Home » Language IDEs » C / C++ IDE (CDT) » Cross platform CDT...
Cross platform CDT... [message #74087] Thu, 26 June 2003 05:41 Go to next message
Originally posted by: mephri.infolink.co.id
Hi. Is it possible to do cross platform development using Linux CDT? E.g. I
want to develop Neutrino application using CDT under Linux? Hopefully vice
versa. Thanks..
--meph++
Re: Cross platform CDT... [message #74506 is a reply to message #74087] Mon, 30 June 2003 22:02 Go to previous messageGo to next message
Hellooo...
--meph++
"Mephri" <mephri@infolink.co.id> wrote in message
news:bdef4m$vlc$1@rogue.oti.com...
I
> versa. Thanks..
> --meph++
Re: Cross platform CDT... [message #75037 is a reply to message #74506] Sat, 05 July 2003 15:05 Go to previous messageGo to next message
news:bdqq4d$sro$1@rogue.oti.com...
> Hellooo...
> --meph++
E.g.
> I
vice
> > versa. Thanks..
First of all, I'd suggest that questions like this might be best directed at
QNX
and their product newsgroups.
Second, it is possible, but you would need to have the appropriate
toolchain,
libraries, headers etc which would mean purchasing the SDK from QNX. For
the vice versa, the same is true.
CDT is an platform/host agnostic development environment tool
Thomas
Re: Cross platform CDT... [message #76303 is a reply to message #74506] Fri, 18 July 2003 14:58 Go to previous message
Originally posted by: dschaefe.ca.ibm.com
Nothing in the CDT proper prohibits this. What it comes down to is the
tools that get integrated with the CDT that make this happen.
From a build perspective, if you specify cross platform development in a
makefile, then you can use the Standard Make project to build it.
I'm not as much of an expert on the debug side of things but I am aware of
gdbserver support there.
Hope this helps,
Doug
> Hellooo...
> --meph++
E.g.
> I
vice
> > versa. Thanks..
> > --meph++
Previous Topic:Use of Non-GNU C compiler with CDT
Next Topic:Integration of existing C / X / Motif code using Eclipse
Current Time: Sat Nov 08 22:18:53 EST 2025
Powered by FUDForum. Page generated in 0.25002 seconds
