Home » Eclipse Projects » Eclipse Scout » Cannot see outline and menu(Eclipse Scout, on Onpensuse 11.4 64 bit with KDE )
Cannot see outline and menu [message #717560] Sun, 21 August 2011 07:08 Go to next message
As you can see in attached images, my app has an outline with a table page, and the default menus. However, when I start the SWT application, I cannot see none of these.
I tried various combination, but nothing changed.
The only warning I see at start of the app is:
!ENTRY org.eclipse.ui 4 4 2011-08-21 12:52:19.477
!MESSAGE Referenced part does not exist yet: frantoio.ui.swt.views.TablePageView.
I updated to the last nightly update, but nothing changed.
Thanks for your help
Re: Cannot see outline and menu [message #717574 is a reply to message #717560] Sun, 21 August 2011 09:15 Go to previous messageGo to next message
Hi Pietro
When creating a new scout application you can choose between some application templates. It seems to me that your application was created with the template "Application with a single form". This template does not include the code for starting the forms used by outline and pages.
To change this behavior you need to add the code to startup the outline forms when opening the desktop:
protected void execOpened() throws ProcessingException {
  // outline tree
  DefaultOutlineTreeForm treeForm = new DefaultOutlineTreeForm();
  treeForm.startView();
  //outline table
  DefaultOutlineTableForm tableForm = new DefaultOutlineTableForm();
  tableForm.startView();
  if (getAvailableOutlines().length > 0) {
    setOutline(getAvailableOutlines()[0]);
This should solve your issue with the outline. To solve the issue with the menus some hand work need to be done because scout does not link the menus defined in the desktop with the eclipse menu bar so far.
Basically you need to declare the eclipse menus in the plugin.xml of the ui.swt plugin, create a command and link its handler with the menu action in the desktop. I suggest to have a look at the org.eclipse.ui.menus extension point and the command/handler concept.
If I have time next week I can provide a howto but do not rely on that.
Hope that helps
Claudio
Re: Cannot see outline and menu [message #717793 is a reply to message #717574] Mon, 22 August 2011 07:39 Go to previous messageGo to next message
Ok I've now solved the outline problem, following your suggestions. For the menu, I thought they should link to main bar automagically, but I know how to do with standard RCP, so don't worry about it and thanks again Smile
Re: Cannot see outline and menu [message #735314 is a reply to message #717574] Tue, 11 October 2011 10:25 Go to previous messageGo to next message
Hi all,
I also struggle with the menu problem.
I created an empty application and there is a File menu with an Exit submenu visible. These are these not in the PlugIn.xml but they still work.
What is the difference between this menu and menus I create myself.
Regards Bertin
Re: Cannot see outline and menu [message #735430 is a reply to message #717560] Tue, 11 October 2011 14:54 Go to previous messageGo to next message
I imagine you have defined menus in your Desktop class (Scout Model). Menus are defined as inner class of other elements that accept them (Desktop in this case, but also Table, Pages, SmartField...).
Something like:
public class Desktop extends AbstractDesktop implements IDesktop {
  private static IScoutLogger logger = ScoutLogManager.getLogger(Desktop.class);
  public Desktop() {
  @Order(10.0)
  public class FileMenu extends AbstractMenu {
    public String getConfiguredText() {
      return Texts.get("FileMenu");
    @Order(10.0)
    public class AddMenu extends AbstractMenu {
      protected String getConfiguredText() {
        return Texts.get("Add");
      @Order(10.0)
      public class CollectionMenu extends AbstractMenu {
          return Texts.get("Collection");
        protected void execAction() throws ProcessingException {
          //TODO add logic to add a new collection
      @Order(20.0)
      public class PictureMenu extends AbstractMenu {
          return Texts.get("Picture");
          //TODO add logic to add a new image
    @Order(20.0)
    public class ExitMenu extends AbstractMenu {
        return Texts.get("ExitMenu");
      public void execAction() throws ProcessingException {
        ClientSyncJob.getCurrentSession(ClientSession.class).stopSession();
Are you using a SWT UI rendering plug in?
If yes, what you point out is a big limitation of the current implementation of the SWT rendering plug-in. Desktop is not correctly supported rendered. (See also: [SWT GUI] switch between outlines attached to the desktop)
This is because of a timing problem. The SWT Rendering plug-in uses the traditional Eclipse RCP Stack (Application ApplicationWorkbenchAdvisor, ApplicationWorkbenchWindowAdvisor, ApplicationActionBarAdvisor...). When the application is started, the Scout Client model isn't instantiated yet.
This could be solved with e4 (considering Scout Client Model as a processor that contribute elements to the application model).
Current solution:
Add the code to add the menu as you would do for any other RCP Application. If you only want a SWT application, you can do this instead of the scout client model. If you want have a single sourced application with multiple UI (multiple renderer like SWT, Swing, RAP...) you need to duplicate in SWT, what you have coded in the Scout Client model.
In SWT, if you want to access something on the scout desktop, you can use the code given here:
ISwtEnvironment env = Activator.getDefault().getEnvironment();
final IDesktop desktop = env.getScoutDesktop();
Runnable t = new Runnable() {
  public void run() {
    // your code here, using the scout desktop.
env.invokeScoutLater(t, 0);
Other solution: use Swing renderer.
Re: Cannot see outline and menu [message #735433 is a reply to message #735314] Tue, 11 October 2011 14:57 Go to previous messageGo to next message
bertin wrote on Tue, 11 October 2011 16:25
The SWT Menus you see are hard-coded in the SWT UI Plug-in:
<your application>.ui.swt.application.ApplicationActionBarAdvisor.fillMenuBar(IMenuManager)
Re: Cannot see outline and menu [message #735956 is a reply to message #735430] Thu, 13 October 2011 04:21 Go to previous message
thanks,
it works although I don't quite understand why in the code below the first call MessageBox.showOkMessage() gives an error and the second, inside the run() works well.
Regards Bertin
 protected void makeActions(IWorkbenchWindow window) {
    exitAction = ActionFactory.QUIT.create(window);
    register(exitAction);
    vensterClientenAction = new Action("Clienten...") {
      public void run() {
        MessageBox.showOkMessage("Clienten", "Toon Clienten", "Deze dialog toont clienten");
          public void run() {
Previous Topic:transaction management
Next Topic:Best practice for large BO's
Current Time: Thu Jul 24 18:50:29 EDT 2025
Powered by FUDForum. Page generated in 0.06295 seconds
