Home » Eclipse Projects » Eclipse 4 » E4 DI best practices(E4 DI best practices)
E4 DI best practices [message #736121] Thu, 13 October 2011 12:00 Go to next message
- In a ViewPart object, use e4 DI to use E4 services. Good and I'm sure it's a best
practice Wink
- In my Java objects called from ViewPart, e4 DI not available so i call my objects with a reference of my E4 service. Is it a best practice ?
- In my OSGI services,I can't use E4 services because IEclipseContext was created only for my E4 application.
Ok, so i don't use OSGI services and put all classes in my E4 application if i need e4 di ? Is there another solution ?
Re: E4 DI best practices [message #736191 is a reply to message #736121] Thu, 13 October 2011 15:01 Go to previous messageGo to next message
regarding your point 2.
There is a (or even several) way to inject e4 Services into Java objects.
Have a look at this tutorial www.vogella.de/articles/EclipseE4/article.html#programmingmodel_ownobjects
@Thanks to Lars for his good work on all his tutorials!
Re: E4 DI best practices [message #736204 is a reply to message #736121] Thu, 13 October 2011 15:42 Go to previous messageGo to next message
Am 13.10.11 18:00, schrieb jyl:
> it's a best
> practice ;)
I use ContextInjectionFactory.make/.... in my custom code as well. DI
should NOT end at your Part-class.
Well this is an open topic to me as well I'd really like us to get
access to the IEclipseContext in OSGi-Services as well. For single user
envs the solution is simple but I've not yet had an idea how to make
this work with multi-user envs so until today you have to live without
DI in OSGi-Services unless you implement the access your own.
Tom
Re: E4 DI best practices [message #787354 is a reply to message #736191] Tue, 31 January 2012 08:44 Go to previous messageGo to next message
Thanks Thomas for the recommendation. I recently reworked to tutorial. Its now available: Eclipse 4 Application Development.
It also describes how to use DI for POJO's, e.g. not objects based on the model.
Re: E4 DI best practices [message #834695 is a reply to message #787354] Mon, 02 April 2012 05:18 Go to previous messageGo to next message
Lars, Tom, a question
I tried the code in your tutorial, seems logic but in my case it doesn't work.
I need to use my PartHelper class in an OSGI Service.
My PartHelper class needs the following injected variables:
@Inject private EModelService modelService;
@Inject private MApplication application;
@Inject private EPartService partService;
Tried to put this code in my service:
Bundle bundle = FrameworkUtil.getBundle(getClass());
BundleContext bundleContext = bundle.getBundleContext();
IEclipseContext eclipseCtx = EclipseContextFactory.getServiceContext(bundleContext);
ContextInjectionFactory.make(PartHelper.class, eclipseCtx);
The MAKE doesn't work, it can't inject the parts obviously because I am in the wrong context. How can I access the application context from here? Is there a way to do it at all?
Laura
Re: E4 DI best practices [message #840793 is a reply to message #834695] Tue, 10 April 2012 10:14 Go to previous message
No you can't get access to applications IEclipseContext in an
OSGi-Service. The problem is that while in a desktop environment there's
(very likely a 1:1 relationship between a running OSGi and Application)
but as soon as you e.g. think about RAP this 1:1 relations is not true
any more.
The question now is why you are using the OSGi-Service to interact with
your application?
Tom
Am 02.04.12 11:18, schrieb Laura V:
> work.
> @Inject private MApplication application; @Inject private
> Thanks
> Laura
Previous Topic:Really need the book on this
Next Topic:Split application model
Current Time: Wed Jul 23 12:40:24 EDT 2025
Powered by FUDForum. Page generated in 0.07019 seconds
