Home » Eclipse Projects » Nebula » 1 problem, 1 question on GridViewer
1 problem, 1 question on GridViewer [message #726897] Mon, 19 September 2011 16:39 Go to next message
I've got a GridTreeViewer working pretty well as a tree. I have 1 problem and 1 question.
Problem: I can't seem to get the auto-expand to work. I am using both a label provider and group content provider, but whenever I set the autoexpandlevel it is ignored. Does this need to be set in a particular order? I do the following:
(gtv is my GridTreeViewer - and all the columns and column groups are already set up)
MyLabelProvider eglp = new MyLabelProvider(gtv.getGrid());
MyContentProvider egcp = new MyContentProvider();
gtv.setAutoExpandLevel(2); //yes, I have 4 levels to my tree...so this should work
gtv.setContentProvider(egcp);
gtv.setLabelProvider(eglp);
gtv.setInput(myListOfData); //this is actually EList<MyEMFObject>
Question:
Is there no label provider type of thing for the footer? Is it just set the text on each column? Just trying to verify this so that I can code accordingly.
Sharon
Re: 1 problem, 1 question on GridViewer [message #735292 is a reply to message #726897] Tue, 11 October 2011 09:16 Go to previous messageGo to next message
bump!
Re: 1 problem, 1 question on GridViewer [message #735295 is a reply to message #726897] Tue, 11 October 2011 09:21 Go to previous messageGo to next message
bump! Any ideas on how to fix the autoexpand?
Re: 1 problem, 1 question on GridViewer [message #809526 is a reply to message #735295] Tue, 28 February 2012 19:43 Go to previous messageGo to next message
Hi Sharon, is this still bugging you?
Re: 1 problem, 1 question on GridViewer [message #809962 is a reply to message #809526] Wed, 29 February 2012 09:02 Go to previous message
I never got it working....I used a workaround.
I ended up calling expandToLevel(2) once all the data is added to my datastore, then I refresh the gridTreeViewer.
Previous Topic:How traverse on composite Nebula widget DateChooserCombo
Next Topic:CalendarCombo problem #3 - keyboard processing
Current Time: Wed Jul 23 06:10:06 EDT 2025
Powered by FUDForum. Page generated in 0.29154 seconds
