Home » Modeling » UML2 Tools » Problem installing UML Tools on Eclipse Galileo
Problem installing UML Tools on Eclipse Galileo [message #734643] Sat, 08 October 2011 22:18 Go to next message
For the life of me, I could not succeed in installing UML tools on Indigo and Helios.
So I stepped back further to Galileo and this is what I get -----
An error occurred while collecting items to be installed
session context was:(profile=epp.package.java, phase=org.eclipse.equinox.internal.provisional.p2.engine.phases.Collect, operand=, action=).
Problems downloading artifact: osgi.bundle,org.eclipse.emf.ant,2.4.0.v200906151043.
File has invalid content:C:\Users\XXXXX\AppData\Local\Temp\signatureFile219212316609769752.jar
Invalid content:ant_tasks/emf.ant.tasks.jar
The file "ant_tasks/emf.ant.tasks.jar" in the jar "C:\Users\XXXXX\AppData\Local\Temp\signatureFile219212316609769752.jar" has been tampered!
Problems downloading artifact: osgi.bundle,org.eclipse.m2m.qvt.oml.runtime,2.0.0.v20090608-1830.
File has invalid content:C:\Users\XXXXX\AppData\Local\Temp\signatureFile2961258532017761391.jar
Invalid content:lib/antTasks.jar
The file "lib/antTasks.jar" in the jar "C:\Users\XXXXX\AppData\Local\Temp\signatureFile2961258532017761391.jar" has been tampered!
Problems downloading artifact: osgi.bundle,org.eclipse.uml2.uml.ecore.importer,2.3.0.v200905041045.
File has invalid content:C:\Users\XXXXX\AppData\Local\Temp\signatureFile1702082796190300617.jar
Invalid content:ant_tasks/uml2.uml.ecore.importer.tasks.jar
The file "ant_tasks/uml2.uml.ecore.importer.tasks.jar" in the jar "C:\Users\XXXXX\AppData\Local\Temp\signatureFile1702082796190300617.jar" has been tampered!
Any solution to this issue?
Re: Problem installing UML Tools on Eclipse Galileo [message #734687 is a reply to message #734643] Sun, 09 October 2011 05:41 Go to previous message
For a long time the Galileo release was the latest UML2 Tools release
and it worked fine on Galileo but not on Helios, for which a build was
made available outside Eclipse. Eventually the 0.10 build appeared on
the update site and IIRC it works on both Helios and Indigo. I have
certainly used it on Indigo.
I suspect your problems are to do with not using a consistent set of
Galileo plugins.
Since Indigo works, and you are not tied by legacy constraints, I
recommend solving your Indigo problem rather than investigating what may
be a download corruption, or perhaps a plugin mismatch.
Ed Willink
> Indigo and Helios.
> operand=, action=).
> File has invalid
> been tampered!
> File has invalid
> has been tampered!
> File has invalid
> has been tampered!
Previous Topic:Class cardinality on class diagram
Next Topic:Does class diagram support Chinese characters?
Current Time: Wed Jul 23 05:26:25 EDT 2025
Powered by FUDForum. Page generated in 0.04325 seconds
