How to unregister Listeners? [message #74394] |
Mon, 18 February 2008 18:39  |
I have written a Plugin, which is connected to a Service via an Extension
Point. This service informs the Plugin about "changes". The Plugin can
provide these Events to its UI-Elements. Therefore an UI-Element (e.g.
TreeViewer, ListViewer) can register itself to the Plugin as a Listener.
After the registration, the Plugin forwards the Events to the UI-Element.
Every new UI registers several UI-Elements to the Plugin, in order to
refresh these Elements if an event occurs. In case of RAP I need to
unregister the UI-Elements, after the Client (Browser) is closed.
How to handle this?
David
Re: How to unregister Listeners? [message #74522 is a reply to message #74394] |
Tue, 19 February 2008 02:14  |
Originally posted by: fappel.innoopract.com
I think you need to listen to the session's timeout to unhook the
listener you've added during the session. The SessionStoreListener may
be what you're looking for.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: David [mailto:david.seidel@prodyna.de]
Bereitgestellt: Dienstag, 19. Februar 2008 00:39
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: How to unregister Listeners?
Betreff: How to unregister Listeners?
Extension Point. This service informs the Plugin about "changes". The
Plugin can provide these Events to its UI-Elements. Therefore an
UI-Element (e.g.
UI-Element.
How to handle this?
David
FUDForum. Page generated in 0.06020 seconds
