Home » Language IDEs » Java Development Tools (JDT) » build classpath and "run classpath"
build classpath and "run classpath" [message #73848] Tue, 08 July 2003 04:26 Go to next message
Originally posted by: bernard.leach.diamos.com
Hi all,
I have a project where I would like to use a different runtime classpath
to the build time classpaths of the projects it is dependent on. I had
hoped to use the "exported" classpath of each project and then add any
extra dependencies, as required, manually. However it seems that the
"default classpath" for a run item is the concatenation of the build
classpath for each dependent project.
The construction is a little strange in that if you uncheck the default
classpath, delete all items and then re-add the dependent projects you
only get the exported resources for each of these projects (which is
actually what I'd hoped for originally!).
Is this inconsistency the desired behaviour?
cheers,
bernard.
Re: build classpath and "run classpath" [message #73901 is a reply to message #73848] Tue, 08 July 2003 08:12 Go to previous messageGo to next message
Which version of eclipse are you using?
Roman
Re: build classpath and "run classpath" [message #74045 is a reply to message #73901] Thu, 10 July 2003 04:56 Go to previous message
> Roman
Sorry, 2.1.1.
Previous Topic:Eclipse and Java
Next Topic:Re: CVS Graph plugin for Eclipse available
Current Time: Tue Oct 14 12:00:38 EDT 2025
Powered by FUDForum. Page generated in 0.04504 seconds
