AspectJ Log4J and log4j.appender.dest1.layout.ConversionPattern= %l%n%m%n [message #73693] |
Wed, 01 April 2009 16:00  |
OS Windows XP
EDI Eclipse 3.4.1
AspectJ version: 1.6.4.20090304172355
http://www.manning.com/laddad/
I take the code source from :
http://www.manning-source.com/books/laddad/laddad_src_Aspect j-In-Action.zip
Reconfigure it to do a Eclipse ready :
Here the new zip :
http://cjoint.com/?edvUgUpaLP
If I change nothing at the log4j.properties file, everything seen OK.
log4j.rootCategory=DEBUG, dest1
log4j.appender.dest1=org.apache.log4j.ConsoleAppender
log4j.appender.dest1.layout=org.apache.log4j.PatternLayout
Output :
Entering [usingLog4jToolkit.Test.main]
Entering [usingLog4jToolkit.Inventory.<init>]
Entering [usingLog4jToolkit.Item.<init>]
Entering [usingLog4jToolkit.Inventory.addItem]
Entering [usingLog4jToolkit.ShoppingCart.<init>]
Entering [usingLog4jToolkit.ShoppingCartOperator.addShoppingCartItem]
Entering [usingLog4jToolkit.Inventory.removeItem]
Entering [usingLog4jToolkit.ShoppingCart.addItem]
But if I add this line :
to the log4j.properties file.
log4j.properties is :
The output is not what I am looking for :
usingLog4jToolkit.TraceAspectV3.ajc$before$usingLog4jToolkit _TraceAspectV3$1$b314f86e(TraceAspectV3.aj:20)
Where my mistake.
Re: AspectJ Log4J and log4j.appender.dest1.layout.ConversionPattern= %l%n%m%n [message #73743 is a reply to message #73728] |
Thu, 02 April 2009 12:20  |
Originally posted by: andrew.eisenberg.springsource.com
> I try to use AspectJ to trace Java code source.
> What I am expecting to do, is to do Jump-to-code aware, the trace
> generated by AspectJ into the Eclipse console.
The output generated seems correct to me. It seems that you are wondering
why you can't use Eclipse's hyperlink capabilities to jump to the
declaration. This likely hasn't been implemented in AJDT. Does this work
when you remove the AJ nature from the project?
Please raise a bug for this in bugzilla. Also, please include any extra
plugins that you have installed. I am not exactly sure how the hyperlinking
for Log4J is implemented, but the functionality may come from another
plugin. And lastly, include the version of Eclipse you are using (are you
using RAD, STS, 3.3, 3.4, etc?).
Re: AspectJ Log4J and log4j.appender.dest1.layout.ConversionPattern= %l%n%m%n [message #599860 is a reply to message #73711] |
Thu, 02 April 2009 05:20  |
Hello Andrew,
>>What were you expecting to see?
With Log4J if you do :
package usingLog4jToolkit;
import org.apache.log4j.Logger;
//Listing 5.5 A test class
public class Test {
final static Logger log = Logger.getLogger("test");
log.info("Start Program");
etc
With this log4j.properties :
You have this outout into the Eclipse console windows :
usingLog4jToolkit.Test.main(Test.java:11)
Start Program
And if you click to (Test.java:11), you jump into the Java code :
What I try to do is the same thing with AspectJ
Pierre8r
Re: AspectJ Log4J and log4j.appender.dest1.layout.ConversionPattern= %l%n%m%n [message #599867 is a reply to message #73728] |
FUDForum. Page generated in 0.10565 seconds
