Abstract class with generics [message #730849] |
Thu, 29 September 2011 06:56  |
Hello !
I'm working with Swingbuilder 3.6 on IBM® Rational® Developer for System z® mit Java
Version: 8.0.1.
I create an abstract class with the following constructor:
public AbstractCobolSearchPanel(Class<? extends T> classOfT, U fachlogik, boolean showToolbar, boolean showMessageLine, KkvsWorkspace parent)
and use it in this implementation:
public KV94SearchPanel(KV9401CobolService fachlogik, KkvsWorkspace parent)
throws BackendException {
super(KV9401CompositeBean.class, fachlogik, true, true, parent);
If i open the panel in SwinBuilder i got the message:
WindowBuilder was not able to find constructor with signature <init>(java.lang.Class,de.kbs.framework_pt.persistence.service.KV9401CobolService,boolean,boolean,de.kbs.kkvsframework.gui.mainwindow.KkvsWorkspace) in de.kbs.kkvsframework.gui.panel.AbstractCobolSearchPanel.
Is it not possible to work with generics in constructors ?
Thank's Andreas
Re: Abstract class with generics [message #735058 is a reply to message #730849] |
Mon, 10 October 2011 15:49  |
Using generics in constructors should work fine.
If you are using WB 8.0.1, that is very old. Please try it again using the most recent v1.1 release from Eclipse.
If you are still having problems, please submit a complete bug report to Bugzilla (Tools > WindowBuilder). Include a complete test case and your complete Eclipse .metadata ".log" file and Eclipse configuration.
FUDForum. Page generated in 0.02718 seconds
