Cached Ordered Lists have null inserted during 2nd update [message #736011] |
Thu, 13 October 2011 07:07  |
Eclipse Persistence Services - 2.4.0.v20110824-r9956
JDK build 1.6.0_27-b07
Windows Server 2008 SP2 win32
The following program contains 3 simple Entities, A singleton from which I get Container entities which are filled with Item Entities.
The Container owns an ordered list of items.
In a postload handler for Container I check that the list of items never contains null as I do not intend it ever to contain null. I do not remove items from the list or create null items in this example.
The postload handler contains an error message and exit when a problem is detected.
The problem seems to occur when the container entities changes are being merged back into the cache after their item lists have been added to during the second transaction.
At the beginning of the merge the instance of container which I have just changed is fine, and the cached 'original' is fine.
However when org.eclipse.persistence.internal.queries.OrderedListContainerPolicy#public void mergeChanges(CollectionChangeRecord changeRecord, Object valueOfTarget, boolean shouldMergeCascadeParts, MergeManager mergeManager, AbstractSession targetSession) is called
it fails to find the added Item eventhough it goes down the //getChangeType == add leg of the code. It seems that an IdentityHashMap is not returning the correct object. The result is that null is added into the cached 'target ' of the merge.
Note:
Every run of this program does NOT give rise to the error. However increasing the number of Containers to 100 almost always results in the problem on my win32 java VM ( max mem is 1024mb )
!!EDIT>>
The program is run with static weaving agent
-javaagent:C:\development\eclipselink\eclipselink-plugins-2.4.0.v20110824-r9956\org.eclipse.persistence.core_2.4.0.v20110824-r9956.jar.
If I run it without this, i.e. using dynamic weaving, then it does not have the problem even with large numbers of containers.
<<!!EDIT
Am I doing something wrong or is this a bug?
Here is the console output I see when running this;
The Customizer has been started
Customize a ServerSession(
DatabaseAccessor(disconnected)
H2Platform)
Customize session called TestSimpleOrderedLists_memPU
Found PersonHealth
[EL Info]: 2011-10-13 11:27:28.675--ServerSession(23108627)--EclipseLink, version: Eclipse Persistence Services - 2.4.0.v20110824-r9956
[EL Info]: 2011-10-13 11:27:28.849--ServerSession(23108627)--TestSimpleOrderedLists_memPU login successful
PreInsertEvent: 0$008b1689-73f1-421c-8323-82a212c65c39
AboutToInsertEvent: 0$008b1689-73f1-421c-8323-82a212c65c39
PreUpdateWithChangesEvent: 0$008b1689-73f1-421c-8323-82a212c65c39
PreInsertEvent: 0$ff58e277-1583-46b1-b01f-e0dd65247dbc
AboutToUpdateEvent: 0$008b1689-73f1-421c-8323-82a212c65c39
AboutToInsertEvent: 0$ff58e277-1583-46b1-b01f-e0dd65247dbc
PreUpdateWithChangesEvent: 0$ff58e277-1583-46b1-b01f-e0dd65247dbc
1: Commit it!
AboutToUpdateEvent: 0$ff58e277-1583-46b1-b01f-e0dd65247dbc
PostMergeEvent: 1$008b1689-73f1-421c-8323-82a212c65c39
PostMergeEvent: 2$ff58e277-1583-46b1-b01f-e0dd65247dbc
1: Committed!
PostCloneEvent: 2$ff58e277-1583-46b1-b01f-e0dd65247dbc
PostCloneEvent: 1$008b1689-73f1-421c-8323-82a212c65c39
PreUpdateWithChangesEvent: 2$ff58e277-1583-46b1-b01f-e0dd65247dbc
PreUpdateWithChangesEvent: 1$008b1689-73f1-421c-8323-82a212c65c39
2: Commit it!
!!!!!!!!! PostMergeEvent: 1$008b1689-73f1-421c-8323-82a212c65c39 source contains null
2: Committed!
!!!!!!!!! PostCloneEvent: 1$008b1689-73f1-421c-8323-82a212c65c39 original contains null
!!!!!!!!! PostCloneEvent: 1$008b1689-73f1-421c-8323-82a212c65c39 source contains null
FOUND IT!!!!
package uk.co.his.test.simpleol;
import java.io.IOException;
import javax.persistence.EntityManager;
import javax.persistence.EntityManagerFactory;
import javax.persistence.Persistence;
public class Main {
private static final int NumItemsPerContainer = 2; //10;
private static final int NumContainers = 2; //100;
//private static final int NumContainersForStage2 = 20;
public static void runContain2Test() {
EntityManagerFactory emf = Persistence.createEntityManagerFactory("TestSimpleOrderedLists_memPU");
EntityManager em = emf.createEntityManager();
em.getTransaction().begin();
Singleton singleton = Singleton.getInstance(em);
for(int i = 1; i <= NumContainers; i++) {
Container cont = singleton.containerAddNew(new Container(), em);
for(int j = 1; j <= NumItemsPerContainer; j++) {
cont.itemsAddNew(new Item(j), em);
cont.setDummyProp(i);
System.err.flush();
System.out.flush();
System.out.println("1: Commit it!");
em.getTransaction().commit();
em.close();
System.out.println("1: Committed!");
System.err.flush();
System.out.flush();
for(Container container: singleton.getContainers()) {
int beginIndex = NumItemsPerContainer;
container.itemsAddNew(new Item(++beginIndex), em);
//container.setDummyProp(container.getDummyProp() * 10);
em.flush();
/* for(int i = 1; i <= NumContainersForStage2; i++) {
for(int j = 1; j < NumItemsPerContainer; j++) {
cont.setDummyProp(NumContainers + i);
for(Item item: container.getItems()) {
item.setDummyProp(item.getDummyProp() * 10);
System.out.println("2: Commit it!");
em.close();
System.err.flush();
System.out.flush();
System.out.println("2: Committed!");
for(@SuppressWarnings("unused") Item item: container.getItems()) {
System.out.print(".");
System.err.flush();
System.out.flush();
System.out.println("3: Commit it!");
em.close();
System.err.flush();
System.out.flush();
System.out.println("3: Committed!");
System.err.flush();
System.out.flush();
System.out.println("Dones!");
* @param args
* @throws IOException
public static void main(String[] args) throws IOException {
runContain2Test();
import java.text.DateFormat;
import java.text.SimpleDateFormat;
import java.util.Date;
import java.util.Locale;
import java.util.TimeZone;
import javax.persistence.CascadeType;
import javax.persistence.Entity;
import javax.persistence.Id;
import javax.persistence.NamedQueries;
import javax.persistence.OneToMany;
import javax.persistence.Version;
@Entity
@NamedQueries({
public class Singleton {
@Version private int version;
@Id
protected String id = "1";
public static Singleton getInstance(EntityManager em) {
Singleton c = em.find(Singleton.class, "1");
if (c == null) {
c = new Singleton();
em.persist(c);
return c;
@OneToMany(cascade=CascadeType.ALL, mappedBy="singleton")
private java.util.Set<Container> containers = new java.util.HashSet<Container>();
protected Container containerAddNew(Container newObj, EntityManager em) {
newObj.setUUID();
newObj.setTimestamp(createTimestamp());
em.persist(newObj);
containers.add(newObj);
newObj.setSingleton(this);
newObj.itemsAddNew(new Item(0), em);
return newObj;
public java.util.Set<Container> getContainers() {
return containers;
private static String createTimestamp()
DateFormat df = new SimpleDateFormat("dd-MMM-yyyy hh:mm:ss", Locale.UK);
df.setTimeZone(TimeZone.getTimeZone("GB"));
return df.format(new Date());
import java.util.ArrayList;
import java.util.UUID;
import javax.persistence.Basic;
import javax.persistence.DiscriminatorColumn;
import javax.persistence.FetchType;
import javax.persistence.Inheritance;
import javax.persistence.InheritanceType;
import javax.persistence.ManyToOne;
import javax.persistence.OrderBy;
import javax.persistence.PostLoad;
import javax.persistence.PostPersist;
import javax.persistence.PreUpdate;
@Entity
@NamedQueries({})
@Inheritance(strategy=InheritanceType.SINGLE_TABLE)
@DiscriminatorColumn
public class Container {
@Id String id;
@Basic int dummyProp;
public int getDummyProp() {
return dummyProp;
public void setDummyProp(int dummyProp) {
this.dummyProp = dummyProp;
public void setUUID() {
id = UUID.randomUUID().toString();
@Basic String timestamp;
public String getTimestamp() {
return timestamp;
public void setTimestamp(String timestamp) {
this.timestamp = timestamp;
@ManyToOne(fetch=FetchType.LAZY)
private Singleton singleton;
public void setSingleton(Singleton singleton) {
this.singleton = singleton;
@OneToMany(cascade=CascadeType.ALL, mappedBy="container")
@OrderBy("item_idx")
java.util.List<Item> items = new ArrayList<Item>();
public java.util.List<Item> getItems() {
return items;
protected Item itemsAddNew(Item newObj, EntityManager em) {
newObj.setUUID();
em.persist(newObj);
items.add(newObj);
em.flush();
newObj.setContainer(this);
return newObj;
@PreUpdate
@PostPersist
public void z_updateIndices() {
//System.out.println("z_updateIndices " + id + "^" + hashCode() + ", items=" + items.hashCode());
for (int i = 0; i<items.size();i++) {
items.get(i).setItemIndex(i);
@PostLoad
public void postLoad() {
//System.out.println("PostLoad " + id + "^" + hashCode() + ", items=" + items.hashCode());
//System.out.println("Item at " + i + " is " + items.get(i));
if(items.get(i) == null) {
System.err.println("FOUND IT!!!!");
System.exit(1);
@Entity
@NamedQueries({
public class Item {
@Id
private String id;
@Basic
private int item_idx;
@Basic int creationOrder;
return timestamp;
return dummyProp;
public Item(int creationOrder) {
this.creationOrder = creationOrder;
private Item() {}
private Container container;
protected void setContainer(Container container) {
this.container = container;
public void setItemIndex(int index) {
item_idx = index;
public String toString() {
return "Item id=" + id + ", creationOrder=" + creationOrder + ", item_idx=" + item_idx;
import org.eclipse.persistence.descriptors.ClassDescriptor;
import org.eclipse.persistence.descriptors.DescriptorEvent;
import org.eclipse.persistence.descriptors.DescriptorEventAdapter;
import org.eclipse.persistence.descriptors.DescriptorEventManager;
import org.eclipse.persistence.sessions.Session;
public class Customizer implements org.eclipse.persistence.config.SessionCustomizer {
public Customizer()
System.err.println("The Customizer has been started");
public void customize(Session session) throws Exception {
System.err.println("Customize a " + session);
System.err.println("Customize session called " + session.getName());
for (ClassDescriptor descriptor : session.getDescriptors().values()) {
if(descriptor.getJavaClass() == Container.class) {
System.out.println("Found PersonHealth");
descriptor.getEventManager().addListener(new DescriptorEventAdapter() {
private void checkObjects(Container source, Container original, String eventName) {
Container evtObj = original==null?source:original;
String evtObjStr = evtObj==null?"null":("" + evtObj.dummyProp + "$" + evtObj.id);
//String info = eventName + ": " + original.dummyProp + "$" + original.id + ". source " + source.dummyProp + "$" + source.id;
String info = eventName + ": " + evtObjStr;
System.out.println(info);
if(original != null) {
if(original.items.contains(null)) {
System.out.println("!!!!!!!!! " + info + " original contains null");
}if(source != null) {
if(source.items.contains(null)) {
System.out.println("!!!!!!!!! " + info + " source contains null");
private void processEvent(DescriptorEvent event) {
checkObjects((Container)event.getSource(), (Container)event.getOriginalObject(), eventCodeToString(event.getEventCode()));
private String eventCodeToString(int eventCode) {
switch(eventCode) {
case DescriptorEventManager.PreWriteEvent :
return "PreWriteEvent";
case DescriptorEventManager.PostWriteEvent :
return "PostWriteEvent";
case DescriptorEventManager.PreDeleteEvent :
return "PreDeleteEvent";
case DescriptorEventManager.PostDeleteEvent :
return "PostDeleteEvent";
case DescriptorEventManager.PreInsertEvent :
return "PreInsertEvent";
case DescriptorEventManager.PostInsertEvent :
return "PostInsertEvent";
case DescriptorEventManager.PreUpdateEvent :
return "PreUpdateEvent";
case DescriptorEventManager.PostUpdateEvent :
return "PostUpdateEvent";
case DescriptorEventManager.PostBuildEvent :
return "PostBuildEvent";
case DescriptorEventManager.PostRefreshEvent :
return "PostRefreshEvent";
case DescriptorEventManager.PostCloneEvent :
return "PostCloneEvent";
case DescriptorEventManager.PostMergeEvent :
return "PostMergeEvent";
case DescriptorEventManager.AboutToInsertEvent :
return "AboutToInsertEvent";
case DescriptorEventManager.AboutToUpdateEvent :
return "AboutToUpdateEvent";
case DescriptorEventManager.AboutToDeleteEvent :
return "AboutToDeleteEvent";
case DescriptorEventManager.PrePersistEvent :
return "PrePersistEvent";
case DescriptorEventManager.PreRemoveEvent :
return "PreRemoveEvent";
case DescriptorEventManager.PreUpdateWithChangesEvent :
return "PreUpdateWithChangesEvent";
return "Unknown event";
public void aboutToInsert(DescriptorEvent event) {
processEvent(event);
public void aboutToUpdate(DescriptorEvent event) {
public void postBuild(DescriptorEvent event) {
public void postClone(DescriptorEvent event) {
public void postMerge(DescriptorEvent event) {
public void postRefresh(DescriptorEvent event) {
public void preInsert(DescriptorEvent event) {
public void preUpdateWithChanges(DescriptorEvent event) {
persistence.xml;
<persistence xmlns="http://java.sun.com/xml/ns/persistence"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="2.0"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd">
<persistence-unit name="TestSimpleOrderedLists_memPU">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<class> uk.co.his.test.simpleol.Singleton</class>
<class> uk.co.his.test.simpleol.Container</class>
<class> uk.co.his.test.simpleol.Item</class>
<properties>
<property name="eclipselink.target-database" value="org.eclipse.persistence.platform.database.H2Platform"/>
<property name="javax.persistence.jdbc.url" value="jdbc:h2:mem:TestSimpleOrderedListsmem"/>
<property name="eclipselink.ddl-generation" value="create-tables"/>
<property name="eclipselink.session.customizer" value="uk.co.his.test.simpleol.Customizer"/>
</properties>
</persistence-unit>
</persistence>
Attachment: Main.java
(Size: 2.97KB, Downloaded 254 times)
Attachment: Container.java
(Size: 2.89KB, Downloaded 253 times)
Attachment: Singleton.java
(Size: 1.49KB, Downloaded 255 times)
Attachment: Item.java
(Size: 1.58KB, Downloaded 250 times)
Attachment: persistence.xm
(Size: 1.01KB, Downloaded 371 times)
[Updated on: Thu, 13 October 2011 07:56] by Moderator
FUDForum. Page generated in 0.06989 seconds
