Home » Modeling » Graphiti » Some small issues with Copy/Paste
Some small issues with Copy/Paste [message #737250] |
Fri, 14 October 2011 16:51  |
I've playing a little with Copy/Paste features. The basic support is quite nice and ingenuous. Some issues/observations:
1. The tutorial seems to assume that one will do just a cloning of the pictogram but not of the Business object. It should be clear that this is not necesary (I'm not even sure it's typical), one could also want to clone the business object.
2. The copy/paste inner working does quite dark magic (for me, at least) to place an EObject in the SWT clipboard, using the URIs of the EObjects (I would have expected something simpler, more like an serialization/deserialization, but I don't kwnow anything about SWT clipboard, and little about EMF).
This has some hidden implicancies: one must not copied pre-cloned detached objects, for example. Further, perhaps the tutorial (or the javaDocs) should mention that the canXXXX() methods in the Features should be as light as possible, in particular the canPaste() method is called a lot.
3. Because of that dark magic (I guess) the type of the content placed in the clipboard seems to confuse the rest of the workbench. For example, if I copy a graphical element (in the tutorial) and go to the Project Explorer, the "paste" menu is enabled - this is slightly incorrect, compare with what happens when one copies some text in a text editor.
4. For simplicity, the tutorial places the paste objects at the origin. I tried the more typical behaviour, placing the objects at some fixed offset from the original elements. It basically worked, but it revealed a little issue: if several objects were involved, only one of the new objects is selected after the paste. This is atypical and frustrating, because one frequently wants to move together the set of cloned objects.
Should I enter a bug?
BTW: Is there some programmatic way of marking some pictograms as selected?
5. Another user-unfriendly thing of the tutorial, is the bit about disabling the paste if some element apart from the diagram is selected. The user typically selects some elements, type Ctrl-C, Ctrl-V in sucession, and expects that the selected elements are cloned. Of course, this can be just an idiosincracy of the tutorial, but I wonder why it was implemented in that way.
[Updated on: Fri, 14 October 2011 16:52] by Moderator
Re: Some small issues with Copy/Paste [message #741181 is a reply to message #737250] |
Wed, 19 October 2011 05:04   |
See my comments below.
Michael
"Hernan" schrieb im Newsbeitrag news:j7a6m0$t3g$1@news.eclipse.org...
Michael: I added a note in the Copy&Paste section of the tutorial on that.
Michael: Hm, the way the clipboard is implement was simply taken over from
our previous implementation on our MOF-based modeling infrastructure. There
it was natural to implement it like this. Maybe in EMF a different
implementation would make sense, not sure about that.
Regarding the performance of the canXXX methods I added a note to the docu
page.
Michael: Hm, you're right. What happens is a little irritating; would you
open a bugzilla for this?
tried the more typical behaviour, placing the objects at some offset from
the original. It basically worked, but it revealed a little issue: if
Michael: For M3 we enhanced the paste context with the location information,
so users can also paste their stuff to the mouse location. The tutorial
shows how to do that. Selecting objects after feature processing is always
restricted to at most one object. An enhancement request should target that
completely; feel free to open one.
Michael: you can select them in the editor:
DiagramEditor.selectPictogramElements(PictogramElement[] pictogramElements)
way.
Michael: This is just the way it is implemented in the tutorial for showing
how to restrict copy and paste, without having much focus on usability.
Current Time: Sat Jul 26 12:09:34 EDT 2025
Powered by FUDForum. Page generated in 0.41028 seconds
