Home » Eclipse Projects » EclipseLink » Possible to return a ref cursor from Oracle function using StoredFunctionCall?
Possible to return a ref cursor from Oracle function using StoredFunctionCall? [message #557099] Sat, 04 September 2010 06:31 Go to next message
Hi all,
Is it possible to use StoredFunctionCall to execute an Oracle stored function that returns a ref cursor? I've not been able to find any information on how this can be done. I've written the following sample code but it fails to work (getting a "PLS-00306: wrong number or types of arguments" error despite my arguments being correct). The failure occurs on "session.executeQuery(query)".
StoredFunctionCall call = new StoredFunctionCall();
call.setProcedureName("MY_FUNCTION");
call.setResult("REF_CURSOR");
call.addNamedArgumentValue("FROM_DATE", dateFrom);
call.addNamedArgumentValue("TO_DATE", dateTo);
call.addNamedArgumentValue("NAME", "myname")
ValueReadQuery query = new ValueReadQuery();
query.setCall(call);
session.executeQuery(query);
I have to add that I have executed the "my_function" Oracle function successfully using plain JDBC and OracleCallableStatement so I can confirm the function is fine. I have also switched "dateFrom" and "dateTo" from "java.util.Date" to "java.sql.Date" as I thought perhaps these were causing the error but it didn't make a difference.
Unfortunately there are no real solid examples of how to return a ref cursor from an Oracle function using StoredFunctionCall. Can any help and give me pointers? Thanks in advance.
John
Re: Possible to return a ref cursor from Oracle function using StoredFunctionCall? [message #557474 is a reply to message #557099] Tue, 07 September 2010 10:46 Go to previous messageGo to next message
This can be done using a StoredProcedureCall using,
useNamedCursorOutputAsResultSet()
or,
useUnnamedCursorOutputAsResultSet()
I'm not sure if it works with StoreFunctionCall,
try,
If it does not work, please log a bug, and as a workaround convert the function to a procedure.
Re: Possible to return a ref cursor from Oracle function using StoredFunctionCall? [message #735629 is a reply to message #557099] Wed, 12 October 2011 08:31 Go to previous message
No real name wrote on Sat, 04 September 2010 06:31
Hi all,
John
Still not possible or what? Why have "StoredFunctionCall" then? I can do this using "select function() from dual" and then resultset.next();rs=(ResultSet)resultset.getObject(1) to get the real result set... but this way I cannot map the ResultSet to the @entity. Darn.
edit: Also, sorry for "necroing" but I cannot find any useful resources on this, teh same as OP.
[Updated on: Wed, 12 October 2011 08:32] by Moderator
Re: Possible to return a ref cursor from Oracle function using StoredFunctionCall? [message #735664 is a reply to message #557099] Wed, 12 October 2011 08:31 Go to previous message
> Hi all,
> John
Previous Topic:Extensible Entities
Next Topic:Cached Ordered Lists have null inserted during 2nd update
Current Time: Fri Jul 25 21:38:19 EDT 2025
Powered by FUDForum. Page generated in 1.06381 seconds
