Home » Archived » Test and Performance Tools Platform (TPTP) » BIRT 2.1.0 distribution missing some plugin metadata?
BIRT 2.1.0 distribution missing some plugin metadata? [message #73807] Mon, 12 June 2006 07:35 Go to next message
I've installed the BIRT 2.1.0 zip (1) for TPTP 4.2.0 (as recommended
at bottom of (2)) to enable reporting from the <tptp:publication> ant
task and I noticed that on startup the Error Log is reporting a number
of errors installing BIRT bundles. For example:
Error
Mon Jun 12 12:09:49 BST 2006
Plugin does not have a valid version:
plugins/org.eclipse.datatools.modelbase.sql_0.9.0.200605101/
Error
plugins/org.eclipse.datatools.modelbase.sql.xml.query_0.9.0. 200605101/
Presumably these plugins are coming from DTP, and looking at the
offending plugin folders, they do seem to be missing Manifest files.
Has anyone else noticed this? Should TPTP be using a revised BIRT/DTP
distribution?
(1)
http://www.eclipse.org/downloads/download.php?file=/birt/dow nloads/drops/N-R1-N20060530-200605300632/birt-report-framewo rk-N20060530.zip
(2)
http://www.eclipse.org/tptp/home/downloads/drops/TPTP-4.2.0- 200605251528B.html
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #73916 is a reply to message #73807] Mon, 12 June 2006 15:05 Go to previous message
The DTP modelbase plugins, as included in the BIRT N20060530 build, are
indeed incomplete. The BIRT build should not have included these DTP
modelbase plugins in the first place.
They are no longer included since the BIRT 20060602 build.
A work-around is to manually remove all the DTP modelbase plugins from
your installation, since they are not used by BIRT.
Or, if you want to get the complete DTP plugins, download the version
distributed by DTP download page or the Callisto update site.
Linda
John O'Shea wrote:
> Error
> Error
> distribution?
> (1)
> (2)
Previous Topic:rounding issues ?
Next Topic:Running recorded GUI tests automatically
Current Time: Sat Oct 25 10:14:45 EDT 2025
Powered by FUDForum. Page generated in 0.03928 seconds
