| Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » CDO: Oracle JDBC driver
 Goto Forum:|
| CDO: Oracle JDBC driver [message #7347] | Tue, 13 December 2005 15:53  |  |
| Eclipse User  |  |  |  |  | Originally posted by: tvalence1.cox.net
 Hi Eike,
 I am trying to use Oracle in conjunction with CDO to persist a model that
 has been previously saved/accessed via CDO/MySQL.
 I tried creating a fragment, org.eclipse.net4j.jdbc.oracle (i.e. similar to
 org.eclipse.net4j.jdbc.mysql) to enable CDO to interact with the Oracle JDBC
 driver, but it failed to properly validate in
 org.eclipse.net4j.spring.db.ContextClassLoaderDataSource().
 I was able to workaround the above class loader issue, but now an exception
 is being thrown in
 org.eclipse.net4j.dbgen.impl.SqlDialectImpl.initTypeMappings ().
 Do you have any advice/source on how to properly setup CDO to use the Oracle
 Thin Client JDBC driver?
 Any help would be greatly appreciated.
 Thanks!
 - Ted
| Re: CDO: Oracle JDBC driver [message #7401 is a reply to message #7358] | Thu, 15 December 2005 14:16   |  |
 Eike,
 Attached is the jdbc.oracle fragment (minus the actual Oracle driver) and
 the debug log from the test.
 Note that I had to include the Oracle driver in my application's startup
 plug-in to resolve a classloader issue.  Hopefully, the resolution of the
 fragement issue described below will also resolve the classloader problem.
 BTW, my proof-of-concept was based on MySql, but my target environment runs
 on Oracle.
 Cheers.
 - Ted
 "Eike Stepper" <stepper@sympedia.de> wrote in message
 news:dnrf31$637$1@news.eclipse.org...
 > Hi Ted,
 > Starting with a copy of the jdbc.mysql fragment is a godd idea.
 > I did it for Oracle long time ago and it worked. If only I could
 > find it, I'd send it to you.
 > See my other comments inline...
 > Cheers
 > /Eike
 > TVal schrieb:
 >> Hi Eike,
 > Just to clarify, you don't mean some data migration feature?
 > I assume Mysql was simpler to test with and now you want to switch to
 > Oracle
 > and start with new data.
 >> to
 >> JDBC
 > What was the reason? (copy log)
 >> exception
 >> is being thrown in
 > Can I see the stack trace?
 >> Oracle
 > Let's have a look at your logs and if you want to, you can send me the
 > fragment...
| Re: CDO: Oracle JDBC driver [message #7413 is a reply to message #7401] | Fri, 16 December 2005 03:08  |  |
| Eclipse User  |  |  |  |  | Originally posted by: stepper.sympedia.de
 Ted,
 In your new fragment.xml you are referring to an "oracle" dialect:
 <extension name="Net4j Pluggable ORACLE Driver" point="org.eclipse.net4j.jdbc.drivers">
 <driver className="oracle.jdbc.driver.OracleDriver" exampleURL="jdbc:oracle:thin:@<server>[:<1521>]:<database_name >" name="Oracle">
 <supportedDialect name="oracle" />
 </driver>
 </extension>
 Have you developed, configured and deployed this SqlDialect?
 The name of the provided oracle dialect is "ORACLE", maybe that helps.
 I have coded an additional argument check to detect missing dialects
 before an NPE hurts. Please update org.eclipse.net4j.dbgen
 Does that help?
 Cheers
 /Eike
 TVal schrieb:
 > Eike,
 > on Oracle.
 > Cheers.
 > - Ted
 >>Hi Ted,
 >>Cheers
 >>/Eike
 >>TVal schrieb:
 >>>Hi Eike,
 >>Oracle
 >>>to
 >>>JDBC
 >>>exception
 >>>is being thrown in
 >>>Oracle
 >>fragment...
| Re: CDO: Oracle JDBC driver [message #561967 is a reply to message #7347] | Thu, 15 December 2005 05:04  |  |
| Eclipse User  |  |  |  |  | Hi Ted,
 Cheers
 /Eike
 TVal schrieb:
 > Hi Eike,
 I assume Mysql was simpler to test with and now you want to switch to Oracle
 > is being thrown in
 Let's have a look at your logs and if you want to, you can send me the fragment...
| Re: CDO: Oracle JDBC driver [message #562056 is a reply to message #7358] | Thu, 15 December 2005 14:16  |  |
 Eike,
 on Oracle.
 Cheers.
 - Ted
 > Hi Ted,
 > Cheers
 > /Eike
 > TVal schrieb:
 >> Hi Eike,
 > Oracle
 >> to
 >> JDBC
 >> exception
 >> is being thrown in
 >> Oracle
 > fragment...
| Re: CDO: Oracle JDBC driver [message #562080 is a reply to message #7401] | Fri, 16 December 2005 03:08  |  |
| Eclipse User  |  |  |  |  | Ted,
 </driver>
 </extension>
 Does that help?
 Cheers
 /Eike
 TVal schrieb:
 > Eike,
 > on Oracle.
 > Cheers.
 > - Ted
 >>Hi Ted,
 >>Cheers
 >>/Eike
 >>TVal schrieb:
 >>>Hi Eike,
 >>Oracle
 >>>to
 >>>JDBC
 >>>exception
 >>>is being thrown in
 >>>Oracle
 >>fragment...
 Current Time: Fri Oct 31 02:30:08 EDT 2025
 Powered by FUDForum . Page generated in 0.08217 seconds |
