Home » Language IDEs » PHP Development Tools (PDT) » PDT 1.0.3 and Eclipse 3.4 (Ganymede)
PDT 1.0.3 and Eclipse 3.4 (Ganymede) [message #73539] Mon, 16 June 2008 18:19 Go to next message
Trying to get PDT 1.0.3 installed with the latest release of 3.4.
1. Downloaded eclipse-SDK-3.4RC4-win32.zip
2. Extracted and setup Eclipse
3. Downloaded org.eclipse.php_feature-R20080603.zip
4. Extraced 1.0.3 and noticed in the feature.xml under the features
folder that the required components are:
<requires>
<import feature="org.eclipse.wst" version="2.0.0"
match="compatible"/>
<import feature="org.eclipse.platform" version="3.3.0"
</requires>
5. The platform is already installed but is 3.4.0 (3.4.0.v20080606)
6. Installed the Web Standard Tools for 3.4 (3.0.0.v200806040035)
At this point I tried to get the PDT running in Eclipse 3.4 but it won't
enable itself for use. My main concerns are that the WST is now 3.0.0
and the platform is 3.4.0. Will that work okay with PDT?
I also checked the release web page about it needing EMF SDO XSD 2.3.2,
GEF 3.3.2 and WTP 2.0.2 so I installed the complementing versions for
the Ganymede release:
EMF Runtime - 2.4.0.v200806091234
XSD Runtime - 2.4.0.v200806091234
EMF SDO Runtime - 2.4.0.v200806091234
GEF - 3.4.0.v20080115
Web Developer Tools - 3.0.0v200806040035 (I believe this is the
replacement for WTP)
Even after installing those add-ons I still can't get the PDT to run.
Any suggestions???
Shawn Clark
Re: PDT 1.0.3 and Eclipse 3.4 (Ganymede) [message #73556 is a reply to message #73539] Mon, 16 June 2008 18:29 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
AFAIK, PDT 1.0.x won't run on Eclipse 3.4. You want PDT 1.1.
http://wiki.eclipse.org/PDT/Installation#Eclipse_3.4_.2F_Gan ymede_.2F_PDT_1.1
Nick
> <requires>
> </requires>
> Any suggestions???
> Shawn Clark
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: PDT 1.0.3 and Eclipse 3.4 (Ganymede) [message #73574 is a reply to message #73556] Mon, 16 June 2008 18:34 Go to previous messageGo to next message
Thanks for the link. From my understanding a release of 1.1 isn't going
to be available until the middle of September while Eclipse 3.4 is
available shortly. Is the 1.1 far enough along to be in a usable state
for development work?
Shawn Clark
> Nick
>> <requires>
>> </requires>
>> won't enable itself for use. My main concerns are that the WST is now
>> 3.0.0 and the platform is 3.4.0. Will that work okay with PDT?
>> 2.3.2, GEF 3.3.2 and WTP 2.0.2 so I installed the complementing
>> versions for the Ganymede release:
>> Any suggestions???
>> Shawn Clark
Re: PDT 1.0.3 and Eclipse 3.4 (Ganymede) [message #73591 is a reply to message #73574] Mon, 16 June 2008 22:11 Go to previous message
Try it and see. 1.1 is due in September, along with Eclipse 3.4.1.
Here's hoping that the PDT guys decide next year to align with Io
(Eclipse 3.5's coordinated release). *Hint, hint!*
Nick
> Shawn Clark
>> Nick
>>> <requires>
>>> </requires>
>>> Any suggestions???
>>> Shawn Clark
Previous Topic:Where is keyword/syntax highlighting implemented?
Next Topic:Problems after upgrade
Current Time: Fri Jul 25 20:32:19 EDT 2025
Powered by FUDForum. Page generated in 0.06792 seconds
