AccessControlException using LTW in a custom classloader with a security manager [message #73570] |
Fri, 20 March 2009 19:47  |
Hi, I am using LTW in a custom classloader. The application is running
under a security manager which gives AllPermissions to aspectj but
restricted permissions to the classes defined by the custom classloader
i.e. the classes loaded by the custom classloader are in a sandbox.
When instantiating a sandboxed class, I receive an AccessControlException
because aspectj is performing an operation for which the sandboxed class
(which is also on the stack) does not have permission.
I don't want to hack the aspectj code to wrap calls to Class/ClassLoader
in doPrivileged. Is there another way to make this work?
I am using aspectj 1.5.4
Stack trace:
Caused by: java.security.AccessControlException: access denied
(java.lang.RuntimePermission getClassLoader)
at
java.security.AccessControlContext.checkPermission(AccessCon trolContext.java:264)
at
java.security.AccessController.checkPermission(AccessControl ler.java:427)
at java.lang.SecurityManager.checkPermission(SecurityManager.ja va:532)
at java.lang.Class.getClassLoader(Class.java:588)
at org.aspectj.runtime.reflect.Factory.<init>(Factory.java:71)
at MySandboxedClass.<clinit>(MySandboxedClass.java:1)
Thanks.
Re: AccessControlException using LTW in a custom classloader with a security manager [message #73589 is a reply to message #73570] |
Sat, 21 March 2009 17:27  |
Originally posted by: andrew.eisenberg.springsource.com
1.5.4 is a very old version of AspectJ. Try upgrading to 1.6.3 or later.
Not sure if this will work, but that is the first thing I'd try. If you
continue to have problems, send a message to the AspectJ user's mailing
list:
http://www.eclipse.org/aspectj/userlists.php
On 20/03/09 4:47 PM, in article
b0a1ec43e1e50206dad6e90a51c7a839$1@www.eclipse.org, "steve"
> Stack trace:
> at
> 64)
> at
> Thanks.
Re: AccessControlException using LTW in a custom classloader with a security manager [message #599806 is a reply to message #73570] |
list:
> Stack trace:
> at
> 64)
> at
> Thanks.
FUDForum. Page generated in 0.04701 seconds
