Home » Archived » Eclipse Process Manager (Stardust) » Using Structure Data Type (SDT) in Java Applications(Use of SDT in Stardust using POJOs)
Using Structure Data Type (SDT) in Java Applications [message #741976] Thu, 20 October 2011 00:07 Go to next message
My Structure Data Type defines also attributes. How can attributes be handled in a POJO Application?
[Updated on: Thu, 20 October 2011 06:30] by Moderator
Re: Using Structure Data Type (SDT) in Java Applications [message #741978 is a reply to message #741976] Thu, 20 October 2011 00:08 Go to previous message
Find general documentation on how SDTs are used in Java Application here ...
https://infinity.sungard.com/documentation/ipp/6.0/topic/ag.carnot.docs.dev/html/handbooks/programming/pg-structured-data.html
The Java representation of SDTs are Maps of Maps, Lists, primitve data types and/or Date objects.
For example the simple structure ...
User (firstname, lastname)
... would be represented in Java as a Map with two key/value pairs.
firstname = "John"
lastanme = "Doe"
If the SDT also defines attributes, you just need to add an @ prefix to your key.
firstname = "John"
lastanme = "Doe"
@gender = "male"
[Updated on: Thu, 20 October 2011 05:25] by Moderator
Previous Topic:Invalid JAXP setup, javax.xml.transform.TransformerConfigurationException
Next Topic:Tomcat runs of out memory in a RAD scenario
Current Time: Thu Jul 31 00:42:40 EDT 2025
Powered by FUDForum. Page generated in 1.39088 seconds
