Quirk in "Compare with Version in Ancestor" [message #736073] |
Thu, 13 October 2011 09:53  |
The very handy "Compare with Version in Ancestor" operation in Git views has a quirk that I think is a minor bug, unless I'm misunderstanding. Here's an example case I use every day:
1) Fetch changes
2) Open any of the fetched commits listed in the dialog [a great feature by the way]
3) Right-click any file in the 'Files' section and select "Compare with Version in Ancestor" from the popup menu
4) Expected: diff view; Observed: nothing happens
5) Close the commit view
6) Reopen the same commit using whatever means you prefer, for instance by double-clicking the entry the Reflog view
7) repeat step (3)
8) A diff view appears, as expected
Maybe there's a good reason why compare-with-ancestor should not work in step (3). If it is supposed to work I can file this as a bug
FUDForum. Page generated in 0.26920 seconds
