Home » Language IDEs » C / C++ IDE (CDT) » __STDC__ always defined in CDT??(Source Parsing)
__STDC__ always defined in CDT?? [message #735594] Wed, 12 October 2011 06:11 Go to next message
It seems the symbol __STDC__ is always defined while source parsing.
Compiling of the source does not define the symbol __STDC__.
How can I disable this feature?
reproduction (Eclipse Indigo):
1. create a new C or C++ project.
2. create a new file with following content
//#undef __STDC__
#if !__STDC__
#define TEST "TEST"
#endif
"#define TEST" is shown as unreachable. But if you uncomment "#undef __STDC__" the statement is getting reachable ?!
Gert
Re: __STDC__ always defined in CDT?? [message #735639 is a reply to message #735594] Wed, 12 October 2011 09:10 Go to previous messageGo to next message
AFAIK, CDT gets the symbol from the debugger (aka Scanner Discovery). Create an empty source file test.c and call on the command line
gcc -E -P -dD test.c
This will show you the default predefined symbols (for gcc!).
Re: __STDC__ always defined in CDT?? [message #735644 is a reply to message #735594] Wed, 12 October 2011 09:10 Go to previous messageGo to next message
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
Re: __STDC__ always defined in CDT?? [message #735655 is a reply to message #735644] Wed, 12 October 2011 09:41 Go to previous messageGo to next message
Sorry, I forgot to tell! I use the Microsoft Visual C++ tool chain with CDT Internal Builder. So gcc is no option for me.
Regards, Gert
Re: __STDC__ always defined in CDT?? [message #735927 is a reply to message #735655] Thu, 13 October 2011 02:47 Go to previous messageGo to next message
Gert.Grossmann wrote on Wed, 12 October 2011 15:41
Regards, Gert
Visual C++ defines __STDC__, too.
http://msdn.microsoft.com/en-us/library/b0084kay(v=vs.80).aspx
You can try to remove the symbol from Project Properties->C/C++ General->Paths and Symbols
Re: __STDC__ always defined in CDT?? [message #735937 is a reply to message #735927] Thu, 13 October 2011 03:06 Go to previous message
But Visual C++ does this symbol only define if /Za is on and we're not compiling C++ code.
So this define should depend on compiler switch /Za (switchable via Visual C++ Tool Chain)
Regards, Gert
Previous Topic:pre-build stripping backslashes in SubWCRev cmd
Next Topic:Project repeated under working set
Current Time: Wed Jul 30 14:11:57 EDT 2025
Powered by FUDForum. Page generated in 0.04100 seconds
