Home » Eclipse Projects » WindowBuilder » WB Bindings Not Working Properly(After updating to WB 1.1.0 ... and SWT Designer 1.1.0 ...)
WB Bindings Not Working Properly [message #735067] |
Mon, 10 October 2011 16:10  |
I have an RCP application with multiple plugins running for the last six months without any problems. We update our Eclipse 3.6.2 with the WB 1.1.0 ... and SWT Designer 1.1.0 ... and the binding in our viewer starting to behave strangely.
We have multiple Views with a tableviewer and a few text boxes each. We binded the tableviewer so when selecting a row on the table the data selected shows in the text boxes. This worked for the last six months. Now we updated to version 1.1.0 ... (WB and SWT Designer) and ran the application, now when we select a row in the said table for the first time the data is shown in the text boxes; if we select another row, the text boxes are no longer updating to the new selected values.
What is wrong? It worked before (verion 1.0.0 ...) but now is different. I have not found anything different in the documentation. I am sure that I am missing something with the new version, but I cannot figure out what it is.
Any help will be appreciated.
eric
Re: WB Bindings Not Working Properly [message #735445 is a reply to message #735083] |
Tue, 11 October 2011 16:23   |
Hi Eric,
Thank you for your response.
Quote:Did the code for your app change? If so, what exactly changed?
Nothing changed, I just upgraded and recompiled.
Quote:Did you change your Eclipse version at all?
Same version.
Here is my code:
Database access through Annotations and Hibernate (Its own plugin)
package edu.unmc.cns.condb.model.hibernate.db;
import javax.persistence.Column;
import javax.persistence.GeneratedValue;
import static javax.persistence.GenerationType.IDENTITY;
import javax.persistence.Id;
import javax.persistence.MappedSuperclass;
import edu.unmc.cns.condb.model.AbstractModelObject;
* AbstractDistributionType entity provides the base persistence definition of
* the DistributionType entity.
* @author eric
@MappedSuperclass
public abstract class AbstractDistributionType extends AbstractModelObject implements java.io.Serializable {
// Fields
private Integer distributionTypeID;
private String distributionType;
private String description;
// Constructors
/** default constructor */
public AbstractDistributionType() {
/** minimal constructor */
public AbstractDistributionType(String distributionType) {
this.distributionType = distributionType;
// Property accessors
@Id
@GeneratedValue(strategy = IDENTITY)
@Column(name = "distributiontype_id", unique = true, nullable = false, updatable = false)
public Integer getDistributionTypeID() {
return this.distributionTypeID;
public void setDistributionTypeID(Integer distributionTypeID) {
this.distributionTypeID = distributionTypeID;
@Column(name = "distributiontype", unique = true, nullable = false, length = 50, updatable = false)
public String getDistributionType() {
return this.distributionType;
public void setDistributionType(String distributionType) {
@Column(name = "description", length = 50, updatable = false)
public String getDescription() {
return this.description;
public void setDescription(String description) {
this.description = description;
public String toString(){
import javax.persistence.Entity;
import javax.persistence.Table;
* DistributionType entity.
* @author eric
@Entity
@Table(name = "tbldistributiontypes", schema = "public")
public class DistributionType extends AbstractDistributionType implements java.io.Serializable {
// Constructors
public DistributionType() {
public DistributionType(String distributionType) {
super(distributionType);
Distribution Plugin...
Model for the bindings.
package edu.unmc.cns.mcnp.distribution.model;
import java.util.ArrayList;
import java.util.List;
import edu.unmc.cns.condb.model.hibernate.db.DistributionType;
* @author eric
public class DistributionTypes extends AbstractModelObject {
private List<DistributionType> distributionTypes = new ArrayList<DistributionType>();
public DistributionTypes() {
// TODO Auto-generated constructor stub
* @return the distributionTypes
public List<DistributionType> getDistributionTypes() {
return distributionTypes;
* @param distributionTypes
* the distributionTypes to set
public void setDistributionTypes(List<DistributionType> distributionTypes) {
this.distributionTypes = distributionTypes;
firePropertyChange("distributionTypes", null, distributionTypes);
public void addDistributionType(DistributionType dtype) {
this.distributionTypes.add(dtype);
public void removeDistributionType(DistributionType dtype) {
this.distributionTypes.remove(dtype);
import java.beans.PropertyChangeListener;
import java.beans.PropertyChangeSupport;
* @author eric
public class AbstractModelObject {
private final PropertyChangeSupport propertyChangeSupport = new PropertyChangeSupport(this);
public void addPropertyChangeListener(PropertyChangeListener listener) {
propertyChangeSupport.addPropertyChangeListener(listener);
public void addPropertyChangeListener(String propertyName, PropertyChangeListener listener) {
propertyChangeSupport.addPropertyChangeListener(propertyName, listener);
public void removePropertyChangeListener(PropertyChangeListener listener) {
propertyChangeSupport.removePropertyChangeListener(listener);
public void removePropertyChangeListener(String propertyName, PropertyChangeListener listener) {
propertyChangeSupport.removePropertyChangeListener(propertyName, listener);
protected void firePropertyChange(String propertyName, Object oldValue, Object newValue) {
propertyChangeSupport.firePropertyChange(propertyName, oldValue, newValue);
The view part and a controller.
package edu.unmc.cns.mcnp.distribution.view;
import org.eclipse.jface.action.IMenuManager;
import org.eclipse.jface.action.IToolBarManager;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.TableViewerColumn;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.FormAttachment;
import org.eclipse.swt.layout.FormData;
import org.eclipse.swt.layout.FormLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Group;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.Text;
import org.eclipse.ui.part.ViewPart;
import com.swtdesigner.SWTResourceManager;
import edu.unmc.cns.mcnp.distribution.view.controller.DistributionTypeViewController;
public class DistributionTypeView extends ViewPart {
public static final String ID = "edu.unmc.cns.mcnp.distribution.view.DistributionTypeView_ID"; //$NON-NLS-1$
private Group grpDistributionTypeList;
private Label lblManageDistributionType;
private Table tbldistrotype;
private TableViewer tableViewer;
private TableColumn tblclmnId;
private TableViewerColumn tableViewerColumn;
private TableColumn tblclmnType;
private TableViewerColumn tableViewerColumn_1;
private TableColumn tblclmnDescription;
private TableViewerColumn tableViewerColumn_2;
private TableColumn tblclmnLastUpdated;
private TableViewerColumn tableViewerColumn_3;
private Group grpEditDistributionType;
private Label lblDistributionType;
private Text txtDistributiontype;
private Label lblDescription;
private Text txtDescription;
private Composite composite;
private Label label;
private Label label_1;
private Button btnSave;
private Label label_2;
private Button btnClear;
private boolean newrecord = true;
private DistributionTypeViewController m_controller;
public DistributionTypeView() {
* Create contents of the view part.
* @param parent
public void createPartControl(Composite parent) {
Composite container = new Composite(parent, SWT.NONE);
container.setLayout(new FormLayout());
this.grpDistributionTypeList = new Group(container, SWT.NONE);
this.grpDistributionTypeList.setText("Distribution Type List");
this.grpDistributionTypeList.setLayout(new GridLayout(1, false));
FormData fd_grpDistributionTypeList = new FormData();
fd_grpDistributionTypeList.bottom = new FormAttachment(50);
fd_grpDistributionTypeList.right = new FormAttachment(100, -10);
fd_grpDistributionTypeList.top = new FormAttachment(0, 10);
fd_grpDistributionTypeList.left = new FormAttachment(0, 10);
this.grpDistributionTypeList.setLayoutData(fd_grpDistributionTypeList);
this.lblManageDistributionType = new Label(this.grpDistributionTypeList, SWT.NONE);
this.lblManageDistributionType.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, false, false, 1, 1));
this.lblManageDistributionType.setText("Manage Distribution Type");
this.lblManageDistributionType.setFont(SWTResourceManager.getFont("Tahoma", 12, SWT.BOLD));
tableViewer = new TableViewer(this.grpDistributionTypeList, SWT.BORDER | SWT.FULL_SELECTION);
this.tbldistrotype = tableViewer.getTable();
this.tbldistrotype.setLinesVisible(true);
this.tbldistrotype.setHeaderVisible(true);
this.tbldistrotype.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true, 1, 1));
tableViewerColumn = new TableViewerColumn(this.tableViewer, SWT.NONE);
this.tblclmnId = tableViewerColumn.getColumn();
this.tblclmnId.setWidth(50);
this.tblclmnId.setText("ID");
tableViewerColumn_1 = new TableViewerColumn(this.tableViewer, SWT.NONE);
this.tblclmnType = tableViewerColumn_1.getColumn();
this.tblclmnType.setWidth(150);
this.tblclmnType.setText("Type");
tableViewerColumn_2 = new TableViewerColumn(this.tableViewer, SWT.NONE);
this.tblclmnDescription = tableViewerColumn_2.getColumn();
this.tblclmnDescription.setWidth(200);
this.tblclmnDescription.setText("Description");
tableViewerColumn_3 = new TableViewerColumn(this.tableViewer, SWT.NONE);
this.tblclmnLastUpdated = tableViewerColumn_3.getColumn();
this.tblclmnLastUpdated.setWidth(100);
this.tblclmnLastUpdated.setText("Last Updated");
this.grpEditDistributionType = new Group(container, SWT.NONE);
this.grpEditDistributionType.setText("Edit Distribution Type");
this.grpEditDistributionType.setLayout(new GridLayout(2, false));
FormData fd_grpEditDistributionType = new FormData();
fd_grpEditDistributionType.bottom = new FormAttachment(100, -10);
fd_grpEditDistributionType.right = new FormAttachment(this.grpDistributionTypeList, 0, SWT.RIGHT);
fd_grpEditDistributionType.top = new FormAttachment(this.grpDistributionTypeList, 5);
fd_grpEditDistributionType.left = new FormAttachment(this.grpDistributionTypeList, 0, SWT.LEFT);
this.grpEditDistributionType.setLayoutData(fd_grpEditDistributionType);
this.lblDistributionType = new Label(this.grpEditDistributionType, SWT.NONE);
this.lblDistributionType.setLayoutData(new GridData(SWT.RIGHT, SWT.CENTER, false, false, 1, 1));
this.lblDistributionType.setText("Distribution Type");
this.txtDistributiontype = new Text(this.grpEditDistributionType, SWT.BORDER);
this.txtDistributiontype.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
this.lblDescription = new Label(this.grpEditDistributionType, SWT.NONE);
this.lblDescription.setText("Description");
this.txtDescription = new Text(this.grpEditDistributionType, SWT.BORDER);
this.txtDescription.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
this.composite = new Composite(this.grpEditDistributionType, SWT.NONE);
this.composite.setLayout(new FillLayout(SWT.HORIZONTAL));
GridData gd_composite = new GridData(SWT.FILL, SWT.CENTER, false, false, 1, 1);
gd_composite.heightHint = 32;
this.composite.setLayoutData(gd_composite);
this.label = new Label(this.composite, SWT.NONE);
this.label_1 = new Label(this.composite, SWT.NONE);
this.btnSave = new Button(this.composite, SWT.NONE);
this.btnSave.setText("Save");
this.btnSave.setEnabled(false);
this.label_2 = new Label(this.composite, SWT.NONE);
this.btnClear = new Button(this.composite, SWT.NONE);
this.btnClear.setText("Clear");
m_controller = new DistributionTypeViewController(this);
createActions();
initializeToolBar();
initializeMenu();
* Create the actions.
private void createActions() {
// Create the actions
* Initialize the toolbar.
private void initializeToolBar() {
IToolBarManager toolbarManager = getViewSite().getActionBars().getToolBarManager();
* Initialize the menu.
private void initializeMenu() {
IMenuManager menuManager = getViewSite().getActionBars().getMenuManager();
public void setFocus() {
// Set the focus
public TableViewer getTableViewer() {
return tableViewer;
public Text getTxtDistributiontype() {
return txtDistributiontype;
public Text getTxtDescription() {
return txtDescription;
package edu.unmc.cns.mcnp.distribution.view.controller;
import edu.unmc.cns.condb.model.hibernate.db.dao.DistributionTypeDAO;
import edu.unmc.cns.mcnp.distribution.model.DistributionTypes;
import edu.unmc.cns.mcnp.distribution.view.DistributionTypeView;
import org.eclipse.core.databinding.DataBindingContext;
import org.eclipse.jface.databinding.viewers.ObservableListContentProvider;
import org.eclipse.core.databinding.observable.map.IObservableMap;
import org.eclipse.core.databinding.beans.BeansObservables;
import org.eclipse.jface.databinding.viewers.ObservableMapLabelProvider;
import org.eclipse.core.databinding.observable.list.IObservableList;
import org.eclipse.core.databinding.observable.Realm;
import org.eclipse.core.databinding.observable.value.IObservableValue;
import org.eclipse.jface.databinding.viewers.ViewersObservables;
import org.eclipse.jface.databinding.swt.SWTObservables;
* @author eric
public class DistributionTypeViewController {
private DataBindingContext m_bindingContext;
private DistributionTypeView m_distributionTypeView = null;
private DistributionType m_distributionType = new DistributionType();
private DistributionTypes m_distributiontypes = new DistributionTypes();
public DistributionTypeViewController(DistributionTypeView m_distributionTypeView) {
this.m_distributionTypeView = m_distributionTypeView;
initializeData();
m_bindingContext = initDataBindings();
private void initializeData() {
DistributionTypeDAO dao = new DistributionTypeDAO();
List<DistributionType> types = dao.findAll();
for (DistributionType dtype : types) {
this.m_distributiontypes.addDistributionType(dtype);
* @param m_distributionTypeView
* the m_distributionTypeView to set
public void setM_distributionTypeView(DistributionTypeView m_distributionTypeView) {
* @return the m_distributionTypeView
public DistributionTypeView getM_distributionTypeView() {
return m_distributionTypeView;
* @param m_distributiontypes
* the m_distributiontypes to set
public void setM_distributiontypes(DistributionTypes m_distributiontypes) {
this.m_distributiontypes = m_distributiontypes;
* @return the m_distributiontypes
public DistributionTypes getM_distributiontypes() {
return m_distributiontypes;
protected DataBindingContext initDataBindings() {
DataBindingContext bindingContext = new DataBindingContext();
ObservableListContentProvider listContentProvider = new ObservableListContentProvider();
m_distributionTypeView.getTableViewer().setContentProvider(listContentProvider);
IObservableMap[] observeMaps = BeansObservables.observeMaps(listContentProvider.getKnownElements(), DistributionType.class, new String[]{"distributionTypeID", "distributionType", "description", "ctlUpdDTTM"});
m_distributionTypeView.getTableViewer().setLabelProvider(new ObservableMapLabelProvider(observeMaps));
IObservableList distributiontypesDistributionTypesObserveList = BeansObservables.observeList(Realm.getDefault(), m_distributiontypes, "distributionTypes");
m_distributionTypeView.getTableViewer().setInput(distributiontypesDistributionTypesObserveList);
IObservableValue distributionTypeViewgetTxtDistributiontypeObserveTextObserveWidget = SWTObservables.observeText(m_distributionTypeView.getTxtDistributiontype(), SWT.Modify);
IObservableValue distributionTypeViewgetTableViewerObserveSingleSelection = ViewersObservables.observeSingleSelection(m_distributionTypeView.getTableViewer());
IObservableValue distributionTypeViewgetTableViewerDistributionTypeObserveDetailValue = BeansObservables.observeDetailValue(distributionTypeViewgetTableViewerObserveSingleSelection, DistributionType.class, "distributionType", String.class);
bindingContext.bindValue(distributionTypeViewgetTxtDistributiontypeObserveTextObserveWidget, distributionTypeViewgetTableViewerDistributionTypeObserveDetailValue, null, null);
IObservableValue distributionTypeViewgetTxtDescriptionObserveTextObserveWidget = SWTObservables.observeText(m_distributionTypeView.getTxtDescription(), SWT.Modify);
IObservableValue distributionTypeViewgetTableViewerObserveSingleSelection_1 = ViewersObservables.observeSingleSelection(m_distributionTypeView.getTableViewer());
IObservableValue distributionTypeViewgetTableViewerDescriptionObserveDetailValue = BeansObservables.observeDetailValue(distributionTypeViewgetTableViewerObserveSingleSelection_1, DistributionType.class, "description", String.class);
bindingContext.bindValue(distributionTypeViewgetTxtDescriptionObserveTextObserveWidget, distributionTypeViewgetTableViewerDescriptionObserveDetailValue, null, null);
return bindingContext;
Like I stated before, this has been working for the last six months. There has been no changes to the code nor we have updated the Eclipse version.
Hope this help.
Thanks again for your help.
eric
Re: WB Bindings Not Working Properly [message #735658 is a reply to message #735653] |
Wed, 12 October 2011 09:45  |
I'm not sure what you mean by "I recompile the source code with the new version (1.1)." Upgrading WindowBuilder would not cause a recompile and would have no effect on recompilation if triggered manually. WindowBuilder is a development tool, so it would not appear on your classpath and would not be a dependency for your project.
Did you use WindowBuilder to modify the source code in some way. You stated that your source code had not changed which implies that WindowBuilder did nothing to it to alter its behavior. Something does not add up here. Either your source code has changed or something on your classpath has changed. Posting your project classpath might help.
Current Time: Sat Jul 26 11:45:47 EDT 2025
Powered by FUDForum. Page generated in 0.10162 seconds
