't work. It then grabbed both 2.7.0 and 2.7.1 and failed during the build with an unsatisifed depenendency, presumably because emf.edit is a singleton and it had already loaded 2.7.1. Why is not exactly clear. But I have a theory why it grabbed 2.7.1 in the first place... Even though the current version of emf.edit.ui is still 2.7.0, the build for emf.edit.ui was created for Indigo SR1, which assumes the emf.edit 2.7.1 version. When I:
3. Removed both the emf.edit.ui and emf.edit features and instead used the plugin dependencies.
Buckminster then grabbed the emf.edit 2.7.0 and not the 2.7.1. I'm not sure my theory is correct though, because it was the SR1 build version of emf.edit.ui that ended up in the build. The only other explanation is that Buckminster pulled the emf.edit 2.7.1 feature even though I had requested the 2.7.0 emf.edit plugin.
whew...
[Updated on: Sat, 22 October 2011 17:15] by Moderator
FUDForum. Page generated in 0.25046 seconds
