Home » Archived » BIRT » DataTextDropListener drop behavior changed(Drag/drop behavior in chart wizard)
DataTextDropListener drop behavior changed [message #739598] Mon, 17 October 2011 12:36 Go to next message
Last year I integrated BIRT 2.3.2 into our product so that customers could use the chart wizard to create/manage their own charts. Upon upgrading eclipse to 3.7, we upgraded BIRT to 3.7 as well. While testing the chart wizard, I noticed that the drag/drop to the x/y axis fields no longer works. Specifically, the code that assigns the value has been commented out of DataTextDropListener.
	public void drop( DropTargetEvent event )
		String bindingName = (String) event.data;
		// Since in Mac os X/ Linux, the dragEnter method did not validate
		// expression, so
		// here validate the expression.
		if ( !Platform.OS_WIN32.equals( Platform.getOS( ) ) )
			ExpressionCodec expCodec = ChartModelHelper.instance( )
					.createExpressionCodec( );
			expCodec.setBindingName( bindingName, btnBuilder.isCube( ) );
			if ( !DataDefinitionTextManager.getInstance( )
					.isValidExpression( txtDataDefn, expCodec.getExpression( ) ) )
				return;
		btnBuilder.setBindingName( bindingName, true );
		// String expression = (String) event.data;
		// // If it's last element, remove color binding
		// if ( !expression.equals( ChartUIUtil.getText( txtDataDefn ) )
		// && DataDefinitionTextManager.getInstance( )
		// .getNumberOfSameDataDefinition( ChartUIUtil.getText( txtDataDefn ) )
		// == 1 )
		// ColorPalette.getInstance( ).retrieveColor( ChartUIUtil.getText(
		// txtDataDefn ) );
		// // Check if dragged expression can be put on target series. For
		// sharing
		// // binding case, Y optional only allow grouped binding.
		// if ( !DataDefinitionTextManager.getInstance( )
		// .isValidExpression( txtDataDefn, expression ) )
		// return;
		// btnBuilder.setExpression( expression );
		// DataDefinitionTextManager.getInstance( ).updateQuery( txtDataDefn );
		// // Refresh all data definition text
		// DataDefinitionTextManager.getInstance( ).refreshAll( );
Can anyone explain to me why this code was commented out? Is there a work-around?
Carl
Re: DataTextDropListener drop behavior changed [message #739631 is a reply to message #739598] Mon, 17 October 2011 13:16 Go to previous message
I am not certain why this was commented out. Can you open a bugzilla
entry with the question?
Jason
> // expression, so
> // here validate the expression. if ( !Platform.OS_WIN32.equals(
> return;
> // == 1 )
> // txtDataDefn ) );
> // sharing
> // return;
> work-around?
> Carl
Previous Topic:hiding column after rendering
Next Topic:Heat map in birt
Current Time: Sat Jul 26 10:20:06 EDT 2025
Powered by FUDForum. Page generated in 0.03861 seconds
