Home » Archived » Eclipse Process Manager (Stardust) » Use of Timestamps in Stardust AuditTrail database(Retrieving and using timestamps in Stardust AuditTrail database)
Use of Timestamps in Stardust AuditTrail database [message #742083] Thu, 20 October 2011 02:45 Go to next message
Stardust stores dates as long values in the Audit Trail. The statement below helps to check timestamps in a Stardust Audit Trail if Oracle DB is used.
e.g.
select to_char(to_date('01-JAN-1970','DD-MON-YYYY') + ( ai.starttime / (1000 * 60 * 60 * 24) ),'DD-MON-YYYY HH24:MI:SS') "STARTTIME" from activitiy_instance ai;
[Updated on: Thu, 20 October 2011 04:25] by Moderator
Re: Use of Timestamps in Stardust AuditTrail database [message #742084 is a reply to message #742083] Thu, 20 October 2011 02:45 Go to previous messageGo to next message
Same SQL for MySQL databases looks like this ...
select cast(from_unixtime(ai.starttime / 1000) as datetime) from activity_instance ai
... considering timezone conversion ...
select convert_tz(cast(from_unixtime(ai.starttime / 1000) as datetime), '+00:00', '+05:00') from activity_instance ai
Re: Use of Timestamps in Stardust AuditTrail database [message #742086 is a reply to message #742084] Thu, 20 October 2011 02:47 Go to previous message
In case you need to add a where predicate on a date field that is stored as long value, you can use something similar to the SQL statement below (Oracle)...
SELECT count(*)
FROM process_instance pi
WHERE pi.state = 2
AND pi.oid = pi.rootprocessinstance
AND pi.terminationtime < (to_date('2010-01-01', 'YYYY-MM-DD') - to_date('1970-01-01','YYYY-MM-DD')) * (24 * 60 * 60 * 1000)
[Updated on: Thu, 20 October 2011 04:26] by Moderator
Previous Topic:How to enable logging on transaction management for Spring managed Stardust runtime?
Next Topic:Resetting daemon status at the database level
Current Time: Wed Jul 30 08:31:57 EDT 2025
Powered by FUDForum. Page generated in 0.02795 seconds
