build classpath and "run classpath" [message #73848] |
Tue, 08 July 2003 04:26  |
Originally posted by: bernard.leach.diamos.com
Hi all,
I have a project where I would like to use a different runtime classpath
to the build time classpaths of the projects it is dependent on. I had
hoped to use the "exported" classpath of each project and then add any
extra dependencies, as required, manually. However it seems that the
"default classpath" for a run item is the concatenation of the build
classpath for each dependent project.
The construction is a little strange in that if you uncheck the default
classpath, delete all items and then re-add the dependent projects you
only get the exported resources for each of these projects (which is
actually what I'd hoped for originally!).
Is this inconsistency the desired behaviour?
cheers,
bernard.
FUDForum. Page generated in 0.06172 seconds
