Project repeated under working set [message #735170] |
Tue, 11 October 2011 03:16  |
Hello, I wanted to use working sets to put my projects into categories. Something odd is going on, though, because when I am in the C/C++ perspective and have set the project explorer to show working sets as top-level elements, any open CDT project is listed twice. And the context menu for such a repeated project has several duplicated menu items if one selects the context menu of the second one.
See attachment for screenshot.
I am new to CDT but have used Eclipse for Java and Python a few years now.
As I was writing this, I noticed a view called C/C++ projects and I tried to use that one instead of Project explorer. It seems to be able to show a flat list of the selected working sets, but the list of working sets it displays when presses the little down-arrow button is not complete, and one has to open the dialog (Select Working Set...) instead if one wants to select a working set not shown in the list. Not so user-friendly I feel.
Ideally, I would like to group my projects into working sets and have those at the top level in the project explorer, and when in the C/C++ perspective I would only see the working sets I have set as relevant for that perspective.
I tried this on both Windows and Linux, same behavior. I am using Eclipse SDK 3.7.1 with CDT 8.0.1.
Thank you for reading and thanks in advance for any help!
[Updated on: Tue, 11 October 2011 03:17] by Moderator
Re: Project repeated under working set [message #735999 is a reply to message #735929] |
Thu, 13 October 2011 06:39  |
Axel Mueller wrote on Thu, 13 October 2011 02:50Looks like a problem in the pydev plugin. You should report the author of that plugin the bug.
I've reported it to the pydev project. Hopefully the specific cause of this problem can be identified and fixed in short order. Thanks for your help in narrowing this problem down!
FUDForum. Page generated in 0.22145 seconds
