Home » Language IDEs » ServerTools (WTP) » Eclipse Helios Deployment Assembly not working for Webapps(Classpath not working right for dependent projects)
Eclipse Helios Deployment Assembly not working for Webapps [message #739581] |
Mon, 17 October 2011 12:16  |
Since I moved to Eclipse Helios (from Ganymede) I have not been able to run/debug webapps successfully from within Eclipse. Classes from dependent projects throw the infamous ClassNotFoundException, even after adding the projects to the Deployment Assembly.
I could manually JAR the dependent projects and deploy them in WEB-INF/lib or deploy everything to Tomcat by hand... but that defeats the purpose. Previous versions allowed us to do quite painlessly.
Clearly, Helios requires "something else" besides defining dependent projects in the Deployment Assembly, but I can't seem to find what. Any suggestions?
I am running Eclipse Helios, Java 6, Servlet 2.4 (old webapp), Tomcat 6.
[Updated on: Mon, 17 October 2011 14:10] by Moderator
Re: Eclipse Helios Deployment Assembly not working for Webapps [message #739742 is a reply to message #739581] |
Mon, 17 October 2011 16:10   |
> suggestions?
Try right-clicking on the server in the Servers view and select
"Clean..." to force a full publish. See if that helps. Out of
curiosity, is this a new Helios workspace with brand new projects that
is not working? If not, did you open the Ganymede workspace with Helios
or did you import projects into a new Helios workspace?
Larry
Re: Eclipse Helios Deployment Assembly not working for Webapps [message #755758 is a reply to message #755593] |
Wed, 09 November 2011 08:57   |
On 11/8/2011 4:40 PM, Bruno Melloni wrote:
> Larry Isaacs wrote on Wed, 19 October 2011 09:07
>> On 10/18/2011 12:37 PM, Bruno Melloni wrote:
>> (snip)
>> I have interacted with a number of people who have reported this. So
>> far, each time the interaction has come to a stop prior to determining
>> a cause. I assume things mysteriously started working.
> Not necessarily. Many, like me, might be just giving up and going back
> to Ganymede - where things worked quite smoothly.
> In my own case I am getting annoyed enough at this garbage to consider a
> return to Netbeans. I rely heavily on project dependencies and I don't
> have the time to waste on an IDE that can't handle it without jumping
> through hoops.
> For those still struggling and determined to use Helios, I found a
> couple things that make life slightly better: (1) add every single
> dependent project to both the project dependencies and the deployment
> assembly and (b) use Tomcat 7 - NOT Tomcat 6. This doesn't solve all the
> problems but it is a step in the right direction.
> Still, the real fix is to return to Ganymede + Tomcat 6. That setup is
> pretty much fool-proof.
If you, or someone else experiencing this issue, is willing to invest
some time, I will try to help determine the cause. I've been unable to
duplicate this problem, so I will need to work with someone to gather
clues about why this happens.
Larry
Re: Eclipse Helios Deployment Assembly not working for Webapps [message #792436 is a reply to message #789253] |
Mon, 06 February 2012 20:42   |
On 2/2/2012 2:37 PM, Bruno Melloni wrote:
> Larry Isaacs wrote on Wed, 09 November 2011 08:57
>> Cheers,
>> Larry
> I have been extremely tied up but I foresee having time to focus on this
> over the next week or so.
> I also have setup a Java7/EclipseIndigo environment where I can work on
> this issue with no concern over hurting my normal work.
> If the offer is still on, I volunteer myself as guinea pig.
Hi Bruno,
Since it seems to reliably not work for you, if you can create a simple
pair of projects (web and utility) that exhibit this problem, it would
worthwhile to open a bug and attach a zip with the projects to the bug.
The Product would be "WTP ServerTools" and the Component "jst.server".
Preferably this would be projects that only require the Eclipse Java
EE Developers package to run. If more is required, please list what
else is needed. This would allow me to check and see if there is
something different about your projects and the projects that work for
me. If this doesn't seem feasible, then we'll come up with another
approach.
Larry
Re: Eclipse Helios Deployment Assembly not working for Webapps [message #792873 is a reply to message #792436] |
Tue, 07 February 2012 09:14   |
Larry Isaacs wrote on Mon, 06 February 2012 20:42On 2/2/2012 2:37 PM, Bruno Melloni wrote:
>> Cheers,
>> Larry
Hi Bruno,
approach.
Larry
It seems that the other Bruno beat me to it. I am back to being fully busy right now but I should get freed up in a few days. If still needed then I will make the sample projects in Indigo. They will be vanilla JEE plus Spring, one web project and two regular. They will demonstrate how a regular project can easily load classes and spring context files from the others in both Eclipse and web server, and how the web project does too when run directly on the server or from Eclipse Ganymede - while failing when run from Eclipse Helios or Indigo.
Re: Eclipse Helios Deployment Assembly not working for Webapps [message #792874 is a reply to message #792632] |
Tue, 07 February 2012 09:11   |
On 2/7/2012 3:04 AM, Bruno Eberhard wrote:
> Hi Larry,
> I've created the two projects and could reproduce the effect. I don't fully understand what you mean with the described Product and Component name, but I hope the two zip-files will do for you. In the working version I've exported the helper project to the lib directory of the web proejct. In the not working version this hast not be done and the dependency should work with the Deployment Assembly settings.
> Bruno
Oops, I forgot that as an Eclipse committer you will see different UI in
Bugzilla when creating bugs than I will. You can start here:
https://bugs.eclipse.org/bugs/. Once you have an account and have
logged in, click "File a Bug". You will then click "Other projects".
Very near the bottom of the page, select the Product by clicking "WTP
ServerTools". You can skip Step 1 since you are providing a zip and
need a new bug. In Step 2, select "jst.server" for the Component and
provide a Summary and brief Description. Then create the Bug in Step 3.
I'm not sure what you will see next, but hopefully is the bug report
page where you will be able to add an attachment for your zip. It is
best if you create the bug so you will be logged as the reporter. Post
here with the bug number and I will assign the bug to me and try out
your zip.
Larry
Re: Eclipse Helios Deployment Assembly not working for Webapps [message #797724 is a reply to message #792874] |
Mon, 13 February 2012 16:01  |
I think I found a solution. It is probably inefficient and overkill, but I just got it to work on Indigo, with Java 7, Tomcat 7, and using the "Dynamic Web Module" version 3.0.
I will have to do more testing using Java 6, Tomcat 7 and Dynamic Web Module version 2.4... our current deployment environment.
The key elements in the solution were:
1) I had a TestWeb and a TestUtility applications. Dynamic Web Project and Java EE Utility Project respectively. They both had Spring Context files.
2) In TestWeb I added TestUtility to both the Java Build Path and the Deployment Assembly.
3) In the TestWeb context I made sure to (a) have an import statement and (b) make sure the import statement used the format:
<import resource="classpath*:TestUtilityContext.xml" />
The "classpath*:" was the critical bit. In Ganymede you didn't need it and yet TestUtilityContext.xml would be found in the classpath. In Helios and Indigo that is no longer so.
My guess is that the standard became more rigid in the newer version and that Eclipse simply followed it.
[Updated on: Mon, 13 February 2012 16:03] by Moderator
Current Time: Sat Jul 26 18:20:39 EDT 2025
Powered by FUDForum. Page generated in 0.30662 seconds
