Home » Archived » BIRT » Alignment of labels in bar chart
Alignment of labels in bar chart [message #736587] Fri, 14 October 2011 02:17 Go to next message
Can anyone help me to find out how to align the labels of the bar chart at right side?
It looks fine bt when I run that report in web application,labels look improperly aligned..
please help me asap
I'm waiting..
Re: Alignment of labels in bar chart [message #737054 is a reply to message #736587] Fri, 14 October 2011 11:57 Go to previous messageGo to next message
Can you post an image of what it looks like in the web application?
Jason
On 10/14/2011 2:17 AM, gaurikate wrote:
> Hello,
> at right side?
> please help me asap
> I'm waiting..
Re: Alignment of labels in bar chart [message #739134 is a reply to message #737054] Mon, 17 October 2011 02:02 Go to previous messageGo to next message
Image chart2.png is the report run through birt report viewer and chart1.png is the report run in web application. Labels House , City etc. are not properly aligned. I want that to be right aligned. Is it possible?
Gauri
  • Attachment: chart1.png
    (Size: 27.32KB, Downloaded 534 times)
  • Attachment: chart2.png
    (Size: 71.17KB, Downloaded 352 times)
Re: Alignment of labels in bar chart [message #739451 is a reply to message #739134] Mon, 17 October 2011 09:48 Go to previous messageGo to next message
Right justified should be the default. Any chance you can reproduce
this with the sample data? What version of BIRT are you using? Are you
just calling the report engine through a servlet?
Jason
On 10/17/2011 2:02 AM, gaurikate wrote:
> Hello,
> Thanks
> Gauri
Re: Alignment of labels in bar chart [message #741008 is a reply to message #739451] Wed, 19 October 2011 00:58 Go to previous messageGo to next message
I'm using Birt 2.6..yes I am just calling report engine..
Re: Alignment of labels in bar chart [message #741420 is a reply to message #741008] Wed, 19 October 2011 10:06 Go to previous messageGo to next message
Can you reproduce the problem with sample data, so we can run and test
it? If so post the report.
Jason
Re: Alignment of labels in bar chart [message #742094 is a reply to message #741420] Thu, 20 October 2011 02:58 Go to previous messageGo to next message
I have attached the sample report.When I run this report using web application it is not properly aligned.
Plz help me.
Re: Alignment of labels in bar chart [message #742554 is a reply to message #742094] Thu, 20 October 2011 11:45 Go to previous message
When I run your report through my webapp (attached) it works fine.
A couple of things to try:
1 - change the report to fixed layout instead of auto (use General
properties for the report to change it)
2 - Turn off the center button in the grid containing cell.
Jason
> Plz help me.
  • Attachment: webapp.zip
    (Size: 2.58KB, Downloaded 358 times)
Previous Topic:use parameterPage tag to run report in same JSP page
Next Topic:BIRT 2.5.1 cuts off font at auto text when generating a PDF
Current Time: Sun Jul 27 09:18:57 EDT 2025
Powered by FUDForum. Page generated in 0.05373 seconds
