Home » Newcomers » Newcomers » PDE Build: building Source feature.
PDE Build: building Source feature. [message #72871] Thu, 02 June 2005 18:59 Go to next message
Originally posted by: VMarathe.ifmc.sdps.org
Hi Everybody,
I am building a feature using PDE build process and also trying to
generate source feature and plugins also. As per the documentation I
have read so far, we have to make two entries.
1. In build.properties in feature project, add "generate.feature" script
2. Add "<includes>" element in feature.xml
Using this, I get the distributable zip file as I want but it includes
all zip files of the plug-ins source code.
My question is, are the source code zips supposed to be included in the
binary distributable? I want all the source code zips to go to a
different zip file. I have a limited idea about building source features.
Any kind of help is highly appreciated.
Thanks.
Re: PDE Build: building Source feature. [message #73449 is a reply to message #72871] Fri, 03 June 2005 19:09 Go to previous messageGo to next message
Vasant,
I assume you are making reference to this fine article:
http://www.eclipse.org/articles/Article-PDE-Automation/autom ation.html
What you get is a feature, and a plugin extending
org.eclipse.pde.core.source.
The plugin contains only the sources as a zip.
The whole zip will contain everything, binary plugins and source plugins as
well as the related features.
If you want two different zips one with source only, the other without
sources, check how this is done:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.releng. eclipsebuilder/
Each directory corresponds to a set of builds.
You might need a bit of customization of the customTargets.xml to accomplish
what you want as Eclipse is typically distributed as binaries only or
binaries+sources.
Re: PDE Build: building Source feature. [message #74292 is a reply to message #73449] Mon, 06 June 2005 09:52 Go to previous messageGo to next message
Philippe Ombredanne wrote:
> Vasant,
> binaries+sources.
Thanks, a lot, Philippe for your reply.
Yes, I was making reference to the same link.
I will go through the link you have provided and see if it explains what
I need to do. It would also be great if you could let me know which
folder I can take a look at from the link you have sent, because the
link contains many different folders.
Thanks again.
Vasant.
Re: PDE Build: building Source feature. [message #74431 is a reply to message #74292] Mon, 06 June 2005 12:05 Go to previous messageGo to next message
"Vasant" <VMarathe@ifmc.sdps.org> wrote in message
news:42A45530.4060106@ifmc.sdps.org...
Dear Vasant,
I doubt you will find any explanantion, but the code and the article should
help you make your way around.
And if you want to write some explanantion for everybody to enjoy, that
would very nice!
Re: PDE Build: building Source feature. [message #74596 is a reply to message #74431] Mon, 06 June 2005 12:36 Go to previous message
> Dear Vasant,
> would very nice!
Thanks, Philippe, for coming back.
I will dig through the code and shall write some explanation about
seperating the source and binary once I figure it out.
Thanks again,
Vasant
Previous Topic:JeBee and Eclipse
Next Topic:fortran libraries
Current Time: Fri Jul 18 14:28:52 EDT 2025
Powered by FUDForum. Page generated in 0.31325 seconds
