Problem persisting TimestampTZ with JPA [message #737095] |
Fri, 14 October 2011 12:52  |
Versions
Eclipselink 2.1
Oracle 10.2.0.4
Tomcat 5.5.26
Using JPA, I am attempting to persist a java.util.Calendar object to an Oracle Timestamp With Time Zone column. From what I have read, Eclipselink is supposed to just handle this for Oracle DB.
However, an attempt at a direct mapping:
@Entity
@Table(name="TIMESTAMP_TZ_TEST")
public class TimestampTzTest {
@Id
private Long id;
@Column(name="TIME")
private Calendar time;
public Long getId() {
return id;
public void setId(Long id) {
this.id = id;
public Calendar getTime() {
return time;
public void setTime(Calendar time) {
this.time = time;
fails during startup because
The attribute [time] from the entity class [class eg.model.TimestampTzTest] does not specify a temporal type.
Next, I try using a TypeConverter
@Convert("timestamptz")
@TypeConverter(name="timestamptz", dataType=TIMESTAMPTZ.class)
This results in an error during execution:
Caused by: java.lang.ClassCastException: org.apache.tomcat.dbcp.dbcp.DelegatingCallableStatement cannot be cast to oracle.jdbc.OracleCallableStatement
at oracle.sql.TRANSDUMP.getTransitions(TRANSDUMP.java:42)
at oracle.sql.TIMEZONETAB.updateTable(TIMEZONETAB.java:456)
at oracle.sql.TIMESTAMPTZ.toTimestamp(TIMESTAMPTZ.java:571)
at oracle.sql.TIMESTAMPTZ.timestampValue(TIMESTAMPTZ.java:731)
at org.eclipse.persistence.platform.database.oracle.Oracle9Platform.getTIMESTAMPTZFromResultSet(Oracle9Platform.java:192)
From what I have found during search, this appears to be caused by the Tomcat connection pool not returning the underlying OracleCallableStatement.
I have not been able to find a solution to this problem. Can someone please guide me?
Re: Problem persisting TimestampTZ with JPA [message #1784440 is a reply to message #1784079] |
Tue, 27 March 2018 22:22  |
You have posted elsewhere with additional information, suggesting you configured the persistence unit to use JTA. To be used, JPA requires access to the external transaction controller to be hooked into JTA, so you are going to need to create one that hooks into your JTA configuration, or use resource-local for your persistence unit.
FUDForum. Page generated in 0.09432 seconds
