Home » Archived » Jubula » External execute command
External execute command [message #707134] Mon, 01 August 2011 05:33 Go to next message
I m working with Jubula on OpenSusse and I would like during my test, open the konsole and make some command (like ls), get back the result and check it with Jubula if it's the good result.
I think that I must use the "external execute command", but can you give me more informations, like where can I defined the expected result in Jubula?
Mich Mich
Re: External execute command [message #707279 is a reply to message #707134] Mon, 01 August 2011 08:32 Go to previous messageGo to next message
"Execute external command" just checks for the return code, i.e. it checks if the command returns successful. You may add your expected result as data (via a parameter) to a shell script and do the comparison inside the script.
Achim
Re: External execute command [message #707905 is a reply to message #707134] Tue, 02 August 2011 03:47 Go to previous messageGo to next message
For more information on how to use "execute external command" check this link: http://help.eclipse.org/indigo/topic/org.eclipse.jubula.client.ua.help/html/reference/node13.html
Oliver
Re: External execute command [message #735384 is a reply to message #707134] Tue, 11 October 2011 12:06 Go to previous messageGo to next message
Hello, I'm trying to execute Sikuli X scripts from Jubula and have tried the external execute command.
I've made a .cmd file which executes Sikuli
java -jar D:\testtools\SikuliX\sikuli-script.jar ..\ckickTest.sikuli
It launches from commandline and does what it's supposed to do.
I've then tried to call the .cmd file from Jubula as described in the link above
I've set the properties on the command like this:
index.php/fa/4224/0/
and get this error when I execute the test:
index.php/fa/4225/0/
Two questions:
- What am I doing wrong?
- Is there a better way to do what I try to do? Wink
Re: External execute command [message #735542 is a reply to message #735384] Wed, 12 October 2011 03:01 Go to previous messageGo to next message
try to insert "D:\\sikuliscripts\\runInSikuli.cmd", this should start the external command.
Oliver
Re: External execute command [message #735546 is a reply to message #735542] Wed, 12 October 2011 03:24 Go to previous messageGo to next message
Thanks, works like a charm. Smile
Re: External execute command [message #740158 is a reply to message #735546] Tue, 18 October 2011 04:11 Go to previous message
The combination of Jubula and Sikuli sounds interesting - have you thought of participating in the "Pimp your Jubula" competition at Eclipse Con Europe?
http://pimpyourjubula.eventbrite.com/
Maybe see you there...
Alex
Previous Topic:can't create new project
Next Topic:Timeout error when starting webapplication Error 408
Current Time: Sat Jul 26 20:27:54 EDT 2025
Powered by FUDForum. Page generated in 0.03930 seconds
