Home » Eclipse Projects » Plugin Development Environment (PDE) » productBuild.xml requiring unncessary plugins?
productBuild.xml requiring unncessary plugins? [message #731322] Fri, 30 September 2011 11:26 Go to next message
We have a build.xml that uses productBuild.xml
[java] Buildfile:
/home/david/opt2/eclipse/plugins/org.eclipse.pde.build_3.7.0.v20110512-1320/scripts///productBuild/productBuild.xml
[java] main:
[java] preBuild:
[java] [mkdir] Created dir: /home/david/pde/build
[java] preSetup:
[java] checkLocalMaps:
[java] getMapFiles:
[java] postSetup:
[java] checkLocalBase:
[java] getBaseComponents:
[java] processRepos:
[java] generateFeature:
[java] fetch:
Then some way down I get these errors.
[java] [eclipse.generateFeature] Bundle org.eclipse.net4j.buddies.chat:
[java] [eclipse.generateFeature] Another singleton version
selected: org.eclipse.net4j.buddies.chat_4.0.0.v20110516-1727
org.eclipse.emf.cdo.dawn.codegen.dawngenmodel.gmf.ui:
[java] [eclipse.generateFeature] Missing required plug-in
org.eclipse.emf.cdo.dawn.codegen.dawngenmodel.gmf.edit_[1.0.0,2.0.0).
org.eclipse.emf.cdo.dawn.codegen.dawngenmodel.gmf_[1.0.0,2.0.0).
org.eclipse.emf.cdo.server.db4o:
[java] [eclipse.generateFeature] Unsatisfied import package
com.db4o_[7.4.0,8.0.0).
com.db4o.config_[7.4.0,8.0.0).
com.db4o.constraints_[7.4.0,8.0.0).
com.db4o.ext_[7.4.0,8.0.0).
com.db4o.query_[7.4.0,8.0.0).
com.db4o.reflect_[7.4.0,8.0.0).
com.db4o.reflect.jdk_[7.4.0,8.0.0).
org.eclipse.emf.cdo.dawn.tests:
org.eclipse.swtbot.eclipse.core_[2.0.0,3.0.0).
org.eclipse.swtbot.eclipse.finder_[2.0.0,3.0.0).
org.eclipse.swtbot.eclipse.gef.finder_[2.0.0,3.0.0).
org.eclipse.swtbot.eclipse.spy_[2.0.0,3.0.0).
org.eclipse.swtbot.go_[2.0.0,3.0.0).
org.eclipse.swtbot.swt.finder_[2.0.0,3.0.0).
org.eclipse.emf.cdo.tests.ui_[4.0.0,5.0.0).
org.eclipse.emf.cdo.dawn.codegen.dawngenmodel.gmf.ui_1.0.0.
org.eclipse.emf.cdo.dawn.codegen.dawngenmodel.gmf.edit:
org.eclipse.net4j.db.postgresql:
org.postgresql_[8.3.0,9.0.0).
org.postgresql.ds_[8.3.0,9.0.0).
[java] [eclipse.generateFeature] Bundle org.eclipse.emf.cdo.tests.db:
org.eclipse.net4j.db.postgresql_[4.0.0,5.0.0).
org.postgresql.ds.common_[8.3.0,9.0.0).
org.postgresql.jdbc3_[8.3.0,9.0.0).
[java] [eclipse.generateFeature] Bundle org.eclipse.emf.cdo.tests.ui:
org.eclipse.emf.cdo.dawn.codegen.dawngenmodel.gmf:
org.eclipse.gmf.graphdef.codegen_[2.0.0,3.0.0).
org.eclipse.emf.cdo.tests.db4o:
org.eclipse.emf.cdo.server.db4o_1.0.0.
[java] BUILD FAILED
[java]
/home/david/opt2/eclipse/plugins/org.eclipse.pde.build_3.7.0.v20110512-1320/scripts/productBuild/productBuild.xml:39:
The following error occurred while executing this line:
[java]
/home/david/opt2/eclipse/plugins/org.eclipse.pde.build_3.7.0.v20110512-1320/scripts/productBuild/productBuild.xml:69:
Bundle org.eclipse.net4j.db.postgresql_4.0.0.v20110607-1031 failed to
resolve.:
[java] Unsatisfied import package org.postgresql_[8.3.0,9.0.0).
[java] Unsatisfied import package org.postgresql.ds_[8.3.0,9.0.0).
[java] Total time: 15 seconds
[java] An error has occurred. See the log file
[java] /home/david/workspace/.metadata/.log.
I am perplexed as to why. Because I have CDO installed and it is a part
of the bundle, but I do not have some optional parts of CDO installed,
like Dawn, DB40 support, Postgres support. I don't need them and they
are definitely not a part of my dependencies in MANIFEST.MF and
plugin.xml So to be clear none of the missing plugins here are used by
my plugin. So why is it trying to include them? Is there a way I can
find out where these dependencies come from?
Thx.
David
Re: productBuild.xml requiring unncessary plugins? [message #731355 is a reply to message #731322] Fri, 30 September 2011 13:08 Go to previous messageGo to next message
Found the reason for the errors below, dropins/plugin was used by my
collegue and he only had one required plugin there, I had all of CDO
there. By removing that I have far fewer errors.
Not sure why it is trying to include a source file plugin?
Caused by:
Unable to find plug-in: org.eclipse.core.filesystem.source_0.0.0. Please
check the error log for more details.
at
org.eclipse.pde.internal.build.tasks.FeatureGeneratorTask.execute(FeatureGeneratorTask.java:38)
Ideas?
Thx.
David
On 30/09/11 16:26, David Wynter wrote:
> [java] Buildfile:
> [java] main:
> [java] preBuild:
> [java] preSetup:
> [java] getMapFiles:
> [java] postSetup:
> [java] fetch:
> [java] [eclipse.generateFeature] Another singleton version selected:
> [java] [eclipse.generateFeature] Bundle org.eclipse.emf.cdo.server.db4o:
> [java] [eclipse.generateFeature] Bundle org.eclipse.emf.cdo.dawn.tests:
> [java] [eclipse.generateFeature] Bundle org.eclipse.net4j.db.postgresql:
> [java] [eclipse.generateFeature] Bundle org.eclipse.emf.cdo.tests.db4o:
> [java] BUILD FAILED
> [java]
> [java]
> resolve.:
> Thx.
> David
Re: productBuild.xml requiring unncessary plugins? [message #735964 is a reply to message #731355] Thu, 13 October 2011 04:46 Go to previous messageGo to next message
Still cannot build my bundle due to the error below. Leaving aside why
productBuild.xml would include a source file plugin. I am not sure
where I can find this org.eclipse.core.filesystem.source_0.0.0 plugin?
Any pointers?
Thx.
David
On 30/09/11 18:08, David Wynter wrote:
> Caused by:
> at
> Ideas?
> Thx.
> David
>> Hi,
>> [java] Buildfile:
>> [java] main:
>> [java] preBuild:
>> [java] preSetup:
>> [java] getMapFiles:
>> [java] postSetup:
>> [java] fetch:
>> [java] BUILD FAILED
>> [java]
>> [java]
>> resolve.:
>> Thx.
>> David
Re: productBuild.xml requiring unncessary plugins? [message #889375 is a reply to message #735964] Tue, 19 June 2012 03:11 Go to previous message
Hi David,
I've got the same problem you described, but my missing plugin is commons-beanutils.
I think it has nothing to do with the productBuild itself but with the plugins defining your build-base or the plugins defined in your product.
Have you found a solution? If so, please tell me so that I can resolve my problem too.
target_eclipse/plugins/org.eclipse.pde.build_3.7.0.v20111116-2009/scripts/productBuild/productBuild.xml:69: Unable to find plug-in: commons.beanutils_0.0.0. Please check the error log for more details.
Many thanks,
Alex
Previous Topic:the problem of rcp project move from JDK 32bit to jdk 64bit
Next Topic:VerticalRuler
Current Time: Sat Jul 26 00:26:31 EDT 2025
Powered by FUDForum. Page generated in 0.04233 seconds
