Home » Language IDEs » C / C++ IDE (CDT) » Examples of using CDT...
Examples of using CDT... [message #73874] Mon, 23 June 2003 23:04 Go to next message
Originally posted by: mephri.infolink.co.id
Hi, I am very new to CDT. Could someone give me some examples (example
projects) of using the CDT under Linux? Thanks.
--meph++
Re: Examples of using CDT... [message #73892 is a reply to message #73874] Tue, 24 June 2003 02:52 Go to previous messageGo to next message
Is it possible to use a project which is previously created on a different
platform (e.g. QNX Momentics --> Linux)? Or vice versa?
--meph++
Re: Examples of using CDT... [message #73928 is a reply to message #73892] Tue, 24 June 2003 08:14 Go to previous messageGo to next message
Originally posted by: gcaglar.hotmail.com
It is pretty straightforward. You will start a new project with your
projects root directory. When you have the project in the Navigator as a C++
project, you will use Eclipse to modify the source code as if you were using
any editor. Makefiles or any other build tools are used to build to project,
and you get an interface to gdb to debug your program. So there is no reason
why you could not use Eclipse + CDT with any previously existing project.
The help files tell ou how to start a project.
Gokhan
"Mephri" <mephri@infolink.co.id> wrote in message
news:bd8sfs$1h2$1@rogue.oti.com...
> --meph++
Re: Examples of using CDT... [message #73946 is a reply to message #73928] Tue, 24 June 2003 23:40 Go to previous messageGo to next message
I see differences in QNX Momentics project files. There is no common.mk file
in Eclipse under Linux.
I've tried to use a project from QNX Momentics. The Linux IDE couldn't load
it.
--meph++
"Gokhan Caglar" <gcaglar@hotmail.com> wrote in message
news:bd9fbj$jq2$1@rogue.oti.com...
C++
using
project,
reason
> Gokhan
different
> > --meph++
Re: Examples of using CDT... [message #74002 is a reply to message #73946] Wed, 25 June 2003 12:40 Go to previous messageGo to next message
What's actually within that common.mk file?
How does it look like?
> it.
I can't see a difference between those environments yet.
Re: Examples of using CDT... [message #74037 is a reply to message #73946] Wed, 25 June 2003 13:53 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
The project created with QNX Momentics as a QNX project can not be used on
Linux. You should to write your own makefile.
news:bdb5k1$55n$1@rogue.oti.com...
file
load
> it.
> --meph++
> C++
> using
> project,
> reason
project.
> > Gokhan
> different
> > > --meph++
Re: Examples of using CDT... [message #74070 is a reply to message #74037] Wed, 25 June 2003 22:23 Go to previous message
That's exactly what I wanna be sure of. I asked this because we are planning
to develop projects on multiple platforms. Two of them are QNX Momentics and
SuSE Linux. We are sure to use QNX Momentics because currently we are using
QNX 4.5. We are looking forward the possibility of using Linux as well.
Thanks for the information...
--meph++
"Mikhail Khodjaiants" <mikhailk@qnx.com> wrote in message
news:bdcnp6$j7l$1@rogue.oti.com...
Previous Topic:make problems
Next Topic:enums in Outline View
Current Time: Tue Jul 22 09:14:02 EDT 2025
Powered by FUDForum. Page generated in 0.05283 seconds
