Home » Language IDEs » ServerTools (WTP) » URL exception
icon4.gif  URL exception [message #743334] Fri, 21 October 2011 07:09 Go to next message
Hello
I've been searching on Internet for this problem but there is not a really solution for this.
I've installed eclipse with enterprice pack (from Oracle download page, becouse i need weblogic server)
I imported a project and all *.jsp file dosn't get open becpouse of
an exception
java.lang.IllegalArgumentException: URLDecoder: Illegal hex characters
in escape (%) pattern - For input string: "=r"
which is located her:
<link rel="stylesheet" type="text/css" href="..<%=request.getContextPath() %>/content_common.css" />
i resolved it this way:
String hrefPath = "href='..'" + request.getContextPath() + "/content_common.css";
<html>
      <head>
            <title>
                  Search Results (DlrSearchResults)
            </title>
            <META HTTP-EQUIV="expires" CONTENT="0">
            <META HTTP-EQUIV="Pragma" CONTENT="no-cache">
            <META HTTP-EQUIV="Cache-Control" CONTENT="no-cache">
            <link rel="stylesheet" type="text/css" <%=hrefPath%>>
      </head>
but what is the reason of this exception. I've many jsp this way and a don't reale have to chance all of them.
Best regards.
Re: URL exception [message #743580 is a reply to message #743334] Fri, 21 October 2011 11:37 Go to previous messageGo to next message
With which editor are you trying to open those JSPs? The Open With context menu on your JSP file will help you find out.
Re: URL exception [message #757783 is a reply to message #743580] Mon, 21 November 2011 11:15 Go to previous message
When I try to open a jsp page using the context menu of the JSP file I get the following exception:
at org.eclipse.jst.jsf.common.metadata.query.internal.taglib.TaglibDomainContextImpl.<init>(TaglibDomainContextImpl.java:48)
at org.eclipse.jst.jsf.common.metadata.query.internal.MetaDataQueryContextFactory.createTaglibDomainModelContext(MetaDataQueryContextFactory.java:65)
at org.eclipse.jst.pagedesigner.editors.palette.TagImageManager.getSmallIconImage(TagImageManager.java:80)
at org.eclipse.jst.pagedesigner.converter.jsp.JSPConverterFactory$MyLabelProvider.getImage(JSPConverterFactory.java:96)
at org.eclipse.jst.pagedesigner.converter.HiddenTagConverter.getVisualImage(HiddenTagConverter.java:91)
at org.eclipse.jst.pagedesigner.parts.ElementEditPart.createHiddenProvider(ElementEditPart.java:238)
at org.eclipse.jst.pagedesigner.parts.ElementEditPart.refresh(ElementEditPart.java:275)
at org.eclipse.jst.pagedesigner.parts.ElementEditPart.refresh(ElementEditPart.java:264)
at org.eclipse.gef.editparts.AbstractEditPart.addNotify(AbstractEditPart.java:253)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotify(AbstractGraphicalEditPart.java:223)
at org.eclipse.jst.pagedesigner.parts.NodeEditPart.addNotify(NodeEditPart.java:104)
at org.eclipse.jst.pagedesigner.parts.ElementEditPart.addNotify(ElementEditPart.java:155)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:212)
at org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(AbstractEditPart.java:781)
at org.eclipse.jst.pagedesigner.parts.DocumentEditPart.refreshChildren(DocumentEditPart.java:134)
at org.eclipse.jst.pagedesigner.parts.DocumentEditPart.refreshChildren(DocumentEditPart.java:126)
at org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractEditPart.java:726)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh(AbstractGraphicalEditPart.java:644)
at org.eclipse.jst.pagedesigner.parts.DocumentEditPart.refresh(DocumentEditPart.java:114)
at org.eclipse.gef.editparts.SimpleRootEditPart.setContents(SimpleRootEditPart.java:105)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:617)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:626)
at org.eclipse.jst.pagedesigner.editors.SimpleGraphicalEditor.setModel(SimpleGraphicalEditor.java:430)
at org.eclipse.jst.pagedesigner.editors.HTMLEditor.connectDesignPage(HTMLEditor.java:364)
at org.eclipse.jst.pagedesigner.editors.HTMLEditor.createPages(HTMLEditor.java:444)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2945)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2756)
at org.eclipse.ui.ide.IDE.openInternalEditorOnFileStore(IDE.java:1216)
at org.eclipse.ui.internal.ide.application.DelayedEventsProcessor$1.run(DelayedEventsProcessor.java:106)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
I am using eclipse version version 3.7.0 build I20110613-1736 with the Oracle Enterprise Pack for Eclipse version 11.1.1.7.3
This is really frustrating. Any help would be greatly appreciated.
Greg
Previous Topic:Reading an XML's schema via the Web Tools editor
Next Topic:CMDocument for an internal subset?
Current Time: Sun Jul 27 06:39:58 EDT 2025
Powered by FUDForum. Page generated in 0.04911 seconds
