Home » Archived » Buckminster » No component named ... is known to Buckminster
No component named ... is known to Buckminster [message #699793] |
Fri, 22 July 2011 06:08  |
I was trying to add support for the "emma" command, which caused be to
rebuild our headless Buckminster. Suddenly our build started failing
with the following error:
> [java] No component named com.iar.ide.common.doc is known to Buckminster
I also noted the following printout
> [java] INFO: Resetting target platform Buckminster Default TP
which hadn't been there before.
I added some code displaying the version of the buckminster plugins used
in our build in order to try to narrow down when things started to go
wrong. These were the last known good versions:
> [echo] org.eclipse.buckminster.cmdline_1.0.350.r11559.jar
> [echo] org.eclipse.buckminster.core_1.2.361.r11579.jar
> [echo] org.eclipse.buckminster.pde_1.2.1.r11582/pde.jar
And these are the earlier known bad versions:
> [echo] org.eclipse.buckminster.cmdline_1.0.350.r11675.jar
> [echo] org.eclipse.buckminster.core_1.2.361.r11749.jar
> [echo] org.eclipse.buckminster.pde_1.2.1.r11746/pde.jar
We have two Buckminster scripts, one for setting up the workspace:
> # Setup Buckminster workspace
> importtargetdefinition -A ${targetplatform}
> setpref org.eclipse.buckminster.jdt.complianceLevel=1.6
> # Temporarily disabled API checks to be able to build Indigo
> #resolve -P buckminster.properties hubble-baseline.cquery
> #addbaseline -A ${baseline}
The actual build is performed in a separate script:
> resolve -P buckminster.properties hubble.cquery
> build
> # Generate the knownissues.html file from information in Jira
> perform -P buckminster.properties com.iar.ide.common.doc#generate.knownissues
The last line here fails as described above.
Am I doing something wrong with Buckminster, or is this a bug which has
sneaked in?
Re: No component named ... is known to Buckminster [message #735277 is a reply to message #735001] |
Tue, 11 October 2011 07:39   |
Thomas Hallgren skrev 2011-10-10 17:23:
> On 2011-10-10 13:33, Jesper Eskilson wrote:
Weirdly enough, when I try the same thing now, I also get a bunch of
errors about other plugins as well. These errors I did not get before.
> [echo] Running buckminster script file: scripts/build.bmscript (workspace /home/jesperes/hubble-build-tmp)
> [java] INFO: resolve '-P' 'buckminster.properties' 'hubble.cquery'
> [java] INFO: Import complete.
> [java] INFO: build
> [java] ERROR: Problems during metadata refresh
> [java] ERROR: E No component named org.eclipse.ui.intro.universal:osgi.bundle is known to Buckminster
> [java] ERROR: E No component named org.eclipse.core.databinding.property:osgi.bundle/[1.2.0,2.0.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.compare.core:osgi.bundle/[3.5.0,4.0.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.search:osgi.bundle/[3.2.0,4.0.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.cdt.debug.core:osgi.bundle/7.0.0 is known to Buckminster
> [java] ERROR: E No component named org.eclipse.equinox.p2.core:osgi.bundle/[2.0.0,2.1.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.ui.views:osgi.bundle/[3.2.0,4.0.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.core.databinding.observable:osgi.bundle/[1.3.0,2.0.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.ltk.ui.refactoring:osgi.bundle/[3.5.0,4.0.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.cdt.launch:osgi.bundle/6.1.0 is known to Buckminster
> [java] INFO: perform '-P' 'buckminster.properties' 'com.iar.ide.common.doc#generate.knownissues'
> BUILD FAILED
There is really nothing special about the com.iar.ide.common.doc
component. It is a regular Eclipse plug-in. The "generate.knownissues"
action is a custom action on the com.iar.ide.common.doc component which
simply invokes the "ant" actor on a build.xml file in the component.
See attached file with output from running Buckminster with DEBUG
logging. As far as I can see, the com.iar.ide.common.doc component is
being resolved correctly.
/Jesper
clean-workspace:
[delete] Deleting directory /home/jesperes/dev/eclipse/features/com.iar.hubble.releng/buckminster-headless
[delete] Deleting directory /home/jesperes/hubble-build-tmp/helios/workspace
[unzip] Expanding: /home/jesperes/dev/eclipse/com.iar.ide.buckminster/buckminster-headless.zip into /home/jesperes/dev/eclipse/features/com.iar.hubble.releng/buckminster-headless
[unzip] Expanding: /home/jesperes/dev/eclipse/features/com.iar.hubble.releng/buckminster-workspace-template.zip into /home/jesperes/hubble-build-tmp/helios/workspace
[echo] org.eclipse.buckminster.cmdline_1.0.350.v20110910-0906.jar
[echo] org.eclipse.buckminster.core_1.3.0.v20110915-1108.jar
[echo] org.eclipse.buckminster.pde_1.3.0.v20110910-0906/pde.jar
setup:
run-buckminster:
[mkdir] Created dir: /home/jesperes/hubble-build-tmp/helios/workspace/junit
[echo] Running buckminster script file: scripts/setup.bmscript (workspace /home/jesperes/hubble-build-tmp)
[java] importtargetdefinition '-A' 'file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/helios/helios.target'
[java] Doing full workspace refresh
[java] Waiting for jobs to end
[java] setpref 'org.eclipse.buckminster.jdt.complianceLevel=1.6'
[java] Preference 'org.eclipse.buckminster.jdt.complianceLevel' set to the value '1.6'
build:
run-buckminster:
[java] resolve '-P' 'buckminster.properties' 'hubble.cquery'
[java] Platform install location: /home/jesperes/dev/eclipse/features/com.iar.hubble.releng/buckminster-headless
[java] Target platform provided by class org.eclipse.buckminster.pde.internal.PDETargetPlatform
[java] com.iar.hubble.product.feature:eclipse.feature: Using resolver rmap
[java] com.iar.hubble.product.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.hubble.product.feature:eclipse.feature
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.hubble.product.feature:eclipse.feature
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.hubble.product.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.hubble.product.feature): No component match was found
[java] com.iar.hubble.product.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.hubble.product.feature:eclipse.feature: Using search path default
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble.product.feature])
[java] com.iar.hubble.product.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble.product.feature]): Components of type eclipse.feature are not supported
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble.product.feature])
[java] com.iar.hubble.product.feature:eclipse.feature: Found match
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.hubble.product.feature])
[java] com.iar.hubble.product.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.hubble.product.feature]): Components of type eclipse.feature are not supported
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.hubble.product.feature])
[java] com.iar.hubble.product.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.hubble.product.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble.product.feature]) is producing a better match
[java] com.iar.hubble.product.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble.product.feature])
[java] com.iar.branding:osgi.bundle: Using resolver Local resolver
[java] com.iar.branding:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.branding:osgi.bundle
[java] com.iar.hubble:osgi.bundle: Using resolver Local resolver
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.hubble.product.arm.feature:eclipse.feature
[java] com.iar.hubble:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.hubble:osgi.bundle
[java] com.iar.branding:osgi.bundle: Trying provider local(workspace)
[java] com.iar.hubble:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.branding:osgi.bundle
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.hubble:osgi.bundle
[java] com.iar.branding:osgi.bundle: Trying provider local(target)
[java] No open workspace project found that corresponds to com.iar.hubble.product.arm.feature:eclipse.feature
[java] com.iar.hubble:osgi.bundle: Trying provider local(target)
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.hubble.product.arm.feature): No component match was found
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.branding:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.branding): No component match was found
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Using search path default
[java] com.iar.hubble:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.hubble): No component match was found
[java] com.iar.hubble:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.hubble:osgi.bundle: Using search path default
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble.product.arm.feature])
[java] com.iar.branding:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble.product.arm.feature]): Components of type eclipse.feature are not supported
[java] com.iar.hubble:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble])
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble.product.arm.feature])
[java] com.iar.branding:osgi.bundle: Using search path default
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Found match
[java] com.iar.hubble:osgi.bundle: Found match
[java] com.iar.hubble:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble])
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.hubble.product.arm.feature])
[java] com.iar.branding:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.branding])
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.hubble.product.arm.feature]): Components of type eclipse.feature are not supported
[java] com.iar.hubble:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble]): Components of type osgi.bundle are not supported
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.hubble.product.arm.feature])
[java] com.iar.branding:osgi.bundle: Found match
[java] com.iar.branding:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.branding])
[java] com.iar.hubble:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.hubble])
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.hubble.product.arm.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble.product.arm.feature]) is producing a better match
[java] com.iar.branding:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.branding]): Components of type osgi.bundle are not supported
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble.product.arm.feature])
[java] com.iar.branding:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.branding])
[java] com.iar.hubble:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.hubble]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble]) is producing a better match
[java] com.iar.hubble:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.hubble])
[java] com.iar.branding:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.branding]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.branding]) is producing a better match
[java] com.iar.hubble:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.hubble]): Components of type osgi.bundle are not supported
[java] com.iar.branding:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.branding])
[java] com.iar.hubble:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble])
[java] com.iar.branding:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.branding]): Components of type osgi.bundle are not supported
[java] com.iar.branding:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.branding])
[java] org.eclipse.core.runtime:osgi.bundle: Using resolver Local resolver
[java] org.eclipse.ui:osgi.bundle: Using resolver Local resolver
[java] org.eclipse.core.runtime:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for org.eclipse.core.runtime:osgi.bundle
[java] org.eclipse.ui:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for org.eclipse.ui:osgi.bundle
[java] org.eclipse.core.runtime:osgi.bundle: Trying provider local(workspace)
[java] org.eclipse.ui:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.core.runtime:osgi.bundle
[java] No open workspace project found that corresponds to org.eclipse.ui:osgi.bundle
[java] org.eclipse.core.runtime:osgi.bundle: Trying provider local(target)
[java] org.eclipse.ui:osgi.bundle: Trying provider local(target)
[java] org.eclipse.core.runtime:osgi.bundle: Found match 3.6.0.v20100505
[java] org.eclipse.ui:osgi.bundle: Found match 3.6.2.M20110203-1100
[java] org.eclipse.core.runtime:osgi.bundle: Found match org.eclipse.core.runtime:osgi.bundle$3.6.0.v20100505
[java] org.eclipse.ui:osgi.bundle: Found match org.eclipse.ui:osgi.bundle$3.6.2.M20110203-1100
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.arm.sdk.feature:eclipse.feature
[java] com.iar.cdt.common.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider local(workspace)
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider local(materialized)
[java] No open workspace project found that corresponds to com.iar.cdt.arm.sdk.feature:eclipse.feature
[java] No materialization found for com.iar.cdt.common.feature:eclipse.feature
[java] com.iar.common.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider local(workspace)
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider local(target)
[java] No open workspace project found that corresponds to com.iar.cdt.common.feature:eclipse.feature
[java] com.iar.common.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.common.feature:eclipse.feature
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.cdt.arm.sdk.feature): No component match was found
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.ide.debugger.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.common.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.common.feature:eclipse.feature
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Using search path default
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.ide.debugger.feature:eclipse.feature
[java] com.iar.cdt.common.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.cdt.common.feature): No component match was found
[java] com.iar.cdt.common.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.common.feature:eclipse.feature: Using search path default
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.ide.debugger.feature:eclipse.feature
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.sdk.feature])
[java] com.iar.common.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.sdk.feature]): Components of type eclipse.feature are not supported
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.common.feature])
[java] com.iar.ide.debugger.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.ide.debugger.feature): No component match was found
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.sdk.feature])
[java] com.iar.common.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.common.feature): No component match was found
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Found match
[java] com.iar.ide.debugger.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.ide.debugger.feature:eclipse.feature: Using search path default
[java] com.iar.cdt.common.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.common.feature]): Components of type eclipse.feature are not supported
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.ide.debugger.feature])
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.sdk.feature])
[java] com.iar.common.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.sdk.feature]): Components of type eclipse.feature are not supported
[java] com.iar.ide.debugger.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.ide.debugger.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.common.feature])
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.ide.debugger.feature])
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.sdk.feature])
[java] com.iar.common.feature:eclipse.feature: Using search path default
[java] com.iar.ide.debugger.feature:eclipse.feature: Found match
[java] com.iar.cdt.common.feature:eclipse.feature: Found match
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.ide.debugger.feature])
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.sdk.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.sdk.feature]) is producing a better match
[java] com.iar.common.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.common.feature])
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.sdk.feature])
[java] com.iar.ide.debugger.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.ide.debugger.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.common.feature])
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.ide.debugger.feature])
[java] com.iar.common.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.common.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.common.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.common.feature]): Components of type eclipse.feature are not supported
[java] com.iar.ide.debugger.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.ide.debugger.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.ide.debugger.feature]) is producing a better match
[java] com.iar.common.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.common.feature])
[java] com.iar.ide.debugger.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.ide.debugger.feature])
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.common.feature])
[java] com.iar.common.feature:eclipse.feature: Found match
[java] com.iar.common.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.common.feature])
[java] com.iar.cdt.common.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.common.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.common.feature]) is producing a better match
[java] com.iar.common.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.common.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.common.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.common.feature])
[java] com.iar.common.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.common.feature])
[java] com.iar.common.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.common.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.common.feature]) is producing a better match
[java] com.iar.common.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.common.feature])
[java] com.iar.installer.arm:osgi.bundle: Using resolver Local resolver
[java] com.iar.installer.arm:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.installer.arm:osgi.bundle
[java] com.iar.installer.arm:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.installer.arm:osgi.bundle
[java] com.iar.installer.arm:osgi.bundle: Trying provider local(target)
[java] com.iar.ide.common.doc.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.installer.arm:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.installer.arm): No component match was found
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.ide.common.doc.feature:eclipse.feature
[java] com.iar.installer.arm:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider local(workspace)
[java] com.iar.installer.arm:osgi.bundle: Using search path default
[java] No open workspace project found that corresponds to com.iar.ide.common.doc.feature:eclipse.feature
[java] com.iar.installer.arm:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.installer.arm])
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.installer.arm:osgi.bundle: Found match
[java] com.iar.ide.common.doc.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.ide.common.doc.feature): No component match was found
[java] com.iar.ide.common.doc.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.installer.arm:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.installer.arm])
[java] com.iar.ide.common.doc.feature:eclipse.feature: Using search path default
[java] com.iar.installer.arm:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.installer.arm]): Components of type osgi.bundle are not supported
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.ide.common.doc.feature])
[java] com.iar.installer.arm:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.installer.arm])
[java] com.iar.ide.common.doc.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.ide.common.doc.feature]): Components of type eclipse.feature are not supported
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.ide.common.doc.feature])
[java] com.iar.installer.arm:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.installer.arm]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.installer.arm]) is producing a better match
[java] com.iar.ide.common.doc.feature:eclipse.feature: Found match
[java] com.iar.installer.arm:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.installer.arm])
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.ide.common.doc.feature])
[java] com.iar.installer.arm:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.installer.arm]): Components of type osgi.bundle are not supported
[java] com.iar.ide.common.doc.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.ide.common.doc.feature]): Components of type eclipse.feature are not supported
[java] com.iar.installer.arm:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.installer.arm])
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.ide.common.doc.feature])
[java] com.iar.ide.common.doc.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.ide.common.doc.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.ide.common.doc.feature]) is producing a better match
[java] com.iar.ide.common.doc.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.ide.common.doc.feature])
[java] com.iar.common.projectimport.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.common.projectimport.feature:eclipse.feature
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.common.projectimport.feature:eclipse.feature
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.common.projectimport.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.common.projectimport.feature): No component match was found
[java] com.iar.common.projectimport.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.common.projectimport.feature:eclipse.feature: Using search path default
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.common.projectimport.feature])
[java] com.iar.common.projectimport.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.common.projectimport.feature]): Components of type eclipse.feature are not supported
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.common.projectimport.feature])
[java] com.iar.common.projectimport.feature:eclipse.feature: Found match
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.common.projectimport.feature])
[java] com.iar.common.projectimport.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.common.projectimport.feature]): Components of type eclipse.feature are not supported
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.common.projectimport.feature])
[java] com.iar.common.projectimport.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.common.projectimport.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.common.projectimport.feature]) is producing a better match
[java] com.iar.common.projectimport.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.common.projectimport.feature])
[java] org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0)
[java] org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0): Trying provider local(workspace)
[java] org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0)
[java] No open workspace project found that corresponds to org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0): Trying provider local(target)
[java] org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0): Trying provider local(target)
[java] org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0): Found match 3.5.0.v20100503
[java] org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0): Found match 3.6.2.R36x_v20110210
[java] org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0): Found match org.eclipse.equinox.registry:osgi.bundle$3.5.0.v20100503
[java] org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0): Found match org.eclipse.osgi:osgi.bundle$3.6.2.R36x_v20110210
[java] org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0)
[java] org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0)
[java] org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0): Trying provider local(target)
[java] org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0): Trying provider local(target)
[java] org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0): Found match 3.6.0.v20100503
[java] org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0): Using resolver Local resolver
[java] org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0)
[java] org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0)
[java] org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0): Found match 3.4.100.v20100505-1235
[java] org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0): Trying provider local(target)
[java] org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0): Found match 1.3.1.R36x_v20100803
[java] org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0): Found match org.eclipse.equinox.common:osgi.bundle$3.6.0.v20100503
[java] org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0): Trying provider local(target)
[java] org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0): Found match 3.6.2.M20110210-1200
[java] org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0)
[java] org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0)
[java] org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0): Trying provider local(target)
[java] org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0): Found match 3.6.0.v20100505
[java] org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0): Found match org.eclipse.core.contenttype:osgi.bundle$3.4.100.v20100505-1235
[java] org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0): Found match org.eclipse.equinox.app:osgi.bundle$1.3.1.R36x_v20100803
[java] org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0): Trying provider local(target)
[java] org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0): Found match org.eclipse.core.runtime:osgi.bundle$3.6.0.v20100505
[java] org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0): Found match 3.6.2.M20110210-1200
[java] org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0): Trying provider local(target)
[java] org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0): Found match 3.6.2.v3659c
[java] org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0)
[java] org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0)
[java] org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0): Trying provider local(target)
[java] org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0): Found match 3.4.200.v20100505
[java] org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0): Found match org.eclipse.swt:osgi.bundle$3.6.2.v3659c
[java] org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0): Found match org.eclipse.core.expressions:osgi.bundle$3.4.200.v20100505
[java] com.iar.cdt.arm.samples:osgi.bundle: Using resolver Local resolver
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.arm.samples:osgi.bundle
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.arm.samples:osgi.bundle
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.arm.toolchain.feature:eclipse.feature
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider local(target)
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.arm.toolchain.feature:eclipse.feature
[java] com.iar.cdt.arm.samples:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.cdt.arm.samples): No component match was found
[java] com.iar.cdt.arm.samples:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.cdt.arm.samples:osgi.bundle: Using search path default
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.cdt.arm.toolchain.feature): No component match was found
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.samples])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.arm.samples:osgi.bundle: Found match
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.samples])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Using search path default
[java] com.iar.cdt.arm.samples:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.samples]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.samples])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.toolchain.feature])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.toolchain.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.arm.samples:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.samples]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.samples]) is producing a better match
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.toolchain.feature])
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.samples])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Found match
[java] com.iar.cdt.arm.samples:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.samples]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.toolchain.feature])
[java] org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0): Found match org.eclipse.jface:osgi.bundle$3.6.2.M20110210-1200
[java] com.iar.cdt.arm.samples:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.samples])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.toolchain.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.toolchain.feature])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.toolchain.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.toolchain.feature]) is producing a better match
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.toolchain.feature])
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.arm.debugger.feature:eclipse.feature
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.arm.debugger.feature:eclipse.feature
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.cdt.arm.debugger.feature): No component match was found
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Using search path default
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.debugger.feature])
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.debugger.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.debugger.feature])
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Found match
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.debugger.feature])
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.debugger.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.debugger.feature])
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.debugger.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.debugger.feature]) is producing a better match
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.debugger.feature])
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Using resolver Local resolver
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.arm.sdk.branding:osgi.bundle
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.arm.sdk.branding:osgi.bundle
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider local(target)
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.cdt.arm.sdk.branding): No component match was found
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Using search path default
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.sdk.branding])
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Found match
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.sdk.branding])
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.sdk.branding]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.sdk.branding])
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.sdk.branding]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.sdk.branding]) is producing a better match
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.sdk.branding])
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.sdk.branding]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.sdk.branding])
[java] com.iar.cdt.project.utils:osgi.bundle: Using resolver Local resolver
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.project.utils:osgi.bundle
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.project.utils:osgi.bundle
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider local(target)
[java] com.iar.cdt.project.utils:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.cdt.project.utils): No component match was found
[java] com.iar.cdt.project.utils:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.project.utils:osgi.bundle: Using search path default
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Using resolver Local resolver
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.project.utils])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.generic.toolchain:osgi.bundle
[java] com.iar.cdt.project.utils:osgi.bundle: Found match
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.generic.toolchain:osgi.bundle
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.project.utils])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider local(target)
[java] com.iar.cdt.project.utils:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.project.utils]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.cdt.generic.toolchain): No component match was found
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.project.utils])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Using search path default
[java] com.iar.cdt.project.utils:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.project.utils]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.project.utils]) is producing a better match
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.project.utils])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.generic.toolchain])
[java] com.iar.cdt.project.utils:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.project.utils]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Found match
[java] com.iar.cdt.project.utils:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.project.utils])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.generic.toolchain])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.generic.toolchain]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.generic.toolchain])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.generic.toolchain]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.generic.toolchain]) is producing a better match
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.generic.toolchain])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.generic.toolchain]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.generic.toolchain])
[java] org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0): Found match org.eclipse.ui.workbench:osgi.bundle$3.6.2.M20110210-1200
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Using resolver Local resolver
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.generic.wizardPages:osgi.bundle
[java] com.iar.cdt.generic.toolchain.ui:osgi.bundle: Using resolver Local resolver
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Trying provider local(workspace)
[java] com.iar.cdt.generic.toolchain.ui:osgi.bundle: Trying provider local(materialized)
[java] No open workspace project found that corresponds to com.iar.cdt.generic.wizardPages:osgi.bundle
[java] No materialization found for com.iar.cdt.generic.toolchain.ui:osgi.bundle
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Trying provider local(target)
[java] com.iar.cdt.generic.toolchain.ui:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.generic.toolchain.ui:osgi.bundle
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.cdt.generic.wizardPages): No component match was found
[java] com.iar.cdt.generic.toolchain.ui:osgi.bundle: Trying provider local(target)
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.generic.toolchain.ui:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.cdt.generic.toolchain.ui): No component match was found
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Using search path default
[java] com.iar.cdt.generic.toolchain.ui:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/h
Re: No component named ... is known to Buckminster [message #735291 is a reply to message #735277] |
Tue, 11 October 2011 08:48   |
Hi Jesper,
Judging from the log it looks like the target platform that you import in the beginning is somehow forgotten when you
run the resolve which is a bit odd.
Another thing that strikes me is that you seem to use the url.catalog extensively. That's not very common. Why is that?
- thomas
> Weirdly enough, when I try the same thing now, I also get a bunch of errors about other plugins as well. These errors I
> did not get before.
>> [java] INFO: Resetting target platform Buckminster Default TP
>> [java] INFO: build
>> Buckminster
>> Buckminster
>> [java] No component named com.iar.ide.common.doc is known to Buckminster
>> BUILD FAILED
> There is really nothing special about the com.iar.ide.common.doc component. It is a regular Eclipse plug-in. The
> "generate.knownissues" action is a custom action on the com.iar.ide.common.doc component which simply invokes the "ant"
> See attached file with output from running Buckminster with DEBUG logging. As far as I can see, the
> com.iar.ide.common.doc component is being resolved correctly.
> /Jesper
Re: No component named ... is known to Buckminster [message #756905 is a reply to message #735294] |
Tue, 15 November 2011 08:41  |
Jesper Eskilson skrev 2011-10-11 15:17:
> Thomas Hallgren skrev 2011-10-11 14:48:
>> Hi Jesper,
>> in the beginning is somehow forgotten when you run the resolve which is
>> a bit odd.
The reason turned out to be that our RMAP specified source="false",
which caused all our plugins to be materialized into the target
platform. This caused the target platform to be reset after the
"resolve" command, and all the plugins I expected to be in the workspace
were in the target platform instead.
/Jesper
Current Time: Sun Jul 27 22:25:42 EDT 2025
Powered by FUDForum. Page generated in 0.51471 seconds
