# in twitter URL causes browser not to load [message #742427] |
Thu, 20 October 2011 09:33  |
I am using the SWT with DJSweet to generate screen captures of a web browser from my java program.
All is working well on Windows, but on Linux there is an issue with accessing twitter statuses.
I believe the problem is the # (pound/ hash) sign in the twitter status URL, which java interprets as a fragment identifier.
An example status is: twitter.com/#!/mexicanjoe/statuses/122004755785588736
On windows the complete URL seems to load, but on Linux on the part prior to the # sign loads.
I have tried escaping the # sign, but that does not get unescaped and gets a 404 error.
Any ideas would be appritiated!
Thanks!
-- Carolyn
Re: # in twitter URL causes browser not to load [message #743764 is a reply to message #743405] |
Fri, 21 October 2011 14:14   |
I've confirmed that it is a problem in the XULRunner version you're
using, because stand-alone Firefox 3.6.x shows the same behaviour.
Unfortunately the Browser currently only supports XULRunner versions up
to 3.6.x, which corresponds to Firefox 3.6.x, so I don't think there's a
Browser-supported XULRunner version where this works. There is an
eclipse 3.8 plan item to support newer XULRunner versions, so this would
likely make your case start to work.
One other possibility: URLs like this work fine in WebKitGTK. You
should be able to make use of this instead of XULRunner if all of the
following are true:
- DJSweet is creating its Browser with style SWT.NONE, not SWT.MOZILLA
- your Linux distro provides libraries for WebKitGTK >= 1.2.x (this has
been the case for 2-3 years)
- the underlying SWT version is 3.7.x, or alternatively it can be 3.6.2
iff the conditions in
http://www.eclipse.org/swt/faq.php#browserwebkitgtk are met
HTH,
Grant
On 10/21/2011 8:49 AM, Carolyn wrote:
> Hello,
> I checked and accoring to yum I have the most upto date version of
> xulrunner.
> xulrunner-1.9.2.9-1.el6.centos.x86_64
> What version would you reccomend?
> -- Carolyn
Re: # in twitter URL causes browser not to load [message #757929 is a reply to message #757102] |
Wed, 16 November 2011 16:39  |
I'm not great with managing RPMs like this either, and try to avoid
mixing them between distros.
Since you already have WebKitGTK 1.2.6, you presumably have all of the
dependencies that any WebKitGTK 1.2.x release would need. My experience
was that compiling WebKitGTK from source was reasonably straightforward
once all of the required dev packages are installed. You may wish to
try this if the whole RPM thing is giving you a headache.
http://trac.webkit.org/wiki/BuildingGtk is probably an accurate list of
the required dev packages, just ignore the stated version requirements
since they're for building WebKitGTK 1.6.x. If you get it built then
you can point to it at runtime by setting the LD_LIBRARY_PATH
environment variable.
Or alternatively, maybe you can install a newer linux distro?
Grant
On 11/16/2011 9:04 AM, Carolyn wrote:
> Hi Grant,
> I have been trying to no avail to upgrade my version of WebKitGTK on
> Centos to 1.2.7.
> I grabbed a Ferdora RPM and tried to recompile it, but that gave me
> errors on GLIB.
> I then grabbed the GLIB upgrade and tried to compile that, but I get an
> odd error message.
> Do you have any idea where RPMs for Ubuntu would be? All I found were
> deb files.
> I am really not greate when it comes to Linux, so if I am asking an
> obvious question please excuse me.
> -- Carolyn
> Here is the command I ran to rebuild the rpm rpmbuild --rebuild
> glib2-2.24.1-1.fc13.src.rpm > rebuild3.out 2>&1 & Here is the error
> incase that might spark some ideas...
> libtool: link: (cd ".libs" && rm -f "libgthread-2.0.so.0" && ln -s
> "libgthread-2.0.so.0.2400.1" "libgthread-2.0.so.0")
> libtool: link: (cd ".libs" && rm -f "libgthread-2.0.so" && ln -s
> "libgthread-2.0.so.0.2400.1" "libgthread-2.0.so")
> libtool: link: ar cru .libs/libgthread-2.0.a gthread-impl.o
> libtool: link: ranlib .libs/libgthread-2.0.a
> libtool: link: ( cd ".libs" && rm -f "libgthread-2.0.la" && ln -s
> "../libgthread-2.0.la" "libgthread-2.0.la" )
> make[3]: Leaving directory
> `/home/ec2-user/rpmbuild/BUILD/glib-2.24.1/gthread'
> Making all in tests
> make[3]: Entering directory
> `/home/ec2-user/rpmbuild/BUILD/glib-2.24.1/gthread/tests'
> gcc -DHAVE_CONFIG_H -I. -I../.. -g -I../.. -I../../glib
> -DG_DISABLE_CAST_CHECKS -DG_DISABLE_SINGLE_INCLUDES -pthread -O2 -g
> -Wall -MT 1bit-mutex.o -MD -MP -MF .deps/1bit-mutex.Tpo -c -o
> 1bit-mutex.o 1bit-mutex.c
> make[2]: *** wait: No child processes. Stop.
> make[2]: *** Waiting for unfinished jobs....
> make[1]: *** wait: No child processes. Stop.
> make[1]: *** Waiting for unfinished jobs....
> make: *** wait: No child processes. Stop.
> make: *** Waiting for unfinished jobs....
> error: Bad exit status from /var/tmp/rpm-tmp.zoYY2b (%build)
> RPM build errors:
> InstallSourcePackage at: psm.c:244: Header V3 RSA/SHA256 Signature, key
> ID e8e40fde: NOKEY
> user mockbuild does not exist - using root
> group mockbuild does not exist - using root
> make[3]: *** [1bit-mutex.o] Hangup
FUDForum. Page generated in 0.07272 seconds
