Home » Archived » Jubula » Problems with parameters in a test case hierarchy
Problems with parameters in a test case hierarchy [message #735936] Thu, 13 October 2011 03:05 Go to next message
I have problems with references to parameters in a test case hierarchy. I want to do exactly as done in the unbound module complex_app_init (found in Actions (complex)/Init Application).
I create a parameter in a test case and want to transfer the parameter to a another test case, but when trying to create a new parameter of the received parameter then I get the error code "9507: It is not allowed to use references in original testcases."
Anyone who has a clue of what the problem is?
When creating modules for re-use it normally ends up with a hierarchy of test cases, and I want it to be a simple as possible to change the parameters used in all the test steps.
Regards Richard
Re: Problems with parameters in a test case hierarchy [message #735951 is a reply to message #735936] Thu, 13 October 2011 04:04 Go to previous message
Hi Richard,
you have to reuse the referenced test case first in order to parametrize. You can manage the parameters of a test case via "Edit Parameters" (right click on test case or ctrl-shift-a). For further information on using parameters check this link: http://help.eclipse.org/indigo/topic/org.eclipse.jubula.client.ua.help/html/manual/node107.html
Oliver
Previous Topic:AUT agent not starting
Next Topic:can't create new project
Current Time: Thu Jul 24 21:28:09 EDT 2025
Powered by FUDForum. Page generated in 0.24862 seconds
