Re: [Newbie] Help starting the Java profiler [message #74279 is a reply to message #74226] |
Wed, 14 June 2006 17:01   |
Stanimir Stamenkov wrote:
> /Stanimir Stamenkov/:
>> I'm running Eclipse 3.2 RC7 and I've installed the TPTP features as
>> found under the "Testing and Performance" category following the
>> Callisto Discovery Site...
> O.k. What I've installed appears as development version 4.2. I've now
> taken a safer approach and installed TPTP 4.1.0.1 - I see the "Run >
> Profile" entries. I'm still unable to launch profile successfully - I
> get 'An internal error occurred during: "launching".' with no additional
> details. I'll see what I could be missing reading from the documentation.
But Eclipse 3.2 RC7 is a "development version" as well. You don't want
to mix-and-match. If you want 3.2 RC7, go back to 4.2 (preferably the
very latest stable build to go with 3.2RC7)... or if you want to go back
to stable TPTP 4.1.0.1, make sure you adhere to the Requirements section
for that release (Eclipse 3.1.2 I think it was).
So you started with Eclipse 3.2 RC7... platform or SDK? Then you went
and installed the TPTP from the Callisto Discovery... good...good... I
presume you went through the pages that allow you to checkmark TPTP, and
accept the licensing, and override the "are you sure you want to
install" with "Install All", all the way up to the time that it
suggested you restart the workbench... right? On restarting the
workbench, what perspective are you in? Do you have a project in hand?
If I just start up RC7 with a working TPTP (I use it often; I know it
works) but with a new workspace, I'm in a Resource perspective with no
TPTP showing. If I switch to the Java perspective, even with no project,
I see the TPTP Profile launch button as you describe ("run with clock").
If you don't see that in Java mode... you might want to shut down and
restart by adding "-clean" to your startup invocation (Properties =>
Target on the Eclipse icon if in Windows...). If that doesn't work,
you'll need to check your Eclipse .metadata logfile to see if something
died on start-up.
This has been working well for me (and many others) for a while now on
Eclipse 3.2 w/TPTP 4.2 ... but there are "windows" where things have
been potentially broken as we've migrated from one Release Candidate
(RC) to another on the Eclipse mirrors... you might have accidentally
hit one of those windows. This Callisto release (Eclipse 3.2, TPTP 4.2,
and a host of others) *is* "in development" and not yet officially
released after all!
Let me know if I can help you get any further after you decide which
path you want to take!
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: [Newbie] Help starting the Java profiler [message #74893 is a reply to message #74425] |
Wed, 21 June 2006 22:46  |
Originally posted by: mankiko.gmail.com
I was having the exact same problem...
What fixed it for me was installing the TPTP Profiling for Web
applications package (I had only installed 3 of the 4 the first time
around).
The Run w/clock icon wouldn't show up until the Web app package was
installed.
Hopefully someone will find this useful.
Thanks for the tips!
Dave
FUDForum. Page generated in 0.30429 seconds
