Home » Eclipse Projects » EclipseLink » Cached Ordered Lists have null inserted during 2nd update(OrderedLists which are updated with new items sometimes have a null inserted where a valid object should be found. Example does not always show problem. ?bug occurs during OrderedListContainerPolicy m)
Cached Ordered Lists have null inserted during 2nd update [message #736011] Thu, 13 October 2011 07:07 Go to next message
Eclipse Persistence Services - 2.4.0.v20110824-r9956
JDK build 1.6.0_27-b07
Windows Server 2008 SP2 win32
The following program contains 3 simple Entities, A singleton from which I get Container entities which are filled with Item Entities.
The Container owns an ordered list of items.
In a postload handler for Container I check that the list of items never contains null as I do not intend it ever to contain null. I do not remove items from the list or create null items in this example.
The postload handler contains an error message and exit when a problem is detected.
The problem seems to occur when the container entities changes are being merged back into the cache after their item lists have been added to during the second transaction.
At the beginning of the merge the instance of container which I have just changed is fine, and the cached 'original' is fine.
However when org.eclipse.persistence.internal.queries.OrderedListContainerPolicy#public void mergeChanges(CollectionChangeRecord changeRecord, Object valueOfTarget, boolean shouldMergeCascadeParts, MergeManager mergeManager, AbstractSession targetSession) is called
it fails to find the added Item eventhough it goes down the //getChangeType == add leg of the code. It seems that an IdentityHashMap is not returning the correct object. The result is that null is added into the cached 'target ' of the merge.
Note:
Every run of this program does NOT give rise to the error. However increasing the number of Containers to 100 almost always results in the problem on my win32 java VM ( max mem is 1024mb )
!!EDIT>>
The program is run with static weaving agent
-javaagent:C:\development\eclipselink\eclipselink-plugins-2.4.0.v20110824-r9956\org.eclipse.persistence.core_2.4.0.v20110824-r9956.jar.
If I run it without this, i.e. using dynamic weaving, then it does not have the problem even with large numbers of containers.
<<!!EDIT
Am I doing something wrong or is this a bug?
Here is the console output I see when running this;
The Customizer has been started
Customize a ServerSession(
DatabaseAccessor(disconnected)
H2Platform)
Customize session called TestSimpleOrderedLists_memPU
Found PersonHealth
[EL Info]: 2011-10-13 11:27:28.675--ServerSession(23108627)--EclipseLink, version: Eclipse Persistence Services - 2.4.0.v20110824-r9956
[EL Info]: 2011-10-13 11:27:28.849--ServerSession(23108627)--TestSimpleOrderedLists_memPU login successful
PreInsertEvent: 0$008b1689-73f1-421c-8323-82a212c65c39
AboutToInsertEvent: 0$008b1689-73f1-421c-8323-82a212c65c39
PreUpdateWithChangesEvent: 0$008b1689-73f1-421c-8323-82a212c65c39
PreInsertEvent: 0$ff58e277-1583-46b1-b01f-e0dd65247dbc
AboutToUpdateEvent: 0$008b1689-73f1-421c-8323-82a212c65c39
AboutToInsertEvent: 0$ff58e277-1583-46b1-b01f-e0dd65247dbc
PreUpdateWithChangesEvent: 0$ff58e277-1583-46b1-b01f-e0dd65247dbc
1: Commit it!
AboutToUpdateEvent: 0$ff58e277-1583-46b1-b01f-e0dd65247dbc
PostMergeEvent: 1$008b1689-73f1-421c-8323-82a212c65c39
PostMergeEvent: 2$ff58e277-1583-46b1-b01f-e0dd65247dbc
1: Committed!
PostCloneEvent: 2$ff58e277-1583-46b1-b01f-e0dd65247dbc
PostCloneEvent: 1$008b1689-73f1-421c-8323-82a212c65c39
PreUpdateWithChangesEvent: 2$ff58e277-1583-46b1-b01f-e0dd65247dbc
PreUpdateWithChangesEvent: 1$008b1689-73f1-421c-8323-82a212c65c39
2: Commit it!
!!!!!!!!! PostMergeEvent: 1$008b1689-73f1-421c-8323-82a212c65c39 source contains null
2: Committed!
!!!!!!!!! PostCloneEvent: 1$008b1689-73f1-421c-8323-82a212c65c39 original contains null
!!!!!!!!! PostCloneEvent: 1$008b1689-73f1-421c-8323-82a212c65c39 source contains null
FOUND IT!!!!
package uk.co.his.test.simpleol;
import java.io.IOException;
import javax.persistence.EntityManager;
import javax.persistence.EntityManagerFactory;
import javax.persistence.Persistence;
public class Main {
	private static final int NumItemsPerContainer = 2; //10;
	private static final int NumContainers = 2; //100;
	//private static final int NumContainersForStage2 = 20;
	public static void runContain2Test() {
		EntityManagerFactory emf = Persistence.createEntityManagerFactory("TestSimpleOrderedLists_memPU");
		EntityManager em = emf.createEntityManager();
		em.getTransaction().begin();
		Singleton singleton = Singleton.getInstance(em);
		for(int i = 1; i <= NumContainers; i++) {
			Container cont = singleton.containerAddNew(new Container(), em);
			for(int j = 1; j <= NumItemsPerContainer; j++) {
				cont.itemsAddNew(new Item(j), em);
			cont.setDummyProp(i);
		System.err.flush();
		System.out.flush();
		System.out.println("1: Commit it!");
		em.getTransaction().commit();
		em.close();
		System.out.println("1: Committed!");
		System.err.flush();
		System.out.flush();
		for(Container container: singleton.getContainers()) {
			int beginIndex = NumItemsPerContainer;
			container.itemsAddNew(new Item(++beginIndex), em);
			//container.setDummyProp(container.getDummyProp() * 10);
		em.flush();
/*		for(int i = 1; i <= NumContainersForStage2; i++) {
			for(int j = 1; j < NumItemsPerContainer; j++) {
			cont.setDummyProp(NumContainers + i);
			for(Item item: container.getItems()) {
				item.setDummyProp(item.getDummyProp() * 10);
		System.out.println("2: Commit it!");
		em.close();
		System.err.flush();
		System.out.flush();
		System.out.println("2: Committed!");
			for(@SuppressWarnings("unused") Item item: container.getItems()) {
				System.out.print(".");
		System.err.flush();
		System.out.flush();
		System.out.println("3: Commit it!");
		em.close();
		System.err.flush();
		System.out.flush();
		System.out.println("3: Committed!");
		System.err.flush();
		System.out.flush();
		System.out.println("Dones!");
	 * @param args
	 * @throws IOException
	public static void main(String[] args) throws IOException {
		runContain2Test();
import java.text.DateFormat;
import java.text.SimpleDateFormat;
import java.util.Date;
import java.util.Locale;
import java.util.TimeZone;
import javax.persistence.CascadeType;
import javax.persistence.Entity;
import javax.persistence.Id;
import javax.persistence.NamedQueries;
import javax.persistence.OneToMany;
import javax.persistence.Version;
@Entity
@NamedQueries({
public class Singleton {
	@Version private int version;
	@Id
	protected String id = "1";
	public static Singleton getInstance(EntityManager em) {
		Singleton c = em.find(Singleton.class, "1");
		if (c == null) {
			c = new Singleton();
			em.persist(c);
		return c;
	@OneToMany(cascade=CascadeType.ALL, mappedBy="singleton")
    private java.util.Set<Container>  containers  = new java.util.HashSet<Container>();
	protected  Container containerAddNew(Container newObj, EntityManager em) {
	    newObj.setUUID();
	    newObj.setTimestamp(createTimestamp());
	    em.persist(newObj);
	    containers.add(newObj);
	    newObj.setSingleton(this);
	    newObj.itemsAddNew(new Item(0), em);
	    return newObj;
	public java.util.Set<Container> getContainers() {
		return containers;
	private static String createTimestamp()
		DateFormat df = new SimpleDateFormat("dd-MMM-yyyy hh:mm:ss", Locale.UK);
		df.setTimeZone(TimeZone.getTimeZone("GB"));
		return df.format(new Date());
import java.util.ArrayList;
import java.util.UUID;
import javax.persistence.Basic;
import javax.persistence.DiscriminatorColumn;
import javax.persistence.FetchType;
import javax.persistence.Inheritance;
import javax.persistence.InheritanceType;
import javax.persistence.ManyToOne;
import javax.persistence.OrderBy;
import javax.persistence.PostLoad;
import javax.persistence.PostPersist;
import javax.persistence.PreUpdate;
@Entity
@NamedQueries({})
@Inheritance(strategy=InheritanceType.SINGLE_TABLE)
@DiscriminatorColumn
public class Container {
	@Id String id;
    @Basic int dummyProp;
	public int getDummyProp() {
		return dummyProp;
	public void setDummyProp(int dummyProp) {
		this.dummyProp = dummyProp;
	public void setUUID() {
		id = UUID.randomUUID().toString();
	 @Basic String timestamp;
	    public String getTimestamp() {
			return timestamp;
		public void setTimestamp(String timestamp) {
			this.timestamp = timestamp;
	@ManyToOne(fetch=FetchType.LAZY)
	private Singleton singleton;
	public void setSingleton(Singleton singleton) {
		this.singleton = singleton;
	@OneToMany(cascade=CascadeType.ALL, mappedBy="container")
	@OrderBy("item_idx")
    java.util.List<Item>  items  = new ArrayList<Item>();
	public java.util.List<Item> getItems() {
		return items;
	protected  Item itemsAddNew(Item newObj, EntityManager em) {
	    newObj.setUUID();
	    em.persist(newObj);
	    items.add(newObj);
		em.flush();
	    newObj.setContainer(this);
	    return newObj;
	@PreUpdate
    @PostPersist
    public void z_updateIndices() {
		//System.out.println("z_updateIndices " + id + "^" + hashCode() + ", items=" + items.hashCode());
		for (int i = 0; i<items.size();i++) {
			items.get(i).setItemIndex(i);
	@PostLoad
	public void postLoad() {
		//System.out.println("PostLoad " + id + "^" + hashCode() + ", items=" + items.hashCode());
			//System.out.println("Item at " + i + " is " + items.get(i));
			if(items.get(i) == null) {
				System.err.println("FOUND IT!!!!");
				System.exit(1);
@Entity
@NamedQueries({
public class Item {
	@Id
	private String id;
    @Basic
    private int item_idx;
    @Basic int creationOrder;
		return timestamp;
		return dummyProp;
	public Item(int creationOrder) {
    	this.creationOrder = creationOrder;
    private Item() {}
    private Container container;
	protected void setContainer(Container container) {
		this.container = container;
	public void setItemIndex(int index) {
		item_idx = index;
	public String toString() {
		return "Item id=" + id + ", creationOrder=" + creationOrder + ", item_idx=" + item_idx;
import org.eclipse.persistence.descriptors.ClassDescriptor;
import org.eclipse.persistence.descriptors.DescriptorEvent;
import org.eclipse.persistence.descriptors.DescriptorEventAdapter;
import org.eclipse.persistence.descriptors.DescriptorEventManager;
import org.eclipse.persistence.sessions.Session;
public class Customizer implements org.eclipse.persistence.config.SessionCustomizer {
	public Customizer()
		System.err.println("The Customizer has been started");
	public void customize(Session session) throws Exception {
		System.err.println("Customize a " + session);
		System.err.println("Customize session called " + session.getName());
		for (ClassDescriptor descriptor : session.getDescriptors().values()) {
			if(descriptor.getJavaClass() == Container.class) {
				System.out.println("Found PersonHealth");
				descriptor.getEventManager().addListener(new DescriptorEventAdapter() {
					private void checkObjects(Container source, Container original, String eventName) {
						Container evtObj = original==null?source:original;
						String evtObjStr = evtObj==null?"null":("" + evtObj.dummyProp + "$" + evtObj.id);
						//String info = eventName + ": " + original.dummyProp + "$" + original.id + ". source " + source.dummyProp + "$" + source.id;
						String info = eventName + ": " + evtObjStr;
						System.out.println(info);
						if(original != null) {
							if(original.items.contains(null)) {
								System.out.println("!!!!!!!!! " + info + " original contains null");
						}if(source != null) {
							if(source.items.contains(null)) {
								System.out.println("!!!!!!!!! " + info + " source contains null");
					private void processEvent(DescriptorEvent event) {
						checkObjects((Container)event.getSource(), (Container)event.getOriginalObject(), eventCodeToString(event.getEventCode()));
					private String eventCodeToString(int eventCode) {
						switch(eventCode) {
						case DescriptorEventManager.PreWriteEvent :
							return "PreWriteEvent";
						case DescriptorEventManager.PostWriteEvent :
							return "PostWriteEvent";
						case DescriptorEventManager.PreDeleteEvent :
							return "PreDeleteEvent";
						case DescriptorEventManager.PostDeleteEvent :
							return "PostDeleteEvent";
						case DescriptorEventManager.PreInsertEvent :
							return "PreInsertEvent";
						case DescriptorEventManager.PostInsertEvent :
							return "PostInsertEvent";
						case DescriptorEventManager.PreUpdateEvent :
							return "PreUpdateEvent";
						case DescriptorEventManager.PostUpdateEvent :
							return "PostUpdateEvent";
						case DescriptorEventManager.PostBuildEvent :
							return "PostBuildEvent";
						case DescriptorEventManager.PostRefreshEvent :
							return "PostRefreshEvent";
						case DescriptorEventManager.PostCloneEvent :
							return "PostCloneEvent";
						case DescriptorEventManager.PostMergeEvent :
							return "PostMergeEvent";
						case DescriptorEventManager.AboutToInsertEvent :
							return "AboutToInsertEvent";
						case DescriptorEventManager.AboutToUpdateEvent :
							return "AboutToUpdateEvent";
						case DescriptorEventManager.AboutToDeleteEvent :
							return "AboutToDeleteEvent";
						case DescriptorEventManager.PrePersistEvent :
							return "PrePersistEvent";
						case DescriptorEventManager.PreRemoveEvent :
							return "PreRemoveEvent";
						case DescriptorEventManager.PreUpdateWithChangesEvent :
							return "PreUpdateWithChangesEvent";
						return "Unknown event";
					public void aboutToInsert(DescriptorEvent event) {
						processEvent(event);
					public void aboutToUpdate(DescriptorEvent event) {
					public void postBuild(DescriptorEvent event) {
					public void postClone(DescriptorEvent event) {
					public void postMerge(DescriptorEvent event) {
					public void postRefresh(DescriptorEvent event) {
					public void preInsert(DescriptorEvent event) {
					public void preUpdateWithChanges(DescriptorEvent event) {
persistence.xml;
<persistence xmlns="http://java.sun.com/xml/ns/persistence"
	xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="2.0"
	xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd">
	<persistence-unit name="TestSimpleOrderedLists_memPU">
		<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
		<class> uk.co.his.test.simpleol.Singleton</class>
		<class> uk.co.his.test.simpleol.Container</class>
		<class> uk.co.his.test.simpleol.Item</class>
		<properties>
			<property name="eclipselink.target-database" value="org.eclipse.persistence.platform.database.H2Platform"/>
			<property name="javax.persistence.jdbc.url" value="jdbc:h2:mem:TestSimpleOrderedListsmem"/>
			<property name="eclipselink.ddl-generation" value="create-tables"/>
			<property name="eclipselink.session.customizer" value="uk.co.his.test.simpleol.Customizer"/>
		</properties>
	</persistence-unit>
</persistence>
  • Attachment: Main.java
    (Size: 2.97KB, Downloaded 254 times)
  • Attachment: Container.java
    (Size: 2.89KB, Downloaded 253 times)
  • Attachment: Singleton.java
    (Size: 1.49KB, Downloaded 254 times)
  • Attachment: Item.java
    (Size: 1.58KB, Downloaded 250 times)
  • Attachment: persistence.xm
    (Size: 1.01KB, Downloaded 370 times)
[Updated on: Thu, 13 October 2011 07:56] by Moderator
Re: Cached Ordered Lists have null inserted during 2nd update [message #741651 is a reply to message #736011] Wed, 19 October 2011 15:08 Go to previous messageGo to next message
I have reimplemented this using @OrderColumn and have the same problems...
When I run the uploaded files I get the following output
	H2Platform)
Customize session called TestSimpleOrderedLists2_memPU
Found Container
[EL Info]: 2011-10-19 20:05:53.627--ServerSession(33341602)--EclipseLink, version: Eclipse Persistence Services - 2.4.0.v20110824-r9956
[EL Info]: 2011-10-19 20:05:53.782--ServerSession(33341602)--TestSimpleOrderedLists2_memPU login successful
1: Commit it!
PreInsertEvent: 1$045a6045-18fd-4293-89b6-f7a9177d0a2d
PreInsertEvent: 2$2481696d-f758-4c17-94cd-4e39f37e9b47
AboutToInsertEvent: 2$2481696d-f758-4c17-94cd-4e39f37e9b47
AboutToInsertEvent: 1$045a6045-18fd-4293-89b6-f7a9177d0a2d
PostMergeEvent: 2$2481696d-f758-4c17-94cd-4e39f37e9b47
PostMergeEvent: 1$045a6045-18fd-4293-89b6-f7a9177d0a2d
1: Committed!
PostCloneEvent: 1$045a6045-18fd-4293-89b6-f7a9177d0a2d
PostCloneEvent: 2$2481696d-f758-4c17-94cd-4e39f37e9b47
PreUpdateWithChangesEvent: 1$045a6045-18fd-4293-89b6-f7a9177d0a2d
PreUpdateWithChangesEvent: 2$2481696d-f758-4c17-94cd-4e39f37e9b47
2: Commit it!
2: Committed!
........3: Commit it!
3: Committed!
Inserted One Item
Inserted One Item
Inserted One Item
Inserted One Item
4: Commit it!
!!!!!!!!! PostMergeEvent: 1$045a6045-18fd-4293-89b6-f7a9177d0a2d source contains null
4: Committed!
!!!!!!!!! PostCloneEvent: 1$045a6045-18fd-4293-89b6-f7a9177d0a2d original contains null
!!!!!!!!! PostCloneEvent: 1$045a6045-18fd-4293-89b6-f7a9177d0a2d source contains null
.......Found it!!!
Here is the persistence.xml
<persistence-unit name="TestSimpleOrderedLists2_memPU">
		<class> uk.co.his.test.simpleol2.Singleton</class>
		<class> uk.co.his.test.simpleol2.Container</class>
		<class> uk.co.his.test.simpleol2.Item</class>
		<properties>
			<property name="javax.persistence.jdbc.url" value="jdbc:h2:mem:TestSimpleOrderedLists2mem"/>
			<property name="eclipselink.session.customizer" value="uk.co.his.test.simpleol2.Customizer"/>
			<property name="eclipselink.logging.level" value="FINE" />
			<property name="eclipselink.logging.session" value="true" />
		</properties>
	</persistence-unit>
    (Size: 3.83KB, Downloaded 266 times)
    (Size: 1.49KB, Downloaded 243 times)
    (Size: 2.59KB, Downloaded 238 times)
    (Size: 1.45KB, Downloaded 245 times)
  • Attachment: Customizer.java
    (Size: 4.81KB, Downloaded 273 times)
Re: Cached Ordered Lists have null inserted during 2nd update [message #742346 is a reply to message #741651] Thu, 20 October 2011 08:16 Go to previous message
I have submitted this as Bug #361529
https://bugs.eclipse.org/bugs/show_bug.cgi?id=361529
Re: Cached Ordered Lists have null inserted during 2nd update [message #742350 is a reply to message #741651] Thu, 20 October 2011 08:16 Go to previous message
Previous Topic:Controlling column order when creating tables with ddl-generation
Next Topic:command line tool for generating JPA Entities?
Current Time: Wed Jul 23 21:38:53 EDT 2025
Powered by FUDForum. Page generated in 0.27798 seconds
