Home » Archived » BIRT » horizontal printing in BIRT(how to print rows of selected table column horizontally)
horizontal printing in BIRT [message #742225] Thu, 20 October 2011 05:47 Go to next message
Is there a way to print rows of selected table column horizontally? the reports we are working on is basically a matrix report format similar to the format of a cross-tab but all grouped columns must be displayed on each row and a sub-total must appear after each new values on the grouped column.
thanks,
Re: horizontal printing in BIRT [message #742568 is a reply to message #742225] Thu, 20 October 2011 12:02 Go to previous messageGo to next message
Why can you not use a crosstab?
Jason
> grouped column.
> thanks,
Re: horizontal printing in BIRT [message #744339 is a reply to message #742568] Fri, 21 October 2011 23:26 Go to previous messageGo to next message
If we use cross-tab how can we make the group columns' value of a group appear for every each line?
Re: horizontal printing in BIRT [message #748284 is a reply to message #744339] Mon, 24 October 2011 11:56 Go to previous message
That is what the default crosstab does. If the group is dimension in
the cube and the dimension is placed on a crosstab it will show one row
per group value.
Jason
Previous Topic:Using the result of a dataset in another dataset
Next Topic:Generate given HTML once per report page in a custom report item
Current Time: Fri Jul 25 20:32:22 EDT 2025
Powered by FUDForum. Page generated in 0.06561 seconds
