Home » Eclipse Projects » Subversive » Status cache not updating on Commit.
Status cache not updating on Commit. [message #743652] Fri, 21 October 2011 12:35 Go to next message
When I commit my changes, the SVN status in the Package Explorer doesn't update. If I change something in a file, save, I see that the file is marked as "modified". But when I commit, the status icon still says "modified". It also thinks I still have the SVN lock, so the "Lock file" dialog won't open. The file becomes read-only until I restart Eclipse, and reacquire the lock.
Disabling the SVN status cache in Eclipse Settings makes it work as expected, but I would like to be able to use the status cache.
Eclipse Version: Indigo Release
Eclipse Build id: 20110615-0604
Plugins:
Subversive SVN Connectors (2.2.2.I20110819-1700)
Subversive SVN Team Provider (Incubation) (0.7.9.I20110819-1700)
SVNKit 1.3.5 Implementation (Optional) (2.2.2.I20110819-1700)
OS: Windows 7 Professional (SP1)
I also use TortoiseSVN 1.6.16 (Subversion 1.6.17) for Windows integration, which I used for checking out the project.
I had the same problem in Windows XP on the same machine.
Have anyone else had this problem?
Have someone found the reason why it doesn't work?
Have someone found a solution (except disabling the SVN status cache)?
[Updated on: Fri, 21 October 2011 12:36] by Moderator
Re: Status cache not updating on Commit. [message #744687 is a reply to message #743652] Sat, 22 October 2011 05:05 Go to previous message
See my previous post: "Problems committing changes in Indigo".
See also bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=329555
Please, comment on it. Disabling the SVN Status Cache is a good
workaround I didn't know of.
Mauro.
Previous Topic:Port reset after restart eclipse
Next Topic:SVN Actions From Eclipse Helios
Current Time: Sat Jul 26 22:12:38 EDT 2025
Powered by FUDForum. Page generated in 0.06765 seconds
